[rtems-docs commit] c-user: Generate Timer Manager documentation
Thu Dec 10 05:41:18 UTC 2020
On 10/12/2020 03:24, Chris Johns wrote:
> On 9/12/20 7:20 pm, Sebastian Huber wrote:
>> Module:    rtems-docs
>> Branch:    master
>> Commit:    d716c79070901195912526c6e49d43defad00bdd
>> Changeset: http://git.rtems.org/rtems-docs/commit/?id=d716c79070901195912526c6e49d43defad00bdd
>> Author:    Sebastian Huber <sebastian.huber at embedded-brains.de>
>> Date:      Wed Dec  2 08:17:12 2020 +0100
>> The documentation is a consolidation of the comments in Doxygen markup
>> and the documentation sources in Sphinx markup.  The documentation was
>> transfered to interface specification items.  The documentation source
>> files were generated from the items by a script.
>> Update #3993.
>>   c-user/timer/directives.rst   | 992 ++++++++++++++++++++++++++----------------
>>   c-user/timer/introduction.rst |  57 ++-
>>   2 files changed, 674 insertions(+), 375 deletions(-)
>> diff --git a/c-user/timer/directives.rst b/c-user/timer/directives.rst
>> index d9b9877..d65f263 100644
>> --- a/c-user/timer/directives.rst
>> +++ b/c-user/timer/directives.rst
>> @@ -1,463 +1,729 @@
>>   .. SPDX-License-Identifier: CC-BY-SA-4.0
>> +.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
>>   .. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
>> +.. This file is part of the RTEMS quality process and was automatically
>> +.. generated.  If you find something that needs to be fixed or
>> +.. worded better please post a report or patch to an RTEMS mailing list
>> +.. or raise a bug report:
>> +.. https://docs.rtems.org/branches/master/user/support/bugs.html
>> +.. For information on updating and regenerating please refer to:
>> +.. https://docs.rtems.org/branches/master/eng/req/howto.html
> We need a solution. I would prefer we resolve this before we add any more
> instances of these links.
I understand that cross-document links are a problem, however, these two
links are in comments and thus don't show up in the generated documents.
A link to the bug reporting should always point to the latest
information since there is only one bug reporting procedure in the
project at a time. The link to the howto could be branch-specific.
> Suggestions?
We could add a script which performs some post processing after creation
the of the release branches.
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
