[PATCH] arm: Optimize arm_interrupt_disable()
Sebastian Huber
Thu Dec 10 15:20:47 UTC 2020
Update #4202.
cpukit/score/cpu/arm/include/rtems/score/cpu.h | 13 +++++++++++--
1 file changed, 11 insertions(+), 2 deletions(-)
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpu.h b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
index 8a8e8cc617..e5b23e7100 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
@@ -276,8 +276,6 @@ static inline uint32_t arm_interrupt_disable( void )
uint32_t level;
#if defined(ARM_MULTILIB_ARCH_V4)
- uint32_t arm_switch_reg;
* Disable only normal interrupts (IRQ).
@@ -292,6 +290,16 @@ static inline uint32_t arm_interrupt_disable( void )
* operating system support for a FIQ, she can trigger a software interrupt and
* service the request in a two-step process.
+#if __ARM_ARCH >= 7
+ __asm__ volatile (
+ "mrs %0, cpsr\n"
+ "cpsid i\n"
+ "isb"
+ : "=&r" (level)
+#else
+ uint32_t arm_switch_reg;
__asm__ volatile (
ARM_SWITCH_TO_ARM
"mrs %[level], cpsr\n"
@@ -300,6 +308,7 @@ static inline uint32_t arm_interrupt_disable( void )
ARM_SWITCH_BACK
: [arm_switch_reg] "=&r" (arm_switch_reg), [level] "=&r" (level)
+#endif
#elif defined(ARM_MULTILIB_ARCH_V7M)
uint32_t basepri = 0x80;
2.26.2
