Fwd: New Defects reported by Coverity Scan for RTEMS
Wed Dec 9 09:56:53 UTC 2020
On 09/12/2020 10:11, Sebastian Huber wrote:
> On 08/12/2020 19:10, Gedare Bloom wrote:
>> Hi all,
>> I get a text report on new defects from Coverity. I don't know how I
>> managed to sign up for it, and I'm not sure I can get it sent to any
>> list automatically, but here is the current updated new defects. Just
>> looks like two new ones related to static assertions.
>> ---------- Forwarded message ---------
>> From: <scan-admin at coverity.com <mailto:scan-admin at coverity.com>>
>> Date: Mon, Dec 7, 2020 at 7:38 AM
>> Subject: New Defects reported by Coverity Scan for RTEMS
>> To: <gedare at gwmail.gwu.edu <mailto:gedare at gwmail.gwu.edu>>
>> Hi,
>> Please find the latest report on new defect(s) introduced to RTEMS
>> found with Coverity Scan.
>> 1 new defect(s) introduced to RTEMS found with Coverity Scan.
>> 10 defect(s), reported by Coverity Scan earlier, were marked fixed in
>> the recent build analyzed by Coverity Scan.
>> New defect(s) Reported-by: Coverity Scan
>> Showing 1 of 1 defect(s)
>> ** CID 1470570:    (PARSE_ERROR)
>> /cpukit/include/rtems/confdefs/inittask.h: 110 in ()
>> ________________________________________________________________________________________________________
>> *** CID 1470570:    (PARSE_ERROR)
>> 104      */
>> 105     #pragma GCC diagnostic push
>> 106     #pragma GCC diagnostic ignored "-Waddress"
>> 107     #pragma GCC diagnostic ignored "-Wpragmas"
>> 108     #pragma GCC diagnostic ignored "-Wtautological-pointer-compare"
>> 109
>> >>>     type of cast must be integral
>> 110     RTEMS_STATIC_ASSERT(
>> 111       CONFIGURE_INIT_TASK_ENTRY_POINT != NULL,
>> 112       CONFIGURE_INIT_TASK_ENTRY_POINT_MUST_NOT_BE_NULL
>> 113     );
>> 114
>> 115     #pragma GCC diagnostic pop
>> 104      */
>> 109
>> >>>     expression must be an integral constant expression
>> 113     );
>> 114
> I checked an example code with three compilers and noticed no standard
> related warnings. I can ask on a C/C++ mailing list if the code is
> standard compliant. It could be Coverity bug.
> #include <cstddef>
> void f(void);
> static_assert(f != NULL, "f");
> constexpr bool g()
>   return f != NULL;
> extern const bool b;
> const bool b = g();
> arm-rtems6-g++ -Wall -Wextra -pedantic -std=c++11 -S -o - test.cc
>         .cpu arm7tdmi
>         .eabi_attribute 20, 1
>         .eabi_attribute 21, 1
>         .eabi_attribute 23, 3
>         .eabi_attribute 24, 1
>         .eabi_attribute 25, 1
>         .eabi_attribute 26, 2
>         .eabi_attribute 30, 6
>         .eabi_attribute 34, 0
>         .eabi_attribute 18, 4
>         .file   "test.cc"
> test.cc:5:17: warning: the address of 'void f()' will never be NULL
> [-Waddress]
>     5 | static_assert(f != NULL, "f");
> test.cc: In function 'constexpr bool g()':
> test.cc:9:12: warning: the address of 'void f()' will never be NULL
> [-Waddress]
>     9 |   return f != NULL;
>         .text
>         .global b
>         .section        .rodata
>         .type   b, %object
>         .size   b, 1
> b:
>         .byte   1
>         .ident  "GCC: (GNU) 10.2.1 20201203 (RTEMS 6, RSB
> ff6b2320ed34abab48751022085912217f42590d, Newlib 7fa8405)"
>         .file   "test.cc"
> test.cc:5:17: warning: the address of ‘void f()’ will never be NULL
> [-Waddress]
> test.cc: In function ‘constexpr bool g()’:
> test.cc:9:12: warning: the address of ‘void f()’ will never be NULL
> [-Waddress]
>    return f != NULL;
>         .text
>         .globl  b
>         .section        .rodata
>         .type   b, @object
>         .size   b, 1
> b:
>         .byte   1
>         .ident  "GCC: (SUSE Linux) 7.5.0"
>         .section        .note.GNU-stack,"", at progbits
> clang -Wall -Wextra -pedantic -std=c++11 -S -o - test.cc
> test.cc:5:15: warning: comparison of function 'f' not equal to a null
> pointer is always true [-Wtautological-pointer-compare]
> test.cc:5:15: note: prefix with the address-of operator to silence
> this warning
> test.cc:9:10: warning: comparison of function 'f' not equal to a null
>   return f != NULL;
> test.cc:9:10: note: prefix with the address-of operator to silence
> this warning
>   return f != NULL;
>         .text
>         .file   "test.cc"
>         .type   b, at object               # @b
>         .section        .rodata,"a", at progbits
>         .globl  b
> b:
>         .byte   1                       # 0x1
>         .size   b, 1
>         .ident  "clang version 7.0.1 (tags/RELEASE_701/final 349238)"
>         .section        ".note.GNU-stack","", at progbits
>         .addrsig
>         .addrsig_sym b
> 2 warnings generated.
I checked this C code
#include <stddef.h>
void f(void);
_Static_assert(f != 0, "f");
and here we get pedantic warnings and errors:
test.c:5:18: warning: expression in static assertion is not an integer
constant expression [-Wpedantic]
     5 | _Static_assert(f != 0, "f");
test.c:5:16: error: static_assert expression is not an integral constant
expression
It seems we cannot use a static assertion to catch these errors.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
