[rtems-docs commit] c-user: Generate Timer Manager documentation
Chris Johns
chrisj at rtems.org
Thu Dec 10 02:24:49 UTC 2020
On 9/12/20 7:20 pm, Sebastian Huber wrote:
> Module: rtems-docs
> Branch: master
> Commit: d716c79070901195912526c6e49d43defad00bdd
> Changeset: http://git.rtems.org/rtems-docs/commit/?id=d716c79070901195912526c6e49d43defad00bdd
> Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date: Wed Dec 2 08:17:12 2020 +0100
> The documentation is a consolidation of the comments in Doxygen markup
> and the documentation sources in Sphinx markup. The documentation was
> transfered to interface specification items. The documentation source
> files were generated from the items by a script.
> Update #3993.
> c-user/timer/directives.rst | 992 ++++++++++++++++++++++++++----------------
> c-user/timer/introduction.rst | 57 ++-
> 2 files changed, 674 insertions(+), 375 deletions(-)
> diff --git a/c-user/timer/directives.rst b/c-user/timer/directives.rst
> index d9b9877..d65f263 100644
> --- a/c-user/timer/directives.rst
> +++ b/c-user/timer/directives.rst
> @@ -1,463 +1,729 @@
> .. SPDX-License-Identifier: CC-BY-SA-4.0
> +.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
> .. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
> +.. This file is part of the RTEMS quality process and was automatically
> +.. generated. If you find something that needs to be fixed or
> +.. worded better please post a report or patch to an RTEMS mailing list
> +.. or raise a bug report:
> +.. https://docs.rtems.org/branches/master/user/support/bugs.html
> +.. For information on updating and regenerating please refer to:
> +.. https://docs.rtems.org/branches/master/eng/req/howto.html
We need a solution. I would prefer we resolve this before we add any more
instances of these links.
Suggestions?
