[PATCH v2] bsps: Fix GICv3 arm_gic_trigger_sgi()
Thu Dec 10 05:45:54 UTC 2020
On 10/12/2020 00:26, Kinsey Moore wrote:
> -----Original Message-----
> From: devel<devel-bounces at rtems.org>  On Behalf Of Sebastian Huber
> Sent: Wednesday, December 9, 2020 10:33
> To:devel at rtems.org
> Subject: [PATCH v2] bsps: Fix GICv3 arm_gic_trigger_sgi()
>> Use the targets parameter to determine the targets of the SGI.
>> Update #4202.
>> v2: Fix tm27 test support.
>>   bsps/include/dev/irq/arm-gic-tm27.h | 8 ++++----
>>   bsps/shared/dev/irq/arm-gicv3.c     | 2 +-
>>   2 files changed, 5 insertions(+), 5 deletions(-)
>> diff --git a/bsps/include/dev/irq/arm-gic-tm27.h b/bsps/include/dev/irq/arm-gic-tm27.h
>> index 95f3077716..8edacc39e4 100644
>> --- a/bsps/include/dev/irq/arm-gic-tm27.h
>> +++ b/bsps/include/dev/irq/arm-gic-tm27.h
>> @@ -79,8 +79,8 @@ static inline void Cause_tm27_intr(void)  {
>>     rtems_status_code sc = arm_gic_irq_generate_software_irq(
>>       ARM_GIC_TM27_IRQ_LOW,
>> -    ARM_GIC_IRQ_SOFTWARE_IRQ_TO_SELF,
>> -    0
>> +    ARM_GIC_IRQ_SOFTWARE_IRQ_TO_ALL_IN_LIST,
>> +    1
>>     assert(sc == RTEMS_SUCCESSFUL);
>> @@ -94,8 +94,8 @@ static inline void Lower_tm27_intr(void)  {
>>       ARM_GIC_TM27_IRQ_HIGH,
>> -    0
>> +    1
> These changes will work on core 0, but will fail if running on any other core which is a change in behavior for this test.
>> diff --git a/bsps/shared/dev/irq/arm-gicv3.c b/bsps/shared/dev/irq/arm-gicv3.c index db10371c72..569c7610c4 100644
>> --- a/bsps/shared/dev/irq/arm-gicv3.c
>> +++ b/bsps/shared/dev/irq/arm-gicv3.c
>> @@ -356,7 +356,7 @@ void arm_gic_trigger_sgi(
>>     uint64_t value = ICC_SGIR_AFFINITY2(MPIDR_AFFINITY2_GET(mpidr))
>>                    | ICC_SGIR_INTID(vector)
>>                    | ICC_SGIR_AFFINITY1(MPIDR_AFFINITY1_GET(mpidr))
>> -                 | ICC_SGIR_CPU_TARGET_LIST(1);
>> +                 | ICC_SGIR_CPU_TARGET_LIST(targets);
> I think my processor filter todo just above this code will need to be addressed along with this change for correct behavior on non-core 0 runs of tm27.
Yes, I thought about non-core 0 test runs too, however, I guess a lot
more things will pop up if someone does this the first time. We could
replace the 1 with an 1 << (arm_cp15_get_multiprocessor_affinity() & 0xff).
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
