[PATCH 1/5] arm: Support Armv8 in <rtems/score/arm.h>
Wed Dec 9 16:44:14 UTC 2020
Update #4202.
 .../score/cpu/arm/include/rtems/score/arm.h   | 21 +++++++++----------
 1 file changed, 10 insertions(+), 11 deletions(-)
diff --git a/cpukit/score/cpu/arm/include/rtems/score/arm.h b/cpukit/score/cpu/arm/include/rtems/score/arm.h
index f753dd60ed..b1e4b07a37 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/arm.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/arm.h
@@ -1,7 +1,9 @@
  * @file
- * @brief ARM Assembler Support API
+ * @ingroup RTEMSScoreCPUARM
+ * @brief This header file provides defines derived from ARM multilib defines.
@@ -26,8 +28,9 @@ extern "C" {
  * @addtogroup RTEMSScoreCPUARM
 #if defined(__ARM_ARCH_7M__) || defined(__ARM_ARCH_7EM__)
   #define CPU_MODEL_NAME "ARMv7M"
@@ -40,10 +43,7 @@ extern "C" {
   #define ARM_MULTILIB_ARCH_V4
 #endif
-#if defined(__ARM_ARCH_7A__) \
-  || defined(__ARM_ARCH_7R__) \
-  || defined(__ARM_ARCH_7M__) \
-  || defined(__ARM_ARCH_7EM__)
+#if __ARM_ARCH >= 7
   #define ARM_MULTILIB_HAS_WFI
   #define ARM_MULTILIB_HAS_LOAD_STORE_EXCLUSIVE
   #define ARM_MULTILIB_HAS_BARRIER_INSTRUCTIONS
@@ -51,18 +51,17 @@ extern "C" {
 #ifndef ARM_DISABLE_THREAD_ID_REGISTER_USE
+    || defined(__ARM_ARCH_7R__) \
+    || __ARM_ARCH >= 8
     #define ARM_MULTILIB_HAS_THREAD_ID_REGISTER
   #endif
 #endif
+#if defined(__ARM_ARCH_7A__) || __ARM_ARCH >= 8
   #define ARM_MULTILIB_CACHE_LINE_MAX_64
 #endif
   #define ARM_MULTILIB_HAS_CPACR
 #endif
2.26.2
