[PATCH] Add GMP as a prerequisite for GDB
Sebastian Huber
Fri Dec 11 13:00:20 UTC 2020
bare/config/devel/gmp-6.1.0.cfg | 18 ++++++++++
rtems/config/6/rtems-default.bset | 1 +
rtems/config/7/rtems-default.bset | 1 +
source-builder/config/gmp.cfg | 60 +++++++++++++++++++++++++++++++
4 files changed, 80 insertions(+)
create mode 100644 bare/config/devel/gmp-6.1.0.cfg
create mode 100644 source-builder/config/gmp.cfg
diff --git a/bare/config/devel/gmp-6.1.0.cfg b/bare/config/devel/gmp-6.1.0.cfg
new file mode 100644
index 0000000..7bedba9
--- /dev/null
+++ b/bare/config/devel/gmp-6.1.0.cfg
@@ -0,0 +1,18 @@
+# GMP 6.1.0
+%if %{release} == %{nil}
+%define release 1
+%endif
+%include %{_configdir}/base.cfg
+%define gmp_version 6.1.0
+%hash sha512 gmp-%{gmp_version}.tar.bz2 3c82aeab9c1596d4da8afac2eec38e429e84f3211e1a572cf8fd2b546493c44c039b922a1133eaaa48bd7f3e11dbe795a384e21ed95cbe3ecc58d7ac02246117
+# The GMP build instructions.
+%include %{_configdir}/gmp.cfg
diff --git a/rtems/config/6/rtems-default.bset b/rtems/config/6/rtems-default.bset
index 0dc2e77..220778c 100644
--- a/rtems/config/6/rtems-default.bset
+++ b/rtems/config/6/rtems-default.bset
@@ -11,6 +11,7 @@
devel/expat-2.1.0-1
+devel/gmp-6.1.0
tools/rtems-gdb-head
tools/rtems-binutils-head
diff --git a/rtems/config/7/rtems-default.bset b/rtems/config/7/rtems-default.bset
index b37d75f..acb7059 100644
--- a/rtems/config/7/rtems-default.bset
+++ b/rtems/config/7/rtems-default.bset
@@ -6,6 +6,7 @@
devel/expat-2.1.0-1
+devel/gmp-6.1.0
diff --git a/source-builder/config/gmp.cfg b/source-builder/config/gmp.cfg
index 0000000..0e9118e
--- /dev/null
+++ b/source-builder/config/gmp.cfg
@@ -0,0 +1,60 @@
+# The GNU Multiple Precision Arithmetic Library (GMP)
+# This configuration file configure's, make's and install's GMP.
+%define release 1
+%endif
+Name: gmp-%{gmp_version}-%{_host}-%{release}
+Summary: The GNU Multiple Precision Arithmetic Library (GMP) v%{gmp_version} for target %{_target} on host %{_host}
+Version: %{gmp_version}
+Release: %{release}
+URL: https://gmplib.org/
+# Source
+%source set gmp https://gcc.gnu.org/pub/gcc/infrastructure/gmp-%{gmp_version}.tar.bz2
+# Prepare the source code.
+%prep
+ build_top=$(pwd)
+ %source setup gmp -q -n gmp-%{gmp_version}
+ %patch setup gmp -p1
+ cd ${build_top}
+%build
+ build_top=$(pwd)
+ cd gmp-%{gmp_version}
+ %{host_build_flags}
+ ./configure \
+ --build=%{_build} --host=%{_host} \
+ --verbose \
+ --prefix=%{_prefix} --bindir=%{_bindir} \
+ --exec-prefix=%{_exec_prefix} \
+ --includedir=%{_includedir} --libdir=%{_libdir} \
+ --mandir=%{_mandir} --infodir=%{_infodir}
+ %{__make} %{?_smp_mflags} all
+ cd ${build_top}
+%install
+ build_top=$(pwd)
+ rm -rf $SB_BUILD_ROOT
+ %{__make} DESTDIR=$SB_BUILD_ROOT install
+ cd ${build_top}
2.26.2
