Fwd: [rtems-bsp-builder] 2020-12-11 12:57:21: Profile(s): everything
Mon Dec 14 14:23:43 UTC 2020
On Sun, Dec 13, 2020 at 3:32 AM Christian Mauderer <oss at c-mauderer.de>
wrote:
> Hello Joel,
> that patch should most likely fix that problem:
Great!
> https://lists.rtems.org/pipermail/devel/2020-December/063708.html
> I haven't pushed it yet because I just posted it on Thursday and it was
> only one day of review time on Friday. I'll push it on Monday (together
> with some other pending patches).
OK. I'll start another sweep when this goes in.
FWIW I try to do at least one build sweep a month and post reports of
failures when the set of issues changes. It is just easy for something to
slip in. Easy enough to let the computers churn a few days.
--joel
> Best regards
> Christian
> On 12/12/2020 17:24, Joel Sherrill wrote:
> > Looks like the failures would mostly be explained by something is broken
> > on the imx7 BSP and the SPE PowerPC bsps are still listed in the tier
> > files for the tester.
> > ---------- Forwarded message ---------
> > From: <joel at rtems.org <mailto:joel at rtems.org>>
> > Date: Sat, Dec 12, 2020, 9:49 AM
> > Subject: [rtems-bsp-builder] 2020-12-11 12:57:21: Profile(s): everything
> > To: <build at rtems.org <mailto:build at rtems.org>>
> > RTEMS Tools Project - RTEMS Kernel BSP Builder, 6.0.not_released
> > Host: #1 SMP Tue Aug 25 17:23:54 UTC 2020
> > command: /home/joel/rtems-cron-6/tools/6/bin/rtems-bsp-builder\
> >           --rtems=/home/joel/rtems-cron-6/rtems --build-path=/home/joel\
> >           /rtems-cron-6/build
> --prefix=/home/joel/rtems-cron-6/tools/6/bsps\
> >           --log=/home/joel/rtems-cron-6/bsp-builder.log --warnings-\
> >           report=warnings.log --mail --mail-to=build at rtems.org
> > <mailto:build at rtems.org> --mail-\
> >           from=joel at rtems.org <mailto:joel at rtems.org>
> --profiles=everything
> > Total Time            : 20:51:45.296683 for 1696 completed job(s)
> > Average BSP Build Time: 0:00:44.283783
> > Builds
> >   debug
> >   network
> >   network-debug
> >   no-network
> >   no-posix
> >   posix
> >   posix-debug
> >   posix-profiling
> >   profiling
> >   smp
> >   smp-debug
> >   smp-network
> >   smp-network-debug
> > Failures Report
> >     1 debug arm/imx7 build:
> >        configure: /home/joel/rtems-cron-6/rtems/configure --target=arm-\
> >        rtems6 --enable-rtemsbsp=imx7 --prefix=/home/joel/rtems-\
> >        cron-6/tools/6/bsps --enable-rtems-debug
> >       error: bsps/arm/shared/pins/imx_iomux.c:69:10: fatal error:
> >              arm/freescale/imx/imx_iomuxvar.h: No such file or directory
> >     2 network arm/imx7 build:
> >        cron-6/tools/6/bsps --enable-networking
> >     3 network-debug arm/imx7 build:
> >        cron-6/tools/6/bsps --enable-rtems-debug --enable-networking
> >     4 no-network arm/imx7 build:
> >        cron-6/tools/6/bsps --disable-networking
> >     5 no-posix arm/imx7 build:
> >        cron-6/tools/6/bsps --disable-posix
> >     6 posix arm/imx7 build:
> >        cron-6/tools/6/bsps --enable-posix
> >     7 posix-debug arm/imx7 build:
> >        cron-6/tools/6/bsps --enable-rtems-debug --enable-posix
> >     8 posix-profiling arm/imx7 build:
> >        cron-6/tools/6/bsps --enable-posix --enable-profiling
> >     9 profiling arm/imx7 build:
> >        cron-6/tools/6/bsps --enable-profiling
> >    10 smp arm/imx7 build:
> >        cron-6/tools/6/bsps --enable-smp
> >    11 smp-debug arm/imx7 build:
> >        cron-6/tools/6/bsps --enable-rtems-debug --enable-smp
> >    12 smp-network arm/imx7 build:
> >        cron-6/tools/6/bsps --enable-networking --enable-smp
> >    13 smp-network-debug arm/imx7 build:
> >        cron-6/tools/6/bsps --enable-rtems-debug --enable-networking\
> >        --enable-smp
> >    14 debug powerpc/brs5l configure:
> --target=powerpc-\
> >        rtems6 --enable-rtemsbsp=brs5l --prefix=/home/joel/rtems-\
> >        cron-6/tools/6/bsps --enable-rtems-debug --disable-smp
> >    15 network powerpc/brs5l configure:
> --target=powerpc-\
> >        cron-6/tools/6/bsps --enable-networking --disable-smp
> >    16 network-debug powerpc/brs5l configure:
> --target=powerpc-\
> >        --disable-smp
> >    17 no-network powerpc/brs5l configure:
> --target=powerpc-\
> >        cron-6/tools/6/bsps --disable-networking --disable-smp
> >    18 no-posix powerpc/brs5l configure:
> --target=powerpc-\
> >        cron-6/tools/6/bsps --disable-posix --disable-smp
> >    19 posix powerpc/brs5l configure:
> --target=powerpc-\
> >        cron-6/tools/6/bsps --enable-posix --disable-smp
> >    20 posix-debug powerpc/brs5l configure:
> --target=powerpc-\
> --disable-\
> >        smp
> >    21 posix-profiling powerpc/brs5l configure:
> --target=powerpc-\
> --disable-smp
> >    22 profiling powerpc/brs5l configure:
> --target=powerpc-\
> >        cron-6/tools/6/bsps --enable-profiling --disable-smp
> >    23 debug powerpc/brs6l configure:
> --target=powerpc-\
> >        rtems6 --enable-rtemsbsp=brs6l --prefix=/home/joel/rtems-\
> >    24 network powerpc/brs6l configure:
> --target=powerpc-\
> >    25 network-debug powerpc/brs6l configure:
> --target=powerpc-\
> >        --disable-smp
> >    26 no-network powerpc/brs6l configure:
> --target=powerpc-\
> >    27 no-posix powerpc/brs6l configure:
> --target=powerpc-\
> >    28 posix powerpc/brs6l configure:
> --target=powerpc-\
> >    29 posix-debug powerpc/brs6l configure:
> --target=powerpc-\
> --disable-\
> >        smp
> >    30 posix-profiling powerpc/brs6l configure:
> --target=powerpc-\
> --disable-smp
> >    31 profiling powerpc/brs6l configure:
> --target=powerpc-\
> >    32 debug powerpc/dp2 configure:
> --target=powerpc-\
> >        rtems6 --enable-rtemsbsp=dp2 --prefix=/home/joel/rtems-\
> >    33 network powerpc/dp2 configure:
> --target=powerpc-\
> >    34 network-debug powerpc/dp2 configure:
> --target=powerpc-\
> >        --disable-smp
> >    35 no-network powerpc/dp2 configure:
> --target=powerpc-\
> >    36 no-posix powerpc/dp2 configure:
> --target=powerpc-\
> >    37 posix powerpc/dp2 configure:
> --target=powerpc-\
> >    38 posix-debug powerpc/dp2 configure:
> --target=powerpc-\
> --disable-\
> >        smp
> >    39 posix-profiling powerpc/dp2 configure:
> --target=powerpc-\
> --disable-smp
> >    40 profiling powerpc/dp2 configure:
> --target=powerpc-\
> >    41 debug powerpc/mpc5566evb_spe configure:
> --target=powerpc-\
> >        rtems6 --enable-rtemsbsp=mpc5566evb_spe
> >    42 network powerpc/mpc5566evb_spe configure:
> --target=powerpc-\
> >    43 network-debug powerpc/mpc5566evb_spe configure:
> --target=powerpc-\
> >        --disable-smp
> >    44 no-network powerpc/mpc5566evb_spe configure:
> --target=powerpc-\
> >    45 no-posix powerpc/mpc5566evb_spe configure:
> --target=powerpc-\
> >    46 posix powerpc/mpc5566evb_spe configure:
> --target=powerpc-\
> >    47 posix-debug powerpc/mpc5566evb_spe configure:
> --target=powerpc-\
> --disable-\
> >        smp
> >    48 posix-profiling powerpc/mpc5566evb_spe configure:
> --target=powerpc-\
> --disable-smp
> >    49 profiling powerpc/mpc5566evb_spe configure:
> --target=powerpc-\
> >    50 debug powerpc/mpc5643l_dpu configure:
> --target=powerpc-\
> >        rtems6 --enable-rtemsbsp=mpc5643l_dpu --prefix=/home/joel/rtems-\
> >    51 network powerpc/mpc5643l_dpu configure:
> --target=powerpc-\
> >    52 network-debug powerpc/mpc5643l_dpu configure:
> --target=powerpc-\
> >        --disable-smp
> >    53 no-network powerpc/mpc5643l_dpu configure:
> --target=powerpc-\
> >    54 no-posix powerpc/mpc5643l_dpu configure:
> --target=powerpc-\
> >    55 posix powerpc/mpc5643l_dpu configure:
> --target=powerpc-\
> >    56 posix-debug powerpc/mpc5643l_dpu configure:
> --target=powerpc-\
> --disable-\
> >        smp
> >    57 posix-profiling powerpc/mpc5643l_dpu configure:
> --target=powerpc-\
> --disable-smp
> >    58 profiling powerpc/mpc5643l_dpu configure:
> --target=powerpc-\
> >    59 debug powerpc/mpc5674f_ecu508_app configure:
> --target=powerpc-\
> >        rtems6 --enable-rtemsbsp=mpc5674f_ecu508_app --prefix=/home/joel\
> >        /rtems-cron-6/tools/6/bsps --enable-rtems-debug --disable-smp
> >    60 network powerpc/mpc5674f_ecu508_app configure:
> --target=powerpc-\
> >        /rtems-cron-6/tools/6/bsps --enable-networking --disable-smp
> >    61 network-debug powerpc/mpc5674f_ecu508_app configure:
> --target=powerpc-\
> >        --disable-smp
> >    62 no-network powerpc/mpc5674f_ecu508_app configure:
> --target=powerpc-\
> >        /rtems-cron-6/tools/6/bsps --disable-networking --disable-smp
> >    63 no-posix powerpc/mpc5674f_ecu508_app configure:
> --target=powerpc-\
> >        /rtems-cron-6/tools/6/bsps --disable-posix --disable-smp
> >    64 posix powerpc/mpc5674f_ecu508_app configure:
> --target=powerpc-\
> >        /rtems-cron-6/tools/6/bsps --enable-posix --disable-smp
> >    65 posix-debug powerpc/mpc5674f_ecu508_app configure:
> --target=powerpc-\
> >        /rtems-cron-6/tools/6/bsps --enable-rtems-debug --enable-posix\
> >        --disable-smp
> >    66 posix-profiling powerpc/mpc5674f_ecu508_app configure:
> --target=powerpc-\
> >        /rtems-cron-6/tools/6/bsps --enable-posix --enable-profiling\
> >        --disable-smp
> >    67 profiling powerpc/mpc5674f_ecu508_app configure:
> --target=powerpc-\
> >        /rtems-cron-6/tools/6/bsps --enable-profiling --disable-smp
> >    68 debug powerpc/mpc5674f_ecu508_boot configure:
> --target=powerpc-\
> >        rtems6 --enable-rtemsbsp=mpc5674f_ecu508_boot --prefix=/home/joel\
> >    69 network powerpc/mpc5674f_ecu508_boot configure:
> --target=powerpc-\
> >    70 network-debug powerpc/mpc5674f_ecu508_boot configure:
> --target=powerpc-\
> >        --disable-smp
> >    71 no-network powerpc/mpc5674f_ecu508_boot configure:
> --target=powerpc-\
> >    72 no-posix powerpc/mpc5674f_ecu508_boot configure:
> --target=powerpc-\
> >    73 posix powerpc/mpc5674f_ecu508_boot configure:
> --target=powerpc-\
> >    74 posix-debug powerpc/mpc5674f_ecu508_boot configure:
> --target=powerpc-\
> >        --disable-smp
> >    75 posix-profiling powerpc/mpc5674f_ecu508_boot configure:
> --target=powerpc-\
> >        --disable-smp
> >    76 profiling powerpc/mpc5674f_ecu508_boot configure:
> --target=powerpc-\
> >    77 debug powerpc/mpc5674f_rsm6 configure:
> --target=powerpc-\
> >        rtems6 --enable-rtemsbsp=mpc5674f_rsm6 --prefix=/home/joel/rtems-\
> >    78 network powerpc/mpc5674f_rsm6 configure:
> --target=powerpc-\
> >    79 network-debug powerpc/mpc5674f_rsm6 configure:
> --target=powerpc-\
> >        --disable-smp
> >    80 no-network powerpc/mpc5674f_rsm6 configure:
> --target=powerpc-\
> >    81 no-posix powerpc/mpc5674f_rsm6 configure:
> --target=powerpc-\
> >    82 posix powerpc/mpc5674f_rsm6 configure:
> --target=powerpc-\
> >    83 posix-debug powerpc/mpc5674f_rsm6 configure:
> --target=powerpc-\
> --disable-\
> >        smp
> >    84 posix-profiling powerpc/mpc5674f_rsm6 configure:
> --target=powerpc-\
> --disable-smp
> >    85 profiling powerpc/mpc5674f_rsm6 configure:
> --target=powerpc-\
> >    86 debug powerpc/mpc5674fevb_spe configure:
> --target=powerpc-\
> >        rtems6 --enable-rtemsbsp=mpc5674fevb_spe
> >    87 network powerpc/mpc5674fevb_spe configure:
> --target=powerpc-\
> >    88 network-debug powerpc/mpc5674fevb_spe configure:
> --target=powerpc-\
> >        --disable-smp
> >    89 no-network powerpc/mpc5674fevb_spe configure:
> --target=powerpc-\
> >    90 no-posix powerpc/mpc5674fevb_spe configure:
> --target=powerpc-\
> >    91 posix powerpc/mpc5674fevb_spe configure:
> --target=powerpc-\
> >    92 posix-debug powerpc/mpc5674fevb_spe configure:
> --target=powerpc-\
> --disable-\
> >        smp
> >    93 posix-profiling powerpc/mpc5674fevb_spe configure:
> --target=powerpc-\
> --disable-smp
> >    94 profiling powerpc/mpc5674fevb_spe configure:
> --target=powerpc-\
> > Warnings Report
> >   | By Architecture (total : 91686)                                     |
> >   | common : 107 warning(s)                                             |
> >   |   Shared : 8832 |     BSP :    0 |Network : 26136 |    Tests :    0 |
> >   |   LibCPU :    0 | CPU Kit : 4269 |                |                 |
> >   | arm : 60 warning(s)                                                 |
> >   |   Shared : 1196 |     BSP :    0 |Network : 17212 |    Tests :    0 |
> >   |   LibCPU :    0 | CPU Kit : 1294 |                |                 |
> >   | bfin : 28 warning(s)                                                |
> >   |   Shared :   27 |     BSP :    0 | Network : 1032 |    Tests :    0 |
> >   |   LibCPU :  351 | CPU Kit :  126 |                |                 |
> >   | i386 : 30 warning(s)                                                |
> >   |   Shared :  288 |     BSP :    0 | Network : 2000 |    Tests :    0 |
> >   |   LibCPU :    0 | CPU Kit :  522 |                |                 |
> >   | lm32 : 14 warning(s)                                                |
> >   |   Shared :  210 |     BSP :    0 | Network :  792 |    Tests :    0 |
> >   |   LibCPU :    0 | CPU Kit :   78 |                |                 |
> >   | m68k : 155 warning(s)                                               |
> >   |   Shared :  180 |     BSP :    0 | Network : 6784 |    Tests :    0 |
> >   |   LibCPU :    0 | CPU Kit : 1688 |                |                 |
> >   | mips : 8 warning(s)                                                 |
> >   |   Shared :    0 |     BSP :    0 | Network : 1952 |    Tests :    0 |
> >   |   LibCPU :    0 | CPU Kit :  120 |                |                 |
> >   | moxie : 1 warning(s)                                                |
> >   |   Shared :    0 |     BSP :    0 | Network :  248 |    Tests :    0 |
> >   |   LibCPU :    0 | CPU Kit :   89 |                |                 |
> >   | or1k : 3 warning(s)                                                 |
> >   |   Shared :    9 |     BSP :    0 | Network :  232 |    Tests :    0 |
> >   |   LibCPU :    0 | CPU Kit :    0 |                |                 |
> >   | powerpc : 130 warning(s)                                            |
> >   |   Shared : 3988 |     BSP :    0 |Network : 14172 |    Tests :    0 |
> >   |   LibCPU :    0 | CPU Kit : 1234 |                |                 |
> >   | riscv : 7 warning(s)                                                |
> >   |   Shared : 2728 |     BSP :    0 | Network : 6772 |    Tests :    0 |
> >   |   LibCPU :    0 | CPU Kit : 2258 |                |                 |
> >   | sh : 160 warning(s)                                                 |
> >   |   Shared :    0 |     BSP :    0 | Network : 2408 |    Tests :    0 |
> >   |   LibCPU :    0 | CPU Kit :  168 |                |                 |
> >   | sparc : 2 warning(s)                                                |
> >   |   Shared : 1240 |     BSP :    0 | Network : 3480 |    Tests :    0 |
> >   |   LibCPU :    0 | CPU Kit :  252 |                |                 |
> >   | sparc64 : 2 warning(s)                                              |
> >   |   Shared :   18 |     BSP :    0 | Network :  672 |    Tests :    0 |
> >   |   LibCPU :    0 | CPU Kit :   84 |                |                 |
> >   | v850 : 0 warning(s)                                                 |
> >   | By BSP (total : 91686)                                              |
> >   | common : 412 warning(s)                                             |
> >   |   Shared : 9064 |     BSP :    0 |Network : 55364 |    Tests :    0 |
> >   |   LibCPU :  144 | CPU Kit : 7435 |                |                 |
> >   | arm/altcycv_devkit : 0 warning(s)                                   |
> >   | arm/atsamv : 45 warning(s)                                          |
> >   |   Shared :    0 |     BSP :    0 | Network :  328 |    Tests :    0 |
> >   |   LibCPU :    0 | CPU Kit :   24 |                |                 |
> >   | arm/beagleboardorig : 0 warning(s)                                  |
> >   | arm/beagleboardxm : 0 warning(s)                                    |
> >   | arm/beagleboneblack : 0 warning(s)                                  |
> >   | arm/beaglebonewhite : 0 warning(s)                                  |
> >   | arm/csb336 : 3 warning(s)                                           |
> >   |   Shared :    9 |     BSP :    0 | Network :  328 |    Tests :    0 |
> >   | arm/csb337 : 0 warning(s)                                           |
> >   | arm/csb637 : 0 warning(s)                                           |
> >   | arm/edb7312 : 0 warning(s)                                          |
> >   | arm/gumstix : 0 warning(s)                                          |
> >   | arm/imx7 : 0 warning(s)                                             |
> >   | arm/kit637_v6 : 0 warning(s)                                        |
> >   | arm/lm3s3749 : 0 warning(s)                                         |
> >   | arm/lm3s6965 : 0 warning(s)                                         |
> >   | arm/lm3s6965_qemu : 0 warning(s)                                    |
> >   | arm/lm4f120 : 0 warning(s)                                          |
> >   | arm/lpc1768_mbed : 0 warning(s)                                     |
> >   | arm/lpc1768_mbed_ahb_ram : 0 warning(s)                             |
> >   | arm/lpc1768_mbed_ahb_ram_eth : 0 warning(s)                         |
> >   | arm/lpc17xx_ea_ram : 0 warning(s)                                   |
> >   | arm/lpc17xx_ea_rom_int : 0 warning(s)                               |
> >   | arm/lpc17xx_plx800_ram : 0 warning(s)                               |
> >   | arm/lpc17xx_plx800_rom_int : 0 warning(s)                           |
> >   | arm/lpc2362 : 0 warning(s)                                          |
> >   | arm/lpc23xx_tli800 : 0 warning(s)                                   |
> >   | arm/lpc24xx_ea : 0 warning(s)                                       |
> >   | arm/lpc24xx_ncs_ram : 0 warning(s)                                  |
> >   | arm/lpc24xx_ncs_rom_ext : 0 warning(s)                              |
> >   | arm/lpc24xx_ncs_rom_int : 0 warning(s)                              |
> >   | arm/lpc24xx_plx800_ram : 0 warning(s)                               |
> >   | arm/lpc24xx_plx800_rom_int : 0 warning(s)                           |
> >   | arm/lpc32xx_mzx : 0 warning(s)                                      |
> >   | arm/lpc32xx_mzx_stage_1 : 0 warning(s)                              |
> >   | arm/lpc32xx_mzx_stage_2 : 0 warning(s)                              |
> >   | arm/lpc32xx_phycore : 0 warning(s)                                  |
> >   | arm/lpc40xx_ea_ram : 0 warning(s)                                   |
> >   | arm/lpc40xx_ea_rom_int : 0 warning(s)                               |
> >   | arm/raspberrypi : 0 warning(s)                                      |
> >   | arm/raspberrypi2 : 0 warning(s)                                     |
> >   | arm/realview_pbx_a9_qemu : 0 warning(s)                             |
> >   | arm/rtl22xx : 0 warning(s)                                          |
> >   | arm/rtl22xx_t : 0 warning(s)                                        |
> >   | arm/smdk2410 : 0 warning(s)                                         |
> >   | arm/stm32f105rc : 0 warning(s)                                      |
> >   | arm/stm32f4 : 2 warning(s)                                          |
> >   |   Shared :    0 |     BSP :    0 | Network :  344 |    Tests :    0 |
> >   | arm/tms570ls3137_hdk : 0 warning(s)                                 |
> >   | arm/tms570ls3137_hdk_intram : 0 warning(s)                          |
> >   | arm/tms570ls3137_hdk_sdram : 0 warning(s)                           |
> >   | arm/tms570ls3137_hdk_with_loader : 0 warning(s)                     |
> >   | arm/xilinx_zynq_a9_qemu : 0 warning(s)                              |
> >   | arm/xilinx_zynq_zc702 : 0 warning(s)                                |
> >   | arm/xilinx_zynq_zc706 : 0 warning(s)                                |
> >   | arm/xilinx_zynq_zedboard : 0 warning(s)                             |
> >   | bfin/TLL6527M : 10 warning(s)                                       |
> >   |   Shared :    9 |     BSP :    0 | Network :  344 |    Tests :    0 |
> >   |   LibCPU :  207 | CPU Kit :   42 |                |                 |
> >   | bfin/bf537Stamp : 0 warning(s)                                      |
> >   | bfin/eZKit533 : 0 warning(s)                                        |
> >   | i386/pc386 : 0 warning(s)                                           |
> >   | i386/pc486 : 0 warning(s)                                           |
> >   | i386/pc586 : 0 warning(s)                                           |
> >   | i386/pc586-sse : 0 warning(s)                                       |
> >   | i386/pc686 : 0 warning(s)                                           |
> >   | i386/pcp4 : 0 warning(s)                                            |
> >   | lm32/lm32_evr : 0 warning(s)                                        |
> >   | lm32/lm32_evr_gdbsim : 0 warning(s)                                 |
> >   | lm32/milkymist : 0 warning(s)                                       |
> >   | m68k/COBRA5475 : 0 warning(s)                                       |
> >   | m68k/av5282 : 65 warning(s)                                         |
> >   |   LibCPU :    0 | CPU Kit :   87 |                |                 |
> >   | m68k/csb360 : 0 warning(s)                                          |
> >   | m68k/gen68340 : 0 warning(s)                                        |
> >   | m68k/gen68360 : 0 warning(s)                                        |
> >   | m68k/gen68360_040 : 0 warning(s)                                    |
> >   | m68k/m5484FireEngine : 0 warning(s)                                 |
> >   | m68k/mcf5206elite : 0 warning(s)                                    |
> >   | m68k/mcf52235 : 1 warning(s)                                        |
> >   | m68k/mcf5225x : 1 warning(s)                                        |
> >   | m68k/mcf5235 : 2 warning(s)                                         |
> >   | m68k/mcf5329 : 4 warning(s)                                         |
> >   | m68k/mrm332 : 0 warning(s)                                          |
> >   | m68k/mvme147 : 0 warning(s)                                         |
> >   | m68k/mvme147s : 0 warning(s)                                        |
> >   | m68k/mvme162 : 0 warning(s)                                         |
> >   | m68k/mvme162lx : 0 warning(s)                                       |
> >   | m68k/mvme167 : 1 warning(s)                                         |
> >   | m68k/pgh360 : 0 warning(s)                                          |
> >   | m68k/uC5282 : 67 warning(s)                                         |
> >   | mips/csb350 : 1 warning(s)                                          |
> >   | mips/hurricane : 0 warning(s)                                       |
> >   | mips/jmr3904 : 0 warning(s)                                         |
> >   | mips/malta : 6 warning(s)                                           |
> >   |   Shared :    0 |     BSP :    0 | Network :  232 |    Tests :    0 |
> >   | mips/rbtx4925 : 0 warning(s)                                        |
> >   | mips/rbtx4938 : 1 warning(s)                                        |
> >   | moxie/moxiesim : 1 warning(s)                                       |
> >   | or1k/generic_or1k : 3 warning(s)                                    |
> >   | powerpc/beatnik : 0 warning(s)                                      |
> >   | powerpc/br_uid : 0 warning(s)                                       |
> >   | powerpc/gwlcfm : 0 warning(s)                                       |
> >   | powerpc/haleakala : 16 warning(s)                                   |
> >   |   LibCPU :    0 | CPU Kit :   26 |                |                 |
> >   | powerpc/hsc_cm01 : 0 warning(s)                                     |
> >   | powerpc/icecube : 0 warning(s)                                      |
> >   | powerpc/mcp750 : 0 warning(s)                                       |
> >   | powerpc/mpc5566evb : 0 warning(s)                                   |
> >   | powerpc/mpc5643l_evb : 0 warning(s)                                 |
> >   | powerpc/mpc5668g : 0 warning(s)                                     |
> >   | powerpc/mpc5674fevb : 0 warning(s)                                  |
> >   | powerpc/mpc8260ads : 6 warning(s)                                   |
> >   |   Shared :    0 |     BSP :    0 | Network :  352 |    Tests :    0 |
> >   | powerpc/mpc8309som : 0 warning(s)                                   |
> >   | powerpc/mpc8313erdb : 0 warning(s)                                  |
> >   | powerpc/mpc8349eamds : 0 warning(s)                                 |
> >   | powerpc/mtx603e : 0 warning(s)                                      |
> >   | powerpc/mvme2100 : 0 warning(s)                                     |
> >   | powerpc/mvme2307 : 0 warning(s)                                     |
> >   | powerpc/mvme3100 : 3 warning(s)                                     |
> >   |   Shared :  217 |     BSP :    0 | Network :  352 |    Tests :    0 |
> >   | powerpc/mvme5500 : 20 warning(s)                                    |
> >   |   Shared :  226 |     BSP :    0 | Network :  360 |    Tests :    0 |
> >   | powerpc/pghplus : 1 warning(s)                                      |
> >   | powerpc/phycore_mpc5554 : 1 warning(s)                              |
> >   | powerpc/pm520_cr825 : 0 warning(s)                                  |
> >   | powerpc/pm520_ze30 : 0 warning(s)                                   |
> >   | powerpc/psim : 1 warning(s)                                         |
> >   | powerpc/qemuppc : 1 warning(s)                                      |
> >   | powerpc/qemuprep : 0 warning(s)                                     |
> >   | powerpc/qemuprep-altivec : 0 warning(s)                             |
> >   | powerpc/qoriq_core_0 : 0 warning(s)                                 |
> >   | powerpc/qoriq_core_1 : 0 warning(s)                                 |
> >   | powerpc/qoriq_e500 : 0 warning(s)                                   |
> >   | powerpc/qoriq_e6500_32 : 0 warning(s)                               |
> >   | powerpc/qoriq_e6500_64 : 14 warning(s)                              |
> >   |   Shared :  521 |     BSP :    0 | Network :  612 |    Tests :    0 |
> >   |   LibCPU :    0 | CPU Kit :  231 |                |                 |
> >   | powerpc/ss555 : 0 warning(s)                                        |
> >   | powerpc/t32mppc : 2 warning(s)                                      |
> >   |   LibCPU :    0 | CPU Kit :   35 |                |                 |
> >   | powerpc/tqm8xx_stk8xx : 1 warning(s)                                |
> >   | powerpc/virtex : 12 warning(s)                                      |
> >   | powerpc/virtex4 : 0 warning(s)                                      |
> >   | powerpc/virtex5 : 0 warning(s)                                      |
> >   | riscv/rv32i : 0 warning(s)                                          |
> >   | riscv/rv32iac : 0 warning(s)                                        |
> >   | riscv/rv32im : 0 warning(s)                                         |
> >   | riscv/rv32imac : 0 warning(s)                                       |
> >   | riscv/rv32imafc : 0 warning(s)                                      |
> >   | riscv/rv32imafd : 0 warning(s)                                      |
> >   | riscv/rv32imafdc : 0 warning(s)                                     |
> >   | riscv/rv64imac : 0 warning(s)                                       |
> >   | riscv/rv64imac_medany : 0 warning(s)                                |
> >   | riscv/rv64imafd : 0 warning(s)                                      |
> >   | riscv/rv64imafd_medany : 0 warning(s)                               |
> >   | riscv/rv64imafdc : 0 warning(s)                                     |
> >   | riscv/rv64imafdc_medany : 0 warning(s)                              |
> >   | sh/gensh1 : 1 warning(s)                                            |
> >   | sh/gensh2 : 1 warning(s)                                            |
> >   | sh/gensh4 : 1 warning(s)                                            |
> >   | sh/simsh1 : 0 warning(s)                                            |
> >   | sh/simsh2 : 0 warning(s)                                            |
> >   | sh/simsh2e : 0 warning(s)                                           |
> >   | sh/simsh4 : 0 warning(s)                                            |
> >   | sparc/at697f : 0 warning(s)                                         |
> >   | sparc/erc32 : 0 warning(s)                                          |
> >   | sparc/gr712rc : 0 warning(s)                                        |
> >   | sparc/gr740 : 0 warning(s)                                          |
> >   | sparc/leon2 : 0 warning(s)                                          |
> >   | sparc/leon3 : 0 warning(s)                                          |
> >   | sparc/ut699 : 0 warning(s)                                          |
> >   | sparc/ut700 : 0 warning(s)                                          |
> >   | sparc64/niagara : 0 warning(s)                                      |
> >   | sparc64/usiii : 1 warning(s)                                        |
> >   |   Shared :    9 |     BSP :    0 | Network :  336 |    Tests :    0 |
> >   |   LibCPU :    0 | CPU Kit :   42 |                |                 |
> >   | v850/v850e1sim : 0 warning(s)                                       |
> >   | v850/v850e2sim : 0 warning(s)                                       |
> >   | v850/v850e2v3sim : 0 warning(s)                                     |
> >   | v850/v850esim : 0 warning(s)                                        |
> >   | v850/v850essim : 0 warning(s)                                       |
> >   | v850/v850sim : 0 warning(s)                                         |
> >   | By Build (total : 91686)                                            |
> >   | common : 707 warning(s)                                             |
> >   |   Shared : 8178 |     BSP :    0 |Network : 76150 |    Tests :    0 |
> >   |   LibCPU :  312 | CPU Kit : 9452 |                |                 |
> >   | debug : 0 warning(s)                                                |
> >   | network : 0 warning(s)                                              |
> >   | network-debug : 0 warning(s)                                        |
> >   | no-network : 0 warning(s)                                           |
> >   | no-posix : 0 warning(s)                                             |
> >   | posix-debug : 0 warning(s)                                          |
> >   | posix-profiling : 0 warning(s)                                      |
> >   | smp : 0 warning(s)                                                  |
> >   | smp-debug : 0 warning(s)                                            |
> >   | smp-network : 0 warning(s)                                          |
> >   | smp-network-debug : 0 warning(s)                                    |
> > build mailing list
> > http://lists.rtems.org/mailman/listinfo/build
> > <http://lists.rtems.org/mailman/listinfo/build>
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201214/af3cc154/attachment-0001.html>
