[PATCH 0/5] Support for Armv8-R (AArch32)
Sebastian Huber
Wed Dec 9 16:44:13 UTC 2020
Sebastian Huber (5):
arm: Support Armv8 in <rtems/score/arm.h>
arm/cache-cp15: Support Armv8
bsps/arm: Unify ARM Generic Timer options
bsps/arm: Support system level ARM Generic Timer
bsps/arm: Move BSP_START_IN_HYP_SUPPORT option
bsps/arm/shared/cache/cache-cp15.c | 25 +++++++++----------
bsps/shared/dev/clock/arm-generic-timer.c | 13 +++++++++-
.../score/cpu/arm/include/rtems/score/arm.h | 21 ++++++++--------
.../optgentmrfreq.yml => optgtfreq.yml} | 9 ++++---
spec/build/bsps/arm/optgtsysbase.yml | 19 ++++++++++++++
spec/build/bsps/arm/optgtsyscntcr.yml | 20 +++++++++++++++
.../optgentmrusevirt.yml => optgtusevirt.yml} | 3 ++-
.../optenhyp.yml => optstarthyp.yml} | 3 ++-
spec/build/bsps/arm/raspberrypi/grp.yml | 2 +-
spec/build/bsps/arm/xen/bspxen.yml | 2 +-
spec/build/bsps/arm/xen/optgentmrusevirt.yml | 15 -----------
.../arm/xilinx-zynqmp/bspxilinxzynqmp.yml | 8 +++---
12 files changed, 88 insertions(+), 52 deletions(-)
rename spec/build/bsps/arm/{xilinx-zynqmp/optgentmrfreq.yml => optgtfreq.yml} (67%)
create mode 100644 spec/build/bsps/arm/optgtsysbase.yml
create mode 100644 spec/build/bsps/arm/optgtsyscntcr.yml
rename spec/build/bsps/arm/{xilinx-zynqmp/optgentmrusevirt.yml => optgtusevirt.yml} (71%)
rename spec/build/bsps/arm/{raspberrypi/optenhyp.yml => optstarthyp.yml} (74%)
delete mode 100644 spec/build/bsps/arm/xen/optgentmrusevirt.yml
2.26.2
