[PATCH v2] eng: Requirements counting shall start at zero
Frank Kuehndel
frank.kuehndel at embedded-brains.de
Fri Dec 11 14:41:09 UTC 2020
From: Frank Kühndel <frank.kuehndel at embedded-brains.de>
eng/req/req-for-req.rst | 21 +++++++++++++++++++++
1 file changed, 21 insertions(+)
diff --git a/eng/req/req-for-req.rst b/eng/req/req-for-req.rst
index 9225e95..dcc4c11 100644
--- a/eng/req/req-for-req.rst
+++ b/eng/req/req-for-req.rst
@@ -308,6 +308,27 @@ spec:/classic/task/create-err-invname
+If requirements or the YAML files which contain them are to be numbered,
+the numbering shall start with 0. For example:
+.. code-block:: none
+ weak-alias-0.yml
+ weak-alias-1.yml
+Smaller numbers shall be prefixed with 0 to the same count of digits
+as the largest number. For example:
+ alias-00.yml
+ alias-01.yml
+ alias-02.yml
+ alias-09.yml
+ alias-10.yml
+ alias-11.yml
Conflict Free Requirements
2.26.2
