[PATCH v2] bsps: Fix GICv3 arm_gic_trigger_sgi()
Thu Dec 10 13:30:39 UTC 2020
On 10/12/2020 14:26, Kinsey Moore wrote:
>>> I think my processor filter todo just above this code will need to be addressed along with this change for correct behavior on non-core 0 runs of tm27.
>> Yes, I thought about non-core 0 test runs too, however, I guess a lot more things will pop up if someone does this the first time. We could replace the 1 with an 1 << (arm_cp15_get_multiprocessor_affinity() & 0xff).
> That sounds good for the time being. I'll work on a patch to address the filter issues.
I removed the filter feature here:
https://lists.rtems.org/pipermail/devel/2020-December/063707.html
We could add a separate function
arm_gic_sgi_broadcast_to_other()
if needed.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
