Fwd: [rtems-bsp-builder] 2020-12-11 12:57:21: Profile(s): everything
Christian Mauderer oss at c-mauderer.de
Sun Dec 13 09:32:00 UTC 2020
Hello Joel,
that patch should most likely fix that problem:
https://lists.rtems.org/pipermail/devel/2020-December/063708.html
I haven't pushed it yet because I just posted it on Thursday and it was
only one day of review time on Friday. I'll push it on Monday (together
with some other pending patches).
Best regards
Christian
On 12/12/2020 17:24, Joel Sherrill wrote:
> Looks like the failures would mostly be explained by something is broken
> on the imx7 BSP and the SPE PowerPC bsps are still listed in the tier
> files for the tester.
> ---------- Forwarded message ---------
> From: <joel at rtems.org <mailto:joel at rtems.org>>
> Date: Sat, Dec 12, 2020, 9:49 AM
> Subject: [rtems-bsp-builder] 2020-12-11 12:57:21: Profile(s): everything
> To: <build at rtems.org <mailto:build at rtems.org>>
> RTEMS Tools Project - RTEMS Kernel BSP Builder, 6.0.not_released
> Host: #1 SMP Tue Aug 25 17:23:54 UTC 2020
> command: /home/joel/rtems-cron-6/tools/6/bin/rtems-bsp-builder\
>           --rtems=/home/joel/rtems-cron-6/rtems --build-path=/home/joel\
>           /rtems-cron-6/build --prefix=/home/joel/rtems-cron-6/tools/6/bsps\
>           --log=/home/joel/rtems-cron-6/bsp-builder.log --warnings-\
>           report=warnings.log --mail --mail-to=build at rtems.org
> <mailto:build at rtems.org> --mail-\
>           from=joel at rtems.org <mailto:joel at rtems.org> --profiles=everything
> Total Time            : 20:51:45.296683 for 1696 completed job(s)
> Average BSP Build Time: 0:00:44.283783
> Builds
>   debug
>   network
>   network-debug
>   no-network
>   no-posix
>   posix
>   posix-debug
>   posix-profiling
>   profiling
>   smp
>   smp-debug
>   smp-network
>   smp-network-debug
> Failures Report
>     1 debug arm/imx7 build:
>        configure: /home/joel/rtems-cron-6/rtems/configure --target=arm-\
>        rtems6 --enable-rtemsbsp=imx7 --prefix=/home/joel/rtems-\
>        cron-6/tools/6/bsps --enable-rtems-debug
>       error: bsps/arm/shared/pins/imx_iomux.c:69:10: fatal error:
>              arm/freescale/imx/imx_iomuxvar.h: No such file or directory
>     2 network arm/imx7 build:
>        cron-6/tools/6/bsps --enable-networking
>     3 network-debug arm/imx7 build:
>        cron-6/tools/6/bsps --enable-rtems-debug --enable-networking
>     4 no-network arm/imx7 build:
>        cron-6/tools/6/bsps --disable-networking
>     5 no-posix arm/imx7 build:
>        cron-6/tools/6/bsps --disable-posix
>     6 posix arm/imx7 build:
>        cron-6/tools/6/bsps --enable-posix
>     7 posix-debug arm/imx7 build:
>        cron-6/tools/6/bsps --enable-rtems-debug --enable-posix
>     8 posix-profiling arm/imx7 build:
>        cron-6/tools/6/bsps --enable-posix --enable-profiling
>     9 profiling arm/imx7 build:
>        cron-6/tools/6/bsps --enable-profiling
>    10 smp arm/imx7 build:
>        cron-6/tools/6/bsps --enable-smp
>    11 smp-debug arm/imx7 build:
>        cron-6/tools/6/bsps --enable-rtems-debug --enable-smp
>    12 smp-network arm/imx7 build:
>        cron-6/tools/6/bsps --enable-networking --enable-smp
>    13 smp-network-debug arm/imx7 build:
>        cron-6/tools/6/bsps --enable-rtems-debug --enable-networking\
>        --enable-smp
>    14 debug powerpc/brs5l configure:
>        configure: /home/joel/rtems-cron-6/rtems/configure --target=powerpc-\
>        rtems6 --enable-rtemsbsp=brs5l --prefix=/home/joel/rtems-\
>        cron-6/tools/6/bsps --enable-rtems-debug --disable-smp
>    15 network powerpc/brs5l configure:
>        cron-6/tools/6/bsps --enable-networking --disable-smp
>    16 network-debug powerpc/brs5l configure:
>        --disable-smp
>    17 no-network powerpc/brs5l configure:
>        cron-6/tools/6/bsps --disable-networking --disable-smp
>    18 no-posix powerpc/brs5l configure:
>        cron-6/tools/6/bsps --disable-posix --disable-smp
>    19 posix powerpc/brs5l configure:
>        cron-6/tools/6/bsps --enable-posix --disable-smp
>    20 posix-debug powerpc/brs5l configure:
>        cron-6/tools/6/bsps --enable-rtems-debug --enable-posix --disable-\
>        smp
>    21 posix-profiling powerpc/brs5l configure:
>        cron-6/tools/6/bsps --enable-posix --enable-profiling --disable-smp
>    22 profiling powerpc/brs5l configure:
>        cron-6/tools/6/bsps --enable-profiling --disable-smp
>    23 debug powerpc/brs6l configure:
>        rtems6 --enable-rtemsbsp=brs6l --prefix=/home/joel/rtems-\
>    24 network powerpc/brs6l configure:
>    25 network-debug powerpc/brs6l configure:
>        --disable-smp
>    26 no-network powerpc/brs6l configure:
>    27 no-posix powerpc/brs6l configure:
>    28 posix powerpc/brs6l configure:
>    29 posix-debug powerpc/brs6l configure:
>        smp
>    30 posix-profiling powerpc/brs6l configure:
>    31 profiling powerpc/brs6l configure:
>    32 debug powerpc/dp2 configure:
>        rtems6 --enable-rtemsbsp=dp2 --prefix=/home/joel/rtems-\
>    33 network powerpc/dp2 configure:
>    34 network-debug powerpc/dp2 configure:
>        --disable-smp
>    35 no-network powerpc/dp2 configure:
>    36 no-posix powerpc/dp2 configure:
>    37 posix powerpc/dp2 configure:
>    38 posix-debug powerpc/dp2 configure:
>        smp
>    39 posix-profiling powerpc/dp2 configure:
>    40 profiling powerpc/dp2 configure:
>    41 debug powerpc/mpc5566evb_spe configure:
>        rtems6 --enable-rtemsbsp=mpc5566evb_spe --prefix=/home/joel/rtems-\
>    42 network powerpc/mpc5566evb_spe configure:
>    43 network-debug powerpc/mpc5566evb_spe configure:
>        --disable-smp
>    44 no-network powerpc/mpc5566evb_spe configure:
>    45 no-posix powerpc/mpc5566evb_spe configure:
>    46 posix powerpc/mpc5566evb_spe configure:
>    47 posix-debug powerpc/mpc5566evb_spe configure:
>        smp
>    48 posix-profiling powerpc/mpc5566evb_spe configure:
>    49 profiling powerpc/mpc5566evb_spe configure:
>    50 debug powerpc/mpc5643l_dpu configure:
>        rtems6 --enable-rtemsbsp=mpc5643l_dpu --prefix=/home/joel/rtems-\
>    51 network powerpc/mpc5643l_dpu configure:
>    52 network-debug powerpc/mpc5643l_dpu configure:
>        --disable-smp
>    53 no-network powerpc/mpc5643l_dpu configure:
>    54 no-posix powerpc/mpc5643l_dpu configure:
>    55 posix powerpc/mpc5643l_dpu configure:
>    56 posix-debug powerpc/mpc5643l_dpu configure:
>        smp
>    57 posix-profiling powerpc/mpc5643l_dpu configure:
>    58 profiling powerpc/mpc5643l_dpu configure:
>    59 debug powerpc/mpc5674f_ecu508_app configure:
>        rtems6 --enable-rtemsbsp=mpc5674f_ecu508_app --prefix=/home/joel\
>        /rtems-cron-6/tools/6/bsps --enable-rtems-debug --disable-smp
>    60 network powerpc/mpc5674f_ecu508_app configure:
>        /rtems-cron-6/tools/6/bsps --enable-networking --disable-smp
>    61 network-debug powerpc/mpc5674f_ecu508_app configure:
>        /rtems-cron-6/tools/6/bsps --enable-rtems-debug --enable-networking\
>        --disable-smp
>    62 no-network powerpc/mpc5674f_ecu508_app configure:
>        /rtems-cron-6/tools/6/bsps --disable-networking --disable-smp
>    63 no-posix powerpc/mpc5674f_ecu508_app configure:
>        /rtems-cron-6/tools/6/bsps --disable-posix --disable-smp
>    64 posix powerpc/mpc5674f_ecu508_app configure:
>        /rtems-cron-6/tools/6/bsps --enable-posix --disable-smp
>    65 posix-debug powerpc/mpc5674f_ecu508_app configure:
>        /rtems-cron-6/tools/6/bsps --enable-rtems-debug --enable-posix\
>        --disable-smp
>    66 posix-profiling powerpc/mpc5674f_ecu508_app configure:
>        /rtems-cron-6/tools/6/bsps --enable-posix --enable-profiling\
>        --disable-smp
>    67 profiling powerpc/mpc5674f_ecu508_app configure:
>        /rtems-cron-6/tools/6/bsps --enable-profiling --disable-smp
>    68 debug powerpc/mpc5674f_ecu508_boot configure:
>        rtems6 --enable-rtemsbsp=mpc5674f_ecu508_boot --prefix=/home/joel\
>    69 network powerpc/mpc5674f_ecu508_boot configure:
>    70 network-debug powerpc/mpc5674f_ecu508_boot configure:
>        --disable-smp
>    71 no-network powerpc/mpc5674f_ecu508_boot configure:
>    72 no-posix powerpc/mpc5674f_ecu508_boot configure:
>    73 posix powerpc/mpc5674f_ecu508_boot configure:
>    74 posix-debug powerpc/mpc5674f_ecu508_boot configure:
>        --disable-smp
>    75 posix-profiling powerpc/mpc5674f_ecu508_boot configure:
>        --disable-smp
>    76 profiling powerpc/mpc5674f_ecu508_boot configure:
>    77 debug powerpc/mpc5674f_rsm6 configure:
>        rtems6 --enable-rtemsbsp=mpc5674f_rsm6 --prefix=/home/joel/rtems-\
>    78 network powerpc/mpc5674f_rsm6 configure:
>    79 network-debug powerpc/mpc5674f_rsm6 configure:
>        --disable-smp
>    80 no-network powerpc/mpc5674f_rsm6 configure:
>    81 no-posix powerpc/mpc5674f_rsm6 configure:
>    82 posix powerpc/mpc5674f_rsm6 configure:
>    83 posix-debug powerpc/mpc5674f_rsm6 configure:
>        smp
>    84 posix-profiling powerpc/mpc5674f_rsm6 configure:
>    85 profiling powerpc/mpc5674f_rsm6 configure:
>    86 debug powerpc/mpc5674fevb_spe configure:
>        rtems6 --enable-rtemsbsp=mpc5674fevb_spe --prefix=/home/joel/rtems-\
>    87 network powerpc/mpc5674fevb_spe configure:
>    88 network-debug powerpc/mpc5674fevb_spe configure:
>        --disable-smp
>    89 no-network powerpc/mpc5674fevb_spe configure:
>    90 no-posix powerpc/mpc5674fevb_spe configure:
>    91 posix powerpc/mpc5674fevb_spe configure:
>    92 posix-debug powerpc/mpc5674fevb_spe configure:
>        smp
>    93 posix-profiling powerpc/mpc5674fevb_spe configure:
>    94 profiling powerpc/mpc5674fevb_spe configure:
> Warnings Report
>   | By Architecture (total : 91686)                                     |
>   | common : 107 warning(s)                                             |
>   |   Shared : 8832 |     BSP :    0 |Network : 26136 |    Tests :    0 |
>   |   LibCPU :    0 | CPU Kit : 4269 |                |                 |
>   | arm : 60 warning(s)                                                 |
>   |   Shared : 1196 |     BSP :    0 |Network : 17212 |    Tests :    0 |
>   |   LibCPU :    0 | CPU Kit : 1294 |                |                 |
>   | bfin : 28 warning(s)                                                |
>   |   Shared :   27 |     BSP :    0 | Network : 1032 |    Tests :    0 |
>   |   LibCPU :  351 | CPU Kit :  126 |                |                 |
>   | i386 : 30 warning(s)                                                |
>   |   Shared :  288 |     BSP :    0 | Network : 2000 |    Tests :    0 |
>   |   LibCPU :    0 | CPU Kit :  522 |                |                 |
>   | lm32 : 14 warning(s)                                                |
>   |   Shared :  210 |     BSP :    0 | Network :  792 |    Tests :    0 |
>   |   LibCPU :    0 | CPU Kit :   78 |                |                 |
>   | m68k : 155 warning(s)                                               |
>   |   Shared :  180 |     BSP :    0 | Network : 6784 |    Tests :    0 |
>   |   LibCPU :    0 | CPU Kit : 1688 |                |                 |
>   | mips : 8 warning(s)                                                 |
>   |   Shared :    0 |     BSP :    0 | Network : 1952 |    Tests :    0 |
>   |   LibCPU :    0 | CPU Kit :  120 |                |                 |
>   | moxie : 1 warning(s)                                                |
>   |   Shared :    0 |     BSP :    0 | Network :  248 |    Tests :    0 |
>   |   LibCPU :    0 | CPU Kit :   89 |                |                 |
>   | or1k : 3 warning(s)                                                 |
>   |   Shared :    9 |     BSP :    0 | Network :  232 |    Tests :    0 |
>   |   LibCPU :    0 | CPU Kit :    0 |                |                 |
>   | powerpc : 130 warning(s)                                            |
>   |   Shared : 3988 |     BSP :    0 |Network : 14172 |    Tests :    0 |
>   |   LibCPU :    0 | CPU Kit : 1234 |                |                 |
>   | riscv : 7 warning(s)                                                |
>   |   Shared : 2728 |     BSP :    0 | Network : 6772 |    Tests :    0 |
>   |   LibCPU :    0 | CPU Kit : 2258 |                |                 |
>   | sh : 160 warning(s)                                                 |
>   |   Shared :    0 |     BSP :    0 | Network : 2408 |    Tests :    0 |
>   |   LibCPU :    0 | CPU Kit :  168 |                |                 |
>   | sparc : 2 warning(s)                                                |
>   |   Shared : 1240 |     BSP :    0 | Network : 3480 |    Tests :    0 |
>   |   LibCPU :    0 | CPU Kit :  252 |                |                 |
>   | sparc64 : 2 warning(s)                                              |
>   |   Shared :   18 |     BSP :    0 | Network :  672 |    Tests :    0 |
>   |   LibCPU :    0 | CPU Kit :   84 |                |                 |
>   | v850 : 0 warning(s)                                                 |
>   | By BSP (total : 91686)                                              |
>   | common : 412 warning(s)                                             |
>   |   Shared : 9064 |     BSP :    0 |Network : 55364 |    Tests :    0 |
>   |   LibCPU :  144 | CPU Kit : 7435 |                |                 |
>   | arm/altcycv_devkit : 0 warning(s)                                   |
>   | arm/atsamv : 45 warning(s)                                          |
>   |   Shared :    0 |     BSP :    0 | Network :  328 |    Tests :    0 |
>   |   LibCPU :    0 | CPU Kit :   24 |                |                 |
>   | arm/beagleboardorig : 0 warning(s)                                  |
>   | arm/beagleboardxm : 0 warning(s)                                    |
>   | arm/beagleboneblack : 0 warning(s)                                  |
>   | arm/beaglebonewhite : 0 warning(s)                                  |
>   | arm/csb336 : 3 warning(s)                                           |
>   |   Shared :    9 |     BSP :    0 | Network :  328 |    Tests :    0 |
>   | arm/csb337 : 0 warning(s)                                           |
>   | arm/csb637 : 0 warning(s)                                           |
>   | arm/edb7312 : 0 warning(s)                                          |
>   | arm/gumstix : 0 warning(s)                                          |
>   | arm/imx7 : 0 warning(s)                                             |
>   | arm/kit637_v6 : 0 warning(s)                                        |
>   | arm/lm3s3749 : 0 warning(s)                                         |
>   | arm/lm3s6965 : 0 warning(s)                                         |
>   | arm/lm3s6965_qemu : 0 warning(s)                                    |
>   | arm/lm4f120 : 0 warning(s)                                          |
>   | arm/lpc1768_mbed : 0 warning(s)                                     |
>   | arm/lpc1768_mbed_ahb_ram : 0 warning(s)                             |
>   | arm/lpc1768_mbed_ahb_ram_eth : 0 warning(s)                         |
>   | arm/lpc17xx_ea_ram : 0 warning(s)                                   |
>   | arm/lpc17xx_ea_rom_int : 0 warning(s)                               |
>   | arm/lpc17xx_plx800_ram : 0 warning(s)                               |
>   | arm/lpc17xx_plx800_rom_int : 0 warning(s)                           |
>   | arm/lpc2362 : 0 warning(s)                                          |
>   | arm/lpc23xx_tli800 : 0 warning(s)                                   |
>   | arm/lpc24xx_ea : 0 warning(s)                                       |
>   | arm/lpc24xx_ncs_ram : 0 warning(s)                                  |
>   | arm/lpc24xx_ncs_rom_ext : 0 warning(s)                              |
>   | arm/lpc24xx_ncs_rom_int : 0 warning(s)                              |
>   | arm/lpc24xx_plx800_ram : 0 warning(s)                               |
>   | arm/lpc24xx_plx800_rom_int : 0 warning(s)                           |
>   | arm/lpc32xx_mzx : 0 warning(s)                                      |
>   | arm/lpc32xx_mzx_stage_1 : 0 warning(s)                              |
>   | arm/lpc32xx_mzx_stage_2 : 0 warning(s)                              |
>   | arm/lpc32xx_phycore : 0 warning(s)                                  |
>   | arm/lpc40xx_ea_ram : 0 warning(s)                                   |
>   | arm/lpc40xx_ea_rom_int : 0 warning(s)                               |
>   | arm/raspberrypi : 0 warning(s)                                      |
>   | arm/raspberrypi2 : 0 warning(s)                                     |
>   | arm/realview_pbx_a9_qemu : 0 warning(s)                             |
>   | arm/rtl22xx : 0 warning(s)                                          |
>   | arm/rtl22xx_t : 0 warning(s)                                        |
>   | arm/smdk2410 : 0 warning(s)                                         |
>   | arm/stm32f105rc : 0 warning(s)                                      |
>   | arm/stm32f4 : 2 warning(s)                                          |
>   |   Shared :    0 |     BSP :    0 | Network :  344 |    Tests :    0 |
>   | arm/tms570ls3137_hdk : 0 warning(s)                                 |
>   | arm/tms570ls3137_hdk_intram : 0 warning(s)                          |
>   | arm/tms570ls3137_hdk_sdram : 0 warning(s)                           |
>   | arm/tms570ls3137_hdk_with_loader : 0 warning(s)                     |
>   | arm/xilinx_zynq_a9_qemu : 0 warning(s)                              |
>   | arm/xilinx_zynq_zc702 : 0 warning(s)                                |
>   | arm/xilinx_zynq_zc706 : 0 warning(s)                                |
>   | arm/xilinx_zynq_zedboard : 0 warning(s)                             |
>   | bfin/TLL6527M : 10 warning(s)                                       |
>   |   Shared :    9 |     BSP :    0 | Network :  344 |    Tests :    0 |
>   |   LibCPU :  207 | CPU Kit :   42 |                |                 |
>   | bfin/bf537Stamp : 0 warning(s)                                      |
>   | bfin/eZKit533 : 0 warning(s)                                        |
>   | i386/pc386 : 0 warning(s)                                           |
>   | i386/pc486 : 0 warning(s)                                           |
>   | i386/pc586 : 0 warning(s)                                           |
>   | i386/pc586-sse : 0 warning(s)                                       |
>   | i386/pc686 : 0 warning(s)                                           |
>   | i386/pcp4 : 0 warning(s)                                            |
>   | lm32/lm32_evr : 0 warning(s)                                        |
>   | lm32/lm32_evr_gdbsim : 0 warning(s)                                 |
>   | lm32/milkymist : 0 warning(s)                                       |
>   | m68k/COBRA5475 : 0 warning(s)                                       |
>   | m68k/av5282 : 65 warning(s)                                         |
>   |   LibCPU :    0 | CPU Kit :   87 |                |                 |
>   | m68k/csb360 : 0 warning(s)                                          |
>   | m68k/gen68340 : 0 warning(s)                                        |
>   | m68k/gen68360 : 0 warning(s)                                        |
>   | m68k/gen68360_040 : 0 warning(s)                                    |
>   | m68k/m5484FireEngine : 0 warning(s)                                 |
>   | m68k/mcf5206elite : 0 warning(s)                                    |
>   | m68k/mcf52235 : 1 warning(s)                                        |
>   | m68k/mcf5225x : 1 warning(s)                                        |
>   | m68k/mcf5235 : 2 warning(s)                                         |
>   | m68k/mcf5329 : 4 warning(s)                                         |
>   | m68k/mrm332 : 0 warning(s)                                          |
>   | m68k/mvme147 : 0 warning(s)                                         |
>   | m68k/mvme147s : 0 warning(s)                                        |
>   | m68k/mvme162 : 0 warning(s)                                         |
>   | m68k/mvme162lx : 0 warning(s)                                       |
>   | m68k/mvme167 : 1 warning(s)                                         |
>   | m68k/pgh360 : 0 warning(s)                                          |
>   | m68k/uC5282 : 67 warning(s)                                         |
>   | mips/csb350 : 1 warning(s)                                          |
>   | mips/hurricane : 0 warning(s)                                       |
>   | mips/jmr3904 : 0 warning(s)                                         |
>   | mips/malta : 6 warning(s)                                           |
>   |   Shared :    0 |     BSP :    0 | Network :  232 |    Tests :    0 |
>   | mips/rbtx4925 : 0 warning(s)                                        |
>   | mips/rbtx4938 : 1 warning(s)                                        |
>   | moxie/moxiesim : 1 warning(s)                                       |
>   | or1k/generic_or1k : 3 warning(s)                                    |
>   | powerpc/beatnik : 0 warning(s)                                      |
>   | powerpc/br_uid : 0 warning(s)                                       |
>   | powerpc/gwlcfm : 0 warning(s)                                       |
>   | powerpc/haleakala : 16 warning(s)                                   |
>   |   LibCPU :    0 | CPU Kit :   26 |                |                 |
>   | powerpc/hsc_cm01 : 0 warning(s)                                     |
>   | powerpc/icecube : 0 warning(s)                                      |
>   | powerpc/mcp750 : 0 warning(s)                                       |
>   | powerpc/mpc5566evb : 0 warning(s)                                   |
>   | powerpc/mpc5643l_evb : 0 warning(s)                                 |
>   | powerpc/mpc5668g : 0 warning(s)                                     |
>   | powerpc/mpc5674fevb : 0 warning(s)                                  |
>   | powerpc/mpc8260ads : 6 warning(s)                                   |
>   |   Shared :    0 |     BSP :    0 | Network :  352 |    Tests :    0 |
>   | powerpc/mpc8309som : 0 warning(s)                                   |
>   | powerpc/mpc8313erdb : 0 warning(s)                                  |
>   | powerpc/mpc8349eamds : 0 warning(s)                                 |
>   | powerpc/mtx603e : 0 warning(s)                                      |
>   | powerpc/mvme2100 : 0 warning(s)                                     |
>   | powerpc/mvme2307 : 0 warning(s)                                     |
>   | powerpc/mvme3100 : 3 warning(s)                                     |
>   |   Shared :  217 |     BSP :    0 | Network :  352 |    Tests :    0 |
>   | powerpc/mvme5500 : 20 warning(s)                                    |
>   |   Shared :  226 |     BSP :    0 | Network :  360 |    Tests :    0 |
>   | powerpc/pghplus : 1 warning(s)                                      |
>   | powerpc/phycore_mpc5554 : 1 warning(s)                              |
>   | powerpc/pm520_cr825 : 0 warning(s)                                  |
>   | powerpc/pm520_ze30 : 0 warning(s)                                   |
>   | powerpc/psim : 1 warning(s)                                         |
>   | powerpc/qemuppc : 1 warning(s)                                      |
>   | powerpc/qemuprep : 0 warning(s)                                     |
>   | powerpc/qemuprep-altivec : 0 warning(s)                             |
>   | powerpc/qoriq_core_0 : 0 warning(s)                                 |
>   | powerpc/qoriq_core_1 : 0 warning(s)                                 |
>   | powerpc/qoriq_e500 : 0 warning(s)                                   |
>   | powerpc/qoriq_e6500_32 : 0 warning(s)                               |
>   | powerpc/qoriq_e6500_64 : 14 warning(s)                              |
>   |   Shared :  521 |     BSP :    0 | Network :  612 |    Tests :    0 |
>   |   LibCPU :    0 | CPU Kit :  231 |                |                 |
>   | powerpc/ss555 : 0 warning(s)                                        |
>   | powerpc/t32mppc : 2 warning(s)                                      |
>   |   LibCPU :    0 | CPU Kit :   35 |                |                 |
>   | powerpc/tqm8xx_stk8xx : 1 warning(s)                                |
>   | powerpc/virtex : 12 warning(s)                                      |
>   | powerpc/virtex4 : 0 warning(s)                                      |
>   | powerpc/virtex5 : 0 warning(s)                                      |
>   | riscv/rv32i : 0 warning(s)                                          |
>   | riscv/rv32iac : 0 warning(s)                                        |
>   | riscv/rv32im : 0 warning(s)                                         |
>   | riscv/rv32imac : 0 warning(s)                                       |
>   | riscv/rv32imafc : 0 warning(s)                                      |
>   | riscv/rv32imafd : 0 warning(s)                                      |
>   | riscv/rv32imafdc : 0 warning(s)                                     |
>   | riscv/rv64imac : 0 warning(s)                                       |
>   | riscv/rv64imac_medany : 0 warning(s)                                |
>   | riscv/rv64imafd : 0 warning(s)                                      |
>   | riscv/rv64imafd_medany : 0 warning(s)                               |
>   | riscv/rv64imafdc : 0 warning(s)                                     |
>   | riscv/rv64imafdc_medany : 0 warning(s)                              |
>   | sh/gensh1 : 1 warning(s)                                            |
>   | sh/gensh2 : 1 warning(s)                                            |
>   | sh/gensh4 : 1 warning(s)                                            |
>   | sh/simsh1 : 0 warning(s)                                            |
>   | sh/simsh2 : 0 warning(s)                                            |
>   | sh/simsh2e : 0 warning(s)                                           |
>   | sh/simsh4 : 0 warning(s)                                            |
>   | sparc/at697f : 0 warning(s)                                         |
>   | sparc/erc32 : 0 warning(s)                                          |
>   | sparc/gr712rc : 0 warning(s)                                        |
>   | sparc/gr740 : 0 warning(s)                                          |
>   | sparc/leon2 : 0 warning(s)                                          |
>   | sparc/leon3 : 0 warning(s)                                          |
>   | sparc/ut699 : 0 warning(s)                                          |
>   | sparc/ut700 : 0 warning(s)                                          |
>   | sparc64/niagara : 0 warning(s)                                      |
>   | sparc64/usiii : 1 warning(s)                                        |
>   |   Shared :    9 |     BSP :    0 | Network :  336 |    Tests :    0 |
>   |   LibCPU :    0 | CPU Kit :   42 |                |                 |
>   | v850/v850e1sim : 0 warning(s)                                       |
>   | v850/v850e2sim : 0 warning(s)                                       |
>   | v850/v850e2v3sim : 0 warning(s)                                     |
>   | v850/v850esim : 0 warning(s)                                        |
>   | v850/v850essim : 0 warning(s)                                       |
>   | v850/v850sim : 0 warning(s)                                         |
>   | By Build (total : 91686)                                            |
>   | common : 707 warning(s)                                             |
>   |   Shared : 8178 |     BSP :    0 |Network : 76150 |    Tests :    0 |
>   |   LibCPU :  312 | CPU Kit : 9452 |                |                 |
>   | debug : 0 warning(s)                                                |
>   | network : 0 warning(s)                                              |
>   | network-debug : 0 warning(s)                                        |
>   | no-network : 0 warning(s)                                           |
>   | no-posix : 0 warning(s)                                             |
>   | posix : 0 warning(s)                                                |
>   | posix-debug : 0 warning(s)                                          |
>   | posix-profiling : 0 warning(s)                                      |
>   | profiling : 0 warning(s)                                            |
>   | smp : 0 warning(s)                                                  |
>   | smp-debug : 0 warning(s)                                            |
>   | smp-network : 0 warning(s)                                          |
>   | smp-network-debug : 0 warning(s)                                    |
> build mailing list
> http://lists.rtems.org/mailman/listinfo/build
> <http://lists.rtems.org/mailman/listinfo/build>
> devel mailing list
> devel at rtems.org
