RTEMS Tester: Set Timeout in *.ini?
Wed Dec 9 13:54:17 UTC 2020
On 09/12/2020 13:46, Sebastian Huber wrote:
> Hello,
> I have some tests which run a bit longer than the default 180s timeout
> of the RTEMS Tester. Can I change the default timeout in the *.ini
> files? This didn't work:
> [fvp_cortex_r52x1]
> bsp          = fvp_cortex_r52
> arch         = arm
> tester       = %{_rtscripts}/run.cfg
> bsp_run_cmd  = FVP_BaseR_Cortex-R52x1
> bsp_run_opts = -C bp.vis.disable_visualisation=1 -a
> timeout      = 600
Also what is the difference between these to two options:
# Defaults
timeout:              none,    none,     '180'  # seconds
max_test_period:      none,    none,     '300'  # seconds
If I set --timeout=600 on the command line I get a test too long error
after 300 seconds.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
