RTEMS Tester: Set Timeout in *.ini?
Sebastian Huber
Wed Dec 9 12:46:41 UTC 2020
Hello,
I have some tests which run a bit longer than the default 180s timeout
of the RTEMS Tester. Can I change the default timeout in the *.ini
files? This didn't work:
[fvp_cortex_r52x1]
bsp = fvp_cortex_r52
arch = arm
tester = %{_rtscripts}/run.cfg
bsp_run_cmd = FVP_BaseR_Cortex-R52x1
bsp_run_opts = -C bp.vis.disable_visualisation=1 -a
timeout = 600
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
