[PATCH 2/5] arm/cache-cp15: Support Armv8
Wed Dec 9 16:44:15 UTC 2020
Update #4202.
 bsps/arm/shared/cache/cache-cp15.c | 25 ++++++++++++-------------
 1 file changed, 12 insertions(+), 13 deletions(-)
diff --git a/bsps/arm/shared/cache/cache-cp15.c b/bsps/arm/shared/cache/cache-cp15.c
index cdce02425f..9a58146277 100644
--- a/bsps/arm/shared/cache/cache-cp15.c
+++ b/bsps/arm/shared/cache/cache-cp15.c
@@ -22,17 +22,16 @@
 #define CPU_INSTRUCTION_CACHE_ALIGNMENT 32
-#if defined(__ARM_ARCH_7A__)
-/* Some/many ARM Cortex-A cores have L1 data line length 64 bytes */
-#define CPU_MAXIMAL_CACHE_ALIGNMENT 64
+#ifdef ARM_MULTILIB_CACHE_LINE_MAX_64
+  #define CPU_MAXIMAL_CACHE_ALIGNMENT 64
 #endif
 #define CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS
 #define CPU_CACHE_SUPPORT_PROVIDES_CACHE_SIZE_FUNCTIONS
-#if __ARM_ARCH >= 7 && (__ARM_ARCH_PROFILE == 65 || __ARM_ARCH_PROFILE == 82)
-#define CPU_CACHE_SUPPORT_PROVIDES_DISABLE_DATA
+#if __ARM_ARCH >= 7
+  #define CPU_CACHE_SUPPORT_PROVIDES_DISABLE_DATA
 #endif
 static inline void _CPU_cache_flush_1_data_line(const void *d_addr)
@@ -51,9 +50,9 @@ _CPU_cache_flush_data_range(
     d_addr,
     n_bytes
-  #if !defined(__ARM_ARCH_7A__)
+#if __ARM_ARCH < 7
   arm_cp15_drain_write_buffer();
-  #endif
+#endif
  _ARM_Data_synchronization_barrier();
@@ -109,22 +108,22 @@ static inline void _CPU_cache_unfreeze_instruction(void)
 static inline void _CPU_cache_flush_entire_data(void)
-  #if defined(__ARM_ARCH_7A__)
   arm_cp15_data_cache_clean_all_levels();
-  #else
+#else
   arm_cp15_data_cache_clean_and_invalidate();
-  #endif
+#endif
 static inline void _CPU_cache_invalidate_entire_data(void)
   arm_cp15_data_cache_invalidate_all_levels();
-  #else
+#else
   arm_cp15_data_cache_invalidate();
-  #endif
+#endif
 static inline void _CPU_cache_enable_data(void)
2.26.2
