[PATCH] config: Fix invalid static assertions in C
Joel Sherrill
joel at rtems.org
Fri Dec 11 13:32:52 UTC 2020
On Fri, Dec 11, 2020, 7:26 AM Gedare Bloom <gedare at rtems.org> wrote:
> Hi Sebastian,
> On Fri, Dec 11, 2020 at 5:57 AM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> Expressions in static assertions must be integral constant expressions.
>> In
>> integral constant expressions the use of address constant expressions is
>> not
>> allowed.
>> In static initializers the address constant expressions are allowed.
>> Introduce
>> a new macro _CONFIGURE_ASSERT_NOT_NULL() which leads to a compile time
>> error if
>> the second parameter is NULL. It generates error messages like this if
>> for
>> example
>> #define CONFIGURE_INIT_TASK_ENTRY_POINT NULL
>> is provided by the application:
>> cpukit/include/rtems/confdefs/inittask.h:51:26: error: size of unnamed
>> array is negative
>> 51 | ( _type ) sizeof( int[ ( _value ) != NULL ? 1 : -1 ] ) )
>> cpukit/include/rtems/confdefs/inittask.h:170:3: note: in expansion of
>> macro '_CONFIGURE_ASSERT_NOT_NULL'
>> 170 | _CONFIGURE_ASSERT_NOT_NULL(
> This is a nice fix. The initial error is opaque, but the macro expansion
> seems to be clear enough to help a user debug. Thanks
+1
If this was done because of a Coverity flagged issue, please include the
CID in the commit message
>> Update #4181.
>> cpukit/include/rtems/confdefs/inittask.h | 27 +++++++++++--------
>> cpukit/include/rtems/confdefs/wkspace.h | 34 +++++++++++-------------
>> 2 files changed, 32 insertions(+), 29 deletions(-)
>> diff --git a/cpukit/include/rtems/confdefs/inittask.h
>> b/cpukit/include/rtems/confdefs/inittask.h
>> index d5ba521bf9..9dbf0b967b 100644
>> --- a/cpukit/include/rtems/confdefs/inittask.h
>> +++ b/cpukit/include/rtems/confdefs/inittask.h
>> @@ -46,6 +46,10 @@
>> #ifdef CONFIGURE_INIT
>> +#define _CONFIGURE_ASSERT_NOT_NULL( _type, _value ) \
>> + ( ( _value ) != NULL ? ( _value ) : \
>> + ( _type ) sizeof( int[ ( _value ) != NULL ? 1 : -1 ] ) )
> Magic ;)
>> #ifdef CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> #include <rtems/confdefs/percpu.h>
>> @@ -94,8 +98,8 @@ extern "C" {
>> #endif
>> - * Ignore the following warnings from g++ and clang in the static
>> assertion
>> - * below:
>> + * Ignore the following warnings from g++ and clang in the uses of
>> + * _CONFIGURE_ASSERT_NOT_NULL() below:
>> * warning: the address of 'void Init()' will never be NULL [-Waddress]
>> @@ -107,13 +111,6 @@ extern "C" {
>> #pragma GCC diagnostic ignored "-Wpragmas"
>> #pragma GCC diagnostic ignored "-Wtautological-pointer-compare"
>> -RTEMS_STATIC_ASSERT(
>> - CONFIGURE_INIT_TASK_ENTRY_POINT != NULL,
>> - CONFIGURE_INIT_TASK_ENTRY_POINT_MUST_NOT_BE_NULL
>> -#pragma GCC diagnostic pop
>> #ifdef CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
>> #ifdef CONFIGURE_INIT_TASK_STACK_SIZE
>> @@ -139,7 +136,10 @@ const RTEMS_tasks_User_task_config
>> _RTEMS_tasks_User_task_config = {
>> CONFIGURE_INIT_TASK_INITIAL_MODES,
>> CONFIGURE_INIT_TASK_ATTRIBUTES,
>> - CONFIGURE_INIT_TASK_ENTRY_POINT,
>> + _CONFIGURE_ASSERT_NOT_NULL(
>> + rtems_task_entry,
>> + CONFIGURE_INIT_TASK_ENTRY_POINT
>> CONFIGURE_INIT_TASK_ARGUMENTS
>> @@ -167,7 +167,10 @@ const rtems_initialization_tasks_table
>> _RTEMS_tasks_User_task_table = {
>> CONFIGURE_INIT_TASK_STACK_SIZE,
>> CONFIGURE_INIT_TASK_PRIORITY,
>> + rtems_task_entry,
>> @@ -180,6 +183,8 @@ RTEMS_SYSINIT_ITEM(
>> #endif /* CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE */
>> +#pragma GCC diagnostic pop
>> #ifdef __cplusplus
>> #endif
>> diff --git a/cpukit/include/rtems/confdefs/wkspace.h
>> b/cpukit/include/rtems/confdefs/wkspace.h
>> index 39014d7f1d..eac4bdb4bd 100644
>> --- a/cpukit/include/rtems/confdefs/wkspace.h
>> +++ b/cpukit/include/rtems/confdefs/wkspace.h
>> @@ -139,8 +139,8 @@ const uintptr_t _Stack_Space_size =
>> _CONFIGURE_STACK_SPACE_SIZE;
>> #if defined(CONFIGURE_TASK_STACK_ALLOCATOR) \
>> && defined(CONFIGURE_TASK_STACK_DEALLOCATOR)
>> assertions
>> - * below:
>> * warning: the address of 'f()' will never be NULL [-Waddress]
>> @@ -159,13 +159,11 @@ const uintptr_t _Stack_Space_size =
>> #endif
>> #ifdef CONFIGURE_TASK_STACK_ALLOCATOR_INIT
>> - RTEMS_STATIC_ASSERT(
>> - CONFIGURE_TASK_STACK_ALLOCATOR_INIT != NULL,
>> - CONFIGURE_TASK_STACK_ALLOCATOR_INIT_MUST_NOT_BE_NULL
>> const Stack_Allocator_initialize _Stack_Allocator_initialize =
>> - CONFIGURE_TASK_STACK_ALLOCATOR_INIT;
>> + Stack_Allocator_initialize,
>> + CONFIGURE_TASK_STACK_ALLOCATOR_INIT
>> RTEMS_SYSINIT_ITEM(
>> _Stack_Allocator_do_initialize,
>> @@ -174,21 +172,21 @@ const uintptr_t _Stack_Space_size =
>> #endif
>> - CONFIGURE_TASK_STACK_ALLOCATOR != NULL,
>> - CONFIGURE_TASK_STACK_ALLOCATOR_MUST_NOT_BE_NULL
>> + Stack_Allocator_allocate
>> CONFIGURE_TASK_STACK_ALLOCATOR_MUST_NOT_BE_NULL;
>> const Stack_Allocator_allocate _Stack_Allocator_allocate =
>> - CONFIGURE_TASK_STACK_ALLOCATOR;
>> + Stack_Allocator_allocate,
>> - CONFIGURE_TASK_STACK_DEALLOCATOR != NULL,
>> - CONFIGURE_TASK_STACK_DEALLOCATOR_MUST_NOT_BE_NULL
>> + Stack_Allocator_free CONFIGURE_TASK_STACK_DEALLOCATOR_MUST_NOT_BE_NULL;
>> const Stack_Allocator_free _Stack_Allocator_free =
>> - CONFIGURE_TASK_STACK_DEALLOCATOR;
>> + Stack_Allocator_free,
>> + CONFIGURE_TASK_STACK_DEALLOCATOR
>> #elif defined(CONFIGURE_TASK_STACK_ALLOCATOR) \
>> 2.26.2
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201211/1a1fff8d/attachment.html>
