[PATCH 1/2] tm27: Use generic cpu index accessor
Fri Dec 11 05:48:06 UTC 2020
On 10/12/2020 21:42, Kinsey Moore wrote:
> The arm_cp15 function for accessing the current CPU index is specific
> to ARMv7 while this header is used for ARMv8 as well. Instead, use a
> generic accessor that is part of the standard CPU API.
I am fine with this fix, however, this is basically now the same
approach as in my v2 patch:
https://lists.rtems.org/pipermail/devel/2020-December/063693.html
Since the tm27 test is configured to use only one CPU, the current
processor is always 0.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
