[PATCH v2] eng: Requirements counting shall start at zero
Fri Dec 11 14:49:56 UTC 2020
On Fri, Dec 11, 2020, 8:41 AM Frank Kuehndel <
frank.kuehndel at embedded-brains.de> wrote:
> From: Frank Kühndel <frank.kuehndel at embedded-brains.de>
>  eng/req/req-for-req.rst | 21 +++++++++++++++++++++
>  1 file changed, 21 insertions(+)
> diff --git a/eng/req/req-for-req.rst b/eng/req/req-for-req.rst
> index 9225e95..dcc4c11 100644
> --- a/eng/req/req-for-req.rst
> +++ b/eng/req/req-for-req.rst
> @@ -308,6 +308,27 @@ spec:/classic/task/create-err-invname
> +If requirements or the YAML files which contain them are to be numbered,
> +the numbering shall start with 0. For example:
> +.. code-block:: none
> +    weak-alias-0.yml
> +    weak-alias-1.yml
> +Smaller numbers shall be prefixed with 0 to the same count of digits
> +as the largest number. For example:
When one goes from 99 to 100 requirements and didn't anticipate having that
many, does this mean all the files will have to be renamed?
Should we start with a minimum of three or four digits? What would drive
the number of requirements in a set? How large of a functional area will a
single numbered set contain?
I'm just wondering if it is simpler to just have 001 as a minimum.
> +    alias-00.yml
> +    alias-01.yml
> +    alias-02.yml
> +    alias-09.yml
> +    alias-10.yml
> +    alias-11.yml
>  Conflict Free Requirements
> 2.26.2
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201211/84c26ec1/attachment-0001.html>
