[PATCH 2/2] bsps: Fix GICv3 arm_gic_trigger_sgi()
Wed Dec 9 14:23:57 UTC 2020
On 09/12/2020 15:14, Kinsey Moore wrote:
> -----Original Message-----
> From: devel <devel-bounces at rtems.org> On Behalf Of Sebastian Huber
> Sent: Wednesday, December 9, 2020 07:35
> To: devel at rtems.org
> Subject: [PATCH 2/2] bsps: Fix GICv3 arm_gic_trigger_sgi()
> Use the targets parameter to determine the targets of the SGI.
> Update #4202.
>   bsps/shared/dev/irq/arm-gicv3.c | 2 +-
>   1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/bsps/shared/dev/irq/arm-gicv3.c b/bsps/shared/dev/irq/arm-gicv3.c index db10371c72..569c7610c4 100644
> --- a/bsps/shared/dev/irq/arm-gicv3.c
> +++ b/bsps/shared/dev/irq/arm-gicv3.c
> @@ -356,7 +356,7 @@ void arm_gic_trigger_sgi(
>     uint64_t value = ICC_SGIR_AFFINITY2(MPIDR_AFFINITY2_GET(mpidr))
>                    | ICC_SGIR_INTID(vector)
>                    | ICC_SGIR_AFFINITY1(MPIDR_AFFINITY1_GET(mpidr))
> -                 | ICC_SGIR_CPU_TARGET_LIST(1);
> +                 | ICC_SGIR_CPU_TARGET_LIST(targets);
> Does the tm27 test still function on the Cortex-R52 or the generic A53 BSP after this change? The GICv2 implementation uses the filter to decide which CPU to send to since the target is set to 0 for that test. I don't see a defined behavior in the documentation for GICv3 of an all-zero target list since the filter isn't being taken into account here.
> Kinsey
Ok, I will test this. Maybe we have to change
   rtems_status_code sc = arm_gic_irq_generate_software_irq(
     ARM_GIC_TM27_IRQ_HIGH,
     ARM_GIC_IRQ_SOFTWARE_IRQ_TO_SELF,
     0
   assert(sc == RTEMS_SUCCESSFUL);
to
     ARM_GIC_IRQ_SOFTWARE_IRQ_TO_ALL_IN_LIST,
     arm_cp15_get_multiprocessor_affinity() & 0xff
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
