[rtems-docs commit] c-user: Generate Timer Manager documentation
Fri Dec 11 00:35:55 UTC 2020
On 10/12/20 4:41 pm, Sebastian Huber wrote:
> On 10/12/2020 03:24, Chris Johns wrote:
>> On 9/12/20 7:20 pm, Sebastian Huber wrote:
>>> Module:    rtems-docs
>>> Branch:    master
>>> Commit:    d716c79070901195912526c6e49d43defad00bdd
>>> Changeset:
>>> http://git.rtems.org/rtems-docs/commit/?id=d716c79070901195912526c6e49d43defad00bdd
>>> Author:    Sebastian Huber <sebastian.huber at embedded-brains.de>
>>> Date:      Wed Dec  2 08:17:12 2020 +0100
>>> The documentation is a consolidation of the comments in Doxygen markup
>>> and the documentation sources in Sphinx markup.  The documentation was
>>> transfered to interface specification items.  The documentation source
>>> files were generated from the items by a script.
>>> Update #3993.
>>>   c-user/timer/directives.rst   | 992 ++++++++++++++++++++++++++----------------
>>>   c-user/timer/introduction.rst |  57 ++-
>>>   2 files changed, 674 insertions(+), 375 deletions(-)
>>> diff --git a/c-user/timer/directives.rst b/c-user/timer/directives.rst
>>> index d9b9877..d65f263 100644
>>> --- a/c-user/timer/directives.rst
>>> +++ b/c-user/timer/directives.rst
>>> @@ -1,463 +1,729 @@
>>>   .. SPDX-License-Identifier: CC-BY-SA-4.0
>>>   +.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
>>>   .. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
>>>   +.. This file is part of the RTEMS quality process and was automatically
>>> +.. generated.  If you find something that needs to be fixed or
>>> +.. worded better please post a report or patch to an RTEMS mailing list
>>> +.. or raise a bug report:
>>> +.. https://docs.rtems.org/branches/master/user/support/bugs.html
>>> +.. For information on updating and regenerating please refer to:
>>> +.. https://docs.rtems.org/branches/master/eng/req/howto.html
>> We need a solution. I would prefer we resolve this before we add any more
>> instances of these links.
> I understand that cross-document links are a problem, however, these two links
> are in comments and thus don't show up in the generated documents. A link to the
> bug reporting should always point to the latest information since there is only
> one bug reporting procedure in the project at a time. The link to the howto
> could be branch-specific.
Yes I agree. My concern is a change in how master is hosted breaks the links.
>> Suggestions?
> We could add a script which performs some post processing after creation the of
> the release branches.
What about ....
https://www.rtems.org/support/bugs.html
If a redirect can be set up we could insulate these links from the location they
are.
