[PATCH v2] eng: Requirements counting shall start at zero
Mon Dec 14 06:31:08 UTC 2020
On 11/12/2020 17:43, Joel Sherrill wrote:
>     If renaming them introduces challenges, then we should explicitly
>     use -0 for the first requirement always, and not allow unnumbered
>     ones to exist.
> +1
> I would be concerned that the unnumbered ones would be following a
> different naming pattern which would make the requirements file matching
> pattern harder.
We should not make things more complicated than necessary. The goal is
to have descriptive names for the requirements. If a numbering makes
sense, then it should start with zero. If you need more than 10 numbers,
then using 00 is also acceptable, for example: /rtems/event/if/event-00.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
