[PATCH v2] eng: Requirements counting shall start at zero
Fri Dec 11 16:43:14 UTC 2020
On Fri, Dec 11, 2020 at 10:38 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Dec 11, 2020 at 9:12 AM Frank Kühndel <
> frank.kuehndel at embedded-brains.de> wrote:
>> Hello Gedare,
>> On 12/11/20 4:41 PM, Gedare Bloom wrote:
>> > On Fri, Dec 11, 2020 at 8:16 AM Frank Kühndel
>> > <frank.kuehndel at embedded-brains.de
>> > <mailto:frank.kuehndel at embedded-brains.de>> wrote:
>> >     Hello Joel,
>> >     On 12/11/20 3:49 PM, Joel Sherrill wrote:
>> >     > On Fri, Dec 11, 2020, 8:41 AM Frank Kuehndel
>> >     <mailto:frank.kuehndel at embedded-brains.de>>> wrote:
>> >     >     From: Frank Kühndel <frank.kuehndel at embedded-brains.de
>> >     >      eng/req/req-for-req.rst | 21 +++++++++++++++++++++
>> >     >      1 file changed, 21 insertions(+)
>> >     >     diff --git a/eng/req/req-for-req.rst b/eng/req/req-for-req.rst
>> >     >     index 9225e95..dcc4c11 100644
>> >     >     --- a/eng/req/req-for-req.rst
>> >     >     +++ b/eng/req/req-for-req.rst
>> >     >     @@ -308,6 +308,27 @@ spec:/classic/task/create-err-invname
>> >     >     +If requirements or the YAML files which contain them are to
>> be
>> >     >     numbered,
>> >     >     +the numbering shall start with 0. For example:
>> >     >     +.. code-block:: none
>> >     >     +    weak-alias-0.yml
>> >     >     +    weak-alias-1.yml
>> >     >     +Smaller numbers shall be prefixed with 0 to the same count of
>> >     digits
>> >     >     +as the largest number. For example:
>> >     > When one goes from 99 to 100 requirements and didn't anticipate
>> having
>> >     > that many, does this mean all the files will have to be renamed?
>> >     I can change the text to what Gedare Bloom suggested: "If we know
>> the
>> >     max count (N) ahead of time, ..."
>> >     Just from my experience with the requirements for the basedefs,
>> when I
>> >     create the requirements for an operation, I know the number I end up
>> >     with before checking them in. The issue we discuss would only cause
>> >     trouble if later more requirements for the same operation must be
>> added.
>> >     This is not totally unlikely but it means that one actually has 9
>> and
>> >     then need a 10th one.
>> >     > Should we start with a minimum of three or four digits? What would
>> >     drive
>> >     > the number of requirements in a set? How large of a functional
>> >     area will
>> >     > a single numbered set contain?
>> >     > I'm just wondering if it is simpler to just have 001 as a minimum.
>> >     I think that 99 requirements for a single operation are really out
>> of
>> >     scope. That will hopefully never ever happen. Even 9 is already a
>> lot.
>> >     Also it is rather advisable to adapt the names of the requirements
>> to
>> >     indicate the purpose. The numbering is more for the case that there
>> are
>> >     two or more requirements on the same topic (like on handling the
>> same
>> >     bad input argument).
>> >       my-function-0
>> >       my-function-1
>> >       my-function-global-side-effect
>> >       my-function-bad-argument-x-error-handling
>> >       my-function-bad-argument-y-error-handling
>> >       my-function-called-in-wrong-state
>> > This actually means there is a requirement for unnumbered names as well.
>> > Would it be better to explicitly define all requirements numbered and
>> > use -0, in case they should be extended later, or perhaps to start
>> > numbering without a number as 0 "implied" and numbers begin with 1?
>> If there is a -1 then I personally prefer that there should be a -0. For
>> the basedefs, I ended all requirements with -0 even if there was no -1.
>> Yet, whether this is the most wisest thing to do, I cannot say. I would
>> leave it to the author.
>> These numbers are mainly for requirements which need to be split:
>>   my-function.yml
>>     "The function shall return 7 and set global variable X to 5".
>> If later someone needs to split this, would renaming it be so much
>> trouble?
>> I don't know if renaming them would be a problem or not. Need an expert
> to weigh in on that.
> If renaming them introduces challenges, then we should explicitly use -0
> for the first requirement always, and not allow unnumbered ones to exist.
+1
I would be concerned that the unnumbered ones would be following a
different naming pattern which would make the requirements file matching
pattern harder.
>>   my-function-0.yml
>>     "The function shall return 7".
>>   my-function-1.yml
>>     "The function shall set global variable X to 5".
>> Could be as well:
>>   my-function-result.yml
>>   my-function-side-effect.yml
>> Greetings
>> Frank
>> >     My opinion is that defining whether we start counting with 0 or
>> with 1
>> >     makes sense. Everything else seems to me a bit like solving
>> theoretical
>> >     problems.
>> >     >     +    alias-00.yml
>> >     >     +    alias-01.yml
>> >     >     +    alias-02.yml
>> >     >     +    alias-09.yml
>> >     >     +    alias-10.yml
>> >     >     +    alias-11.yml
>> >     >      Conflict Free Requirements
>> >     >     2.26.2
>> >     >     _______________________________________________
>> >     >     devel mailing list
>> >     >     devel at rtems.org <mailto:devel at rtems.org>
>> >     <mailto:devel at rtems.org <mailto:devel at rtems.org>>
>> >     >     http://lists.rtems.org/mailman/listinfo/devel
>> >     <http://lists.rtems.org/mailman/listinfo/devel>
>> >     <http://lists.rtems.org/mailman/listinfo/devel>>
>> >     Greetings
>> >     Frank
>> >     devel mailing list
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201211/7308d151/attachment-0001.html>
