Fwd: [rtems-bsp-builder] 2020-12-11 12:57:21: Profile(s): everything
Christian MAUDERER
christian.mauderer at embedded-brains.de
Mon Dec 14 14:27:30 UTC 2020
Hello Joel,
Am 14.12.20 um 15:23 schrieb Joel Sherrill:
> On Sun, Dec 13, 2020 at 3:32 AM Christian Mauderer <oss at c-mauderer.de
> <mailto:oss at c-mauderer.de>> wrote:
> Hello Joel,
> that patch should most likely fix that problem:
> Great!
> https://lists.rtems.org/pipermail/devel/2020-December/063708.html
> <https://lists.rtems.org/pipermail/devel/2020-December/063708.html>
> I haven't pushed it yet because I just posted it on Thursday and it was
> only one day of review time on Friday. I'll push it on Monday (together
> with some other pending patches).
> OK. I'll start another sweep when this goes in.
Sebastian urged me to push the patch. So it already is in the repo since
a few hours:
https://git.rtems.org/rtems/commit/?id=9b3def237addd99154817f85c6c1a7ef62e444f1
> FWIW I try to do at least one build sweep a month and post reports of
> failures when the set of issues changes. It is just easy for something to
> slip in. Easy enough to let the computers churn a few days.
Yes, that's great. Sorry that the bug slipped in.
Best regards
Christian
> --joel
> Best regards
> Christian
> On 12/12/2020 17:24, Joel Sherrill wrote:
> > Looks like the failures would mostly be explained by something is
> broken
> > on the imx7 BSP and the SPE PowerPC bsps are still listed in the
> tier
> > files for the tester.
> > ---------- Forwarded message ---------
> > From: <joel at rtems.org <mailto:joel at rtems.org>
> <mailto:joel at rtems.org <mailto:joel at rtems.org>>>
> > Date: Sat, Dec 12, 2020, 9:49 AM
> > Subject: [rtems-bsp-builder] 2020-12-11 12:57:21: Profile(s):
> everything
> > To: <build at rtems.org <mailto:build at rtems.org>
> <mailto:build at rtems.org <mailto:build at rtems.org>>>
> > RTEMS Tools Project - RTEMS Kernel BSP Builder, 6.0.not_released
> > Host: #1 SMP Tue Aug 25 17:23:54 UTC 2020
> > command: /home/joel/rtems-cron-6/tools/6/bin/rtems-bsp-builder\
> > --rtems=/home/joel/rtems-cron-6/rtems
> --build-path=/home/joel\
> > /rtems-cron-6/build
> --prefix=/home/joel/rtems-cron-6/tools/6/bsps\
> > --log=/home/joel/rtems-cron-6/bsp-builder.log --warnings-\
> > report=warnings.log --mail --mail-to=build at rtems.org
> > <mailto:build at rtems.org <mailto:build at rtems.org>> --mail-\
> > from=joel at rtems.org <mailto:joel at rtems.org>
> <mailto:joel at rtems.org <mailto:joel at rtems.org>> --profiles=everything
> > Total Time : 20:51:45.296683 for 1696 completed job(s)
> > Average BSP Build Time: 0:00:44.283783
> > Builds
> > debug
> > network
> > network-debug
> > no-network
> > no-posix
> > posix
> > posix-debug
> > posix-profiling
> > profiling
> > smp
> > smp-debug
> > smp-network
> > smp-network-debug
> > Failures Report
> > 1 debug arm/imx7 build:
> > configure: /home/joel/rtems-cron-6/rtems/configure
> --target=arm-\
> > rtems6 --enable-rtemsbsp=imx7 --prefix=/home/joel/rtems-\
> > cron-6/tools/6/bsps --enable-rtems-debug
> > error: bsps/arm/shared/pins/imx_iomux.c:69:10: fatal error:
> > arm/freescale/imx/imx_iomuxvar.h: No such file or
> directory
> > 2 network arm/imx7 build:
> --target=arm-\
> > cron-6/tools/6/bsps --enable-networking
> directory
> > 3 network-debug arm/imx7 build:
> --target=arm-\
> > cron-6/tools/6/bsps --enable-rtems-debug --enable-networking
> directory
> > 4 no-network arm/imx7 build:
> --target=arm-\
> > cron-6/tools/6/bsps --disable-networking
> directory
> > 5 no-posix arm/imx7 build:
> --target=arm-\
> > cron-6/tools/6/bsps --disable-posix
> directory
> > 6 posix arm/imx7 build:
> --target=arm-\
> > cron-6/tools/6/bsps --enable-posix
> directory
> > 7 posix-debug arm/imx7 build:
> --target=arm-\
> > cron-6/tools/6/bsps --enable-rtems-debug --enable-posix
> directory
> > 8 posix-profiling arm/imx7 build:
> --target=arm-\
> > cron-6/tools/6/bsps --enable-posix --enable-profiling
> directory
> > 9 profiling arm/imx7 build:
> --target=arm-\
> > cron-6/tools/6/bsps --enable-profiling
> directory
> > 10 smp arm/imx7 build:
> --target=arm-\
> > cron-6/tools/6/bsps --enable-smp
> directory
> > 11 smp-debug arm/imx7 build:
> --target=arm-\
> > cron-6/tools/6/bsps --enable-rtems-debug --enable-smp
> directory
> > 12 smp-network arm/imx7 build:
> --target=arm-\
> > cron-6/tools/6/bsps --enable-networking --enable-smp
> directory
> > 13 smp-network-debug arm/imx7 build:
> --target=arm-\
> > cron-6/tools/6/bsps --enable-rtems-debug --enable-networking\
> > --enable-smp
> directory
> > 14 debug powerpc/brs5l configure:
> --target=powerpc-\
> > rtems6 --enable-rtemsbsp=brs5l --prefix=/home/joel/rtems-\
> > cron-6/tools/6/bsps --enable-rtems-debug --disable-smp
> > 15 network powerpc/brs5l configure:
> --target=powerpc-\
> > cron-6/tools/6/bsps --enable-networking --disable-smp
> > 16 network-debug powerpc/brs5l configure:
> --target=powerpc-\
> > --disable-smp
> > 17 no-network powerpc/brs5l configure:
> --target=powerpc-\
> > cron-6/tools/6/bsps --disable-networking --disable-smp
> > 18 no-posix powerpc/brs5l configure:
> --target=powerpc-\
> > cron-6/tools/6/bsps --disable-posix --disable-smp
> > 19 posix powerpc/brs5l configure:
> --target=powerpc-\
> > cron-6/tools/6/bsps --enable-posix --disable-smp
> > 20 posix-debug powerpc/brs5l configure:
> --target=powerpc-\
> --disable-\
> > smp
> > 21 posix-profiling powerpc/brs5l configure:
> --target=powerpc-\
> --disable-smp
> > 22 profiling powerpc/brs5l configure:
> --target=powerpc-\
> > cron-6/tools/6/bsps --enable-profiling --disable-smp
> > 23 debug powerpc/brs6l configure:
> --target=powerpc-\
> > rtems6 --enable-rtemsbsp=brs6l --prefix=/home/joel/rtems-\
> > 24 network powerpc/brs6l configure:
> --target=powerpc-\
> > 25 network-debug powerpc/brs6l configure:
> --target=powerpc-\
> > --disable-smp
> > 26 no-network powerpc/brs6l configure:
> --target=powerpc-\
> > 27 no-posix powerpc/brs6l configure:
> --target=powerpc-\
> > 28 posix powerpc/brs6l configure:
> --target=powerpc-\
> > 29 posix-debug powerpc/brs6l configure:
> --target=powerpc-\
> --disable-\
> > smp
> > 30 posix-profiling powerpc/brs6l configure:
> --target=powerpc-\
> --disable-smp
> > 31 profiling powerpc/brs6l configure:
> --target=powerpc-\
> > 32 debug powerpc/dp2 configure:
> --target=powerpc-\
> > rtems6 --enable-rtemsbsp=dp2 --prefix=/home/joel/rtems-\
> > 33 network powerpc/dp2 configure:
> --target=powerpc-\
> > 34 network-debug powerpc/dp2 configure:
> --target=powerpc-\
> > --disable-smp
> > 35 no-network powerpc/dp2 configure:
> --target=powerpc-\
> > 36 no-posix powerpc/dp2 configure:
> --target=powerpc-\
> > 37 posix powerpc/dp2 configure:
> --target=powerpc-\
> > 38 posix-debug powerpc/dp2 configure:
> --target=powerpc-\
> --disable-\
> > smp
> > 39 posix-profiling powerpc/dp2 configure:
> --target=powerpc-\
> --disable-smp
> > 40 profiling powerpc/dp2 configure:
> --target=powerpc-\
> > 41 debug powerpc/mpc5566evb_spe configure:
> --target=powerpc-\
> > rtems6 --enable-rtemsbsp=mpc5566evb_spe
> > 42 network powerpc/mpc5566evb_spe configure:
> --target=powerpc-\
> > 43 network-debug powerpc/mpc5566evb_spe configure:
> --target=powerpc-\
> > --disable-smp
> > 44 no-network powerpc/mpc5566evb_spe configure:
> --target=powerpc-\
> > 45 no-posix powerpc/mpc5566evb_spe configure:
> --target=powerpc-\
> > 46 posix powerpc/mpc5566evb_spe configure:
> --target=powerpc-\
> > 47 posix-debug powerpc/mpc5566evb_spe configure:
> --target=powerpc-\
> --disable-\
> > smp
> > 48 posix-profiling powerpc/mpc5566evb_spe configure:
> --target=powerpc-\
> --disable-smp
> > 49 profiling powerpc/mpc5566evb_spe configure:
> --target=powerpc-\
> > 50 debug powerpc/mpc5643l_dpu configure:
> --target=powerpc-\
> > rtems6 --enable-rtemsbsp=mpc5643l_dpu
> > 51 network powerpc/mpc5643l_dpu configure:
> --target=powerpc-\
> > 52 network-debug powerpc/mpc5643l_dpu configure:
> --target=powerpc-\
> > --disable-smp
> > 53 no-network powerpc/mpc5643l_dpu configure:
> --target=powerpc-\
> > 54 no-posix powerpc/mpc5643l_dpu configure:
> --target=powerpc-\
> > 55 posix powerpc/mpc5643l_dpu configure:
> --target=powerpc-\
> > 56 posix-debug powerpc/mpc5643l_dpu configure:
> --target=powerpc-\
> --disable-\
> > smp
> > 57 posix-profiling powerpc/mpc5643l_dpu configure:
> --target=powerpc-\
> --disable-smp
> > 58 profiling powerpc/mpc5643l_dpu configure:
> --target=powerpc-\
> > 59 debug powerpc/mpc5674f_ecu508_app configure:
> --target=powerpc-\
> > rtems6 --enable-rtemsbsp=mpc5674f_ecu508_app
> --prefix=/home/joel\
> > /rtems-cron-6/tools/6/bsps --enable-rtems-debug --disable-smp
> > 60 network powerpc/mpc5674f_ecu508_app configure:
> --target=powerpc-\
> > /rtems-cron-6/tools/6/bsps --enable-networking --disable-smp
> > 61 network-debug powerpc/mpc5674f_ecu508_app configure:
> --target=powerpc-\
> > --disable-smp
> > 62 no-network powerpc/mpc5674f_ecu508_app configure:
> --target=powerpc-\
> > /rtems-cron-6/tools/6/bsps --disable-networking --disable-smp
> > 63 no-posix powerpc/mpc5674f_ecu508_app configure:
> --target=powerpc-\
> > /rtems-cron-6/tools/6/bsps --disable-posix --disable-smp
> > 64 posix powerpc/mpc5674f_ecu508_app configure:
> --target=powerpc-\
> > /rtems-cron-6/tools/6/bsps --enable-posix --disable-smp
> > 65 posix-debug powerpc/mpc5674f_ecu508_app configure:
> --target=powerpc-\
> --enable-posix\
> > --disable-smp
> > 66 posix-profiling powerpc/mpc5674f_ecu508_app configure:
> --target=powerpc-\
> > /rtems-cron-6/tools/6/bsps --enable-posix --enable-profiling\
> > --disable-smp
> > 67 profiling powerpc/mpc5674f_ecu508_app configure:
> --target=powerpc-\
> > /rtems-cron-6/tools/6/bsps --enable-profiling --disable-smp
> > 68 debug powerpc/mpc5674f_ecu508_boot configure:
> --target=powerpc-\
> > rtems6 --enable-rtemsbsp=mpc5674f_ecu508_boot
> > 69 network powerpc/mpc5674f_ecu508_boot configure:
> --target=powerpc-\
> > 70 network-debug powerpc/mpc5674f_ecu508_boot configure:
> --target=powerpc-\
> > --disable-smp
> > 71 no-network powerpc/mpc5674f_ecu508_boot configure:
> --target=powerpc-\
> > 72 no-posix powerpc/mpc5674f_ecu508_boot configure:
> --target=powerpc-\
> > 73 posix powerpc/mpc5674f_ecu508_boot configure:
> --target=powerpc-\
> > 74 posix-debug powerpc/mpc5674f_ecu508_boot configure:
> --target=powerpc-\
> --enable-posix\
> > --disable-smp
> > 75 posix-profiling powerpc/mpc5674f_ecu508_boot configure:
> --target=powerpc-\
> > --disable-smp
> > 76 profiling powerpc/mpc5674f_ecu508_boot configure:
> --target=powerpc-\
> > 77 debug powerpc/mpc5674f_rsm6 configure:
> --target=powerpc-\
> > rtems6 --enable-rtemsbsp=mpc5674f_rsm6
> > 78 network powerpc/mpc5674f_rsm6 configure:
> --target=powerpc-\
> > 79 network-debug powerpc/mpc5674f_rsm6 configure:
> --target=powerpc-\
> > --disable-smp
> > 80 no-network powerpc/mpc5674f_rsm6 configure:
> --target=powerpc-\
> > 81 no-posix powerpc/mpc5674f_rsm6 configure:
> --target=powerpc-\
> > 82 posix powerpc/mpc5674f_rsm6 configure:
> --target=powerpc-\
> > 83 posix-debug powerpc/mpc5674f_rsm6 configure:
> --target=powerpc-\
> --disable-\
> > smp
> > 84 posix-profiling powerpc/mpc5674f_rsm6 configure:
> --target=powerpc-\
> --disable-smp
> > 85 profiling powerpc/mpc5674f_rsm6 configure:
> --target=powerpc-\
> > 86 debug powerpc/mpc5674fevb_spe configure:
> --target=powerpc-\
> > rtems6 --enable-rtemsbsp=mpc5674fevb_spe
> > 87 network powerpc/mpc5674fevb_spe configure:
> --target=powerpc-\
> > 88 network-debug powerpc/mpc5674fevb_spe configure:
> --target=powerpc-\
> > --disable-smp
> > 89 no-network powerpc/mpc5674fevb_spe configure:
> --target=powerpc-\
> > 90 no-posix powerpc/mpc5674fevb_spe configure:
> --target=powerpc-\
> > 91 posix powerpc/mpc5674fevb_spe configure:
> --target=powerpc-\
> > 92 posix-debug powerpc/mpc5674fevb_spe configure:
> --target=powerpc-\
> --disable-\
> > smp
> > 93 posix-profiling powerpc/mpc5674fevb_spe configure:
> --target=powerpc-\
> --disable-smp
> > 94 profiling powerpc/mpc5674fevb_spe configure:
> --target=powerpc-\
> > Warnings Report
> > | By Architecture (total : 91686)
> > | common : 107 warning(s)
> > | Shared : 8832 | BSP : 0 |Network : 26136 | Tests
> : 0 |
> > | LibCPU : 0 | CPU Kit : 4269 | |
> > | arm : 60 warning(s)
> > | Shared : 1196 | BSP : 0 |Network : 17212 | Tests
> : 0 |
> > | LibCPU : 0 | CPU Kit : 1294 | |
> > | bfin : 28 warning(s)
> > | Shared : 27 | BSP : 0 | Network : 1032 | Tests
> : 0 |
> > | LibCPU : 351 | CPU Kit : 126 | |
> > | i386 : 30 warning(s)
> > | Shared : 288 | BSP : 0 | Network : 2000 | Tests
> : 0 |
> > | LibCPU : 0 | CPU Kit : 522 | |
> > | lm32 : 14 warning(s)
> > | Shared : 210 | BSP : 0 | Network : 792 | Tests
> : 0 |
> > | LibCPU : 0 | CPU Kit : 78 | |
> > | m68k : 155 warning(s)
> > | Shared : 180 | BSP : 0 | Network : 6784 | Tests
> : 0 |
> > | LibCPU : 0 | CPU Kit : 1688 | |
> > | mips : 8 warning(s)
> > | Shared : 0 | BSP : 0 | Network : 1952 | Tests
> : 0 |
> > | LibCPU : 0 | CPU Kit : 120 | |
> > | moxie : 1 warning(s)
> > | Shared : 0 | BSP : 0 | Network : 248 | Tests
> : 0 |
> > | LibCPU : 0 | CPU Kit : 89 | |
> > | or1k : 3 warning(s)
> > | Shared : 9 | BSP : 0 | Network : 232 | Tests
> : 0 |
> > | LibCPU : 0 | CPU Kit : 0 | |
> > | powerpc : 130 warning(s)
> > | Shared : 3988 | BSP : 0 |Network : 14172 | Tests
> : 0 |
> > | LibCPU : 0 | CPU Kit : 1234 | |
> > | riscv : 7 warning(s)
> > | Shared : 2728 | BSP : 0 | Network : 6772 | Tests
> : 0 |
> > | LibCPU : 0 | CPU Kit : 2258 | |
> > | sh : 160 warning(s)
> > | Shared : 0 | BSP : 0 | Network : 2408 | Tests
> : 0 |
> > | LibCPU : 0 | CPU Kit : 168 | |
> > | sparc : 2 warning(s)
> > | Shared : 1240 | BSP : 0 | Network : 3480 | Tests
> : 0 |
> > | LibCPU : 0 | CPU Kit : 252 | |
> > | sparc64 : 2 warning(s)
> > | Shared : 18 | BSP : 0 | Network : 672 | Tests
> : 0 |
> > | LibCPU : 0 | CPU Kit : 84 | |
> > | v850 : 0 warning(s)
> > | By BSP (total : 91686)
> > | common : 412 warning(s)
> > | Shared : 9064 | BSP : 0 |Network : 55364 | Tests
> : 0 |
> > | LibCPU : 144 | CPU Kit : 7435 | |
> > | arm/altcycv_devkit : 0 warning(s)
> > | arm/atsamv : 45 warning(s)
> > | Shared : 0 | BSP : 0 | Network : 328 | Tests
> : 0 |
> > | LibCPU : 0 | CPU Kit : 24 | |
> > | arm/beagleboardorig : 0 warning(s)
> > | arm/beagleboardxm : 0 warning(s)
> > | arm/beagleboneblack : 0 warning(s)
> > | arm/beaglebonewhite : 0 warning(s)
> > | arm/csb336 : 3 warning(s)
> > | Shared : 9 | BSP : 0 | Network : 328 | Tests
> : 0 |
> > | arm/csb337 : 0 warning(s)
> > | arm/csb637 : 0 warning(s)
> > | arm/edb7312 : 0 warning(s)
> > | arm/gumstix : 0 warning(s)
> > | arm/imx7 : 0 warning(s)
> > | arm/kit637_v6 : 0 warning(s)
> > | arm/lm3s3749 : 0 warning(s)
> > | arm/lm3s6965 : 0 warning(s)
> > | arm/lm3s6965_qemu : 0 warning(s)
> > | arm/lm4f120 : 0 warning(s)
> > | arm/lpc1768_mbed : 0 warning(s)
> > | arm/lpc1768_mbed_ahb_ram : 0 warning(s)
> > | arm/lpc1768_mbed_ahb_ram_eth : 0 warning(s)
> > | arm/lpc17xx_ea_ram : 0 warning(s)
> > | arm/lpc17xx_ea_rom_int : 0 warning(s)
> > | arm/lpc17xx_plx800_ram : 0 warning(s)
> > | arm/lpc17xx_plx800_rom_int : 0 warning(s)
> > | arm/lpc2362 : 0 warning(s)
> > | arm/lpc23xx_tli800 : 0 warning(s)
> > | arm/lpc24xx_ea : 0 warning(s)
> > | arm/lpc24xx_ncs_ram : 0 warning(s)
> > | arm/lpc24xx_ncs_rom_ext : 0 warning(s)
> > | arm/lpc24xx_ncs_rom_int : 0 warning(s)
> > | arm/lpc24xx_plx800_ram : 0 warning(s)
> > | arm/lpc24xx_plx800_rom_int : 0 warning(s)
> > | arm/lpc32xx_mzx : 0 warning(s)
> > | arm/lpc32xx_mzx_stage_1 : 0 warning(s)
> > | arm/lpc32xx_mzx_stage_2 : 0 warning(s)
> > | arm/lpc32xx_phycore : 0 warning(s)
> > | arm/lpc40xx_ea_ram : 0 warning(s)
> > | arm/lpc40xx_ea_rom_int : 0 warning(s)
> > | arm/raspberrypi : 0 warning(s)
> > | arm/raspberrypi2 : 0 warning(s)
> > | arm/realview_pbx_a9_qemu : 0 warning(s)
> > | arm/rtl22xx : 0 warning(s)
> > | arm/rtl22xx_t : 0 warning(s)
> > | arm/smdk2410 : 0 warning(s)
> > | arm/stm32f105rc : 0 warning(s)
> > | arm/stm32f4 : 2 warning(s)
> > | Shared : 0 | BSP : 0 | Network : 344 | Tests
> : 0 |
> > | arm/tms570ls3137_hdk : 0 warning(s)
> > | arm/tms570ls3137_hdk_intram : 0 warning(s)
> > | arm/tms570ls3137_hdk_sdram : 0 warning(s)
> > | arm/tms570ls3137_hdk_with_loader : 0 warning(s)
> > | arm/xilinx_zynq_a9_qemu : 0 warning(s)
> > | arm/xilinx_zynq_zc702 : 0 warning(s)
> > | arm/xilinx_zynq_zc706 : 0 warning(s)
> > | arm/xilinx_zynq_zedboard : 0 warning(s)
> > | bfin/TLL6527M : 10 warning(s)
> > | Shared : 9 | BSP : 0 | Network : 344 | Tests
> : 0 |
> > | LibCPU : 207 | CPU Kit : 42 | |
> > | bfin/bf537Stamp : 0 warning(s)
> > | bfin/eZKit533 : 0 warning(s)
> > | i386/pc386 : 0 warning(s)
> > | i386/pc486 : 0 warning(s)
> > | i386/pc586 : 0 warning(s)
> > | i386/pc586-sse : 0 warning(s)
> > | i386/pc686 : 0 warning(s)
> > | i386/pcp4 : 0 warning(s)
> > | lm32/lm32_evr : 0 warning(s)
> > | lm32/lm32_evr_gdbsim : 0 warning(s)
> > | lm32/milkymist : 0 warning(s)
> > | m68k/COBRA5475 : 0 warning(s)
> > | m68k/av5282 : 65 warning(s)
> : 0 |
> > | LibCPU : 0 | CPU Kit : 87 | |
> > | m68k/csb360 : 0 warning(s)
> > | m68k/gen68340 : 0 warning(s)
> > | m68k/gen68360 : 0 warning(s)
> > | m68k/gen68360_040 : 0 warning(s)
> > | m68k/m5484FireEngine : 0 warning(s)
> > | m68k/mcf5206elite : 0 warning(s)
> > | m68k/mcf52235 : 1 warning(s)
> : 0 |
> > | m68k/mcf5225x : 1 warning(s)
> : 0 |
> > | m68k/mcf5235 : 2 warning(s)
> : 0 |
> > | m68k/mcf5329 : 4 warning(s)
> : 0 |
> > | m68k/mrm332 : 0 warning(s)
> > | m68k/mvme147 : 0 warning(s)
> > | m68k/mvme147s : 0 warning(s)
> > | m68k/mvme162 : 0 warning(s)
> > | m68k/mvme162lx : 0 warning(s)
> > | m68k/mvme167 : 1 warning(s)
> : 0 |
> > | m68k/pgh360 : 0 warning(s)
> > | m68k/uC5282 : 67 warning(s)
> : 0 |
> > | mips/csb350 : 1 warning(s)
> : 0 |
> > | mips/hurricane : 0 warning(s)
> > | mips/jmr3904 : 0 warning(s)
> > | mips/malta : 6 warning(s)
> > | Shared : 0 | BSP : 0 | Network : 232 | Tests
> : 0 |
> > | mips/rbtx4925 : 0 warning(s)
> > | mips/rbtx4938 : 1 warning(s)
> : 0 |
> > | moxie/moxiesim : 1 warning(s)
> : 0 |
> > | or1k/generic_or1k : 3 warning(s)
> : 0 |
> > | powerpc/beatnik : 0 warning(s)
> > | powerpc/br_uid : 0 warning(s)
> > | powerpc/gwlcfm : 0 warning(s)
> > | powerpc/haleakala : 16 warning(s)
> : 0 |
> > | LibCPU : 0 | CPU Kit : 26 | |
> > | powerpc/hsc_cm01 : 0 warning(s)
> > | powerpc/icecube : 0 warning(s)
> > | powerpc/mcp750 : 0 warning(s)
> > | powerpc/mpc5566evb : 0 warning(s)
> > | powerpc/mpc5643l_evb : 0 warning(s)
> > | powerpc/mpc5668g : 0 warning(s)
> > | powerpc/mpc5674fevb : 0 warning(s)
> > | powerpc/mpc8260ads : 6 warning(s)
> > | Shared : 0 | BSP : 0 | Network : 352 | Tests
> : 0 |
> > | powerpc/mpc8309som : 0 warning(s)
> > | powerpc/mpc8313erdb : 0 warning(s)
> > | powerpc/mpc8349eamds : 0 warning(s)
> > | powerpc/mtx603e : 0 warning(s)
> > | powerpc/mvme2100 : 0 warning(s)
> > | powerpc/mvme2307 : 0 warning(s)
> > | powerpc/mvme3100 : 3 warning(s)
> > | Shared : 217 | BSP : 0 | Network : 352 | Tests
> : 0 |
> > | powerpc/mvme5500 : 20 warning(s)
> > | Shared : 226 | BSP : 0 | Network : 360 | Tests
> : 0 |
> > | powerpc/pghplus : 1 warning(s)
> : 0 |
> > | powerpc/phycore_mpc5554 : 1 warning(s)
> : 0 |
> > | powerpc/pm520_cr825 : 0 warning(s)
> > | powerpc/pm520_ze30 : 0 warning(s)
> > | powerpc/psim : 1 warning(s)
> : 0 |
> > | powerpc/qemuppc : 1 warning(s)
> : 0 |
> > | powerpc/qemuprep : 0 warning(s)
> > | powerpc/qemuprep-altivec : 0 warning(s)
> > | powerpc/qoriq_core_0 : 0 warning(s)
> > | powerpc/qoriq_core_1 : 0 warning(s)
> > | powerpc/qoriq_e500 : 0 warning(s)
> > | powerpc/qoriq_e6500_32 : 0 warning(s)
> > | powerpc/qoriq_e6500_64 : 14 warning(s)
> > | Shared : 521 | BSP : 0 | Network : 612 | Tests
> : 0 |
> > | LibCPU : 0 | CPU Kit : 231 | |
> > | powerpc/ss555 : 0 warning(s)
> > | powerpc/t32mppc : 2 warning(s)
> : 0 |
> > | LibCPU : 0 | CPU Kit : 35 | |
> > | powerpc/tqm8xx_stk8xx : 1 warning(s)
> : 0 |
> > | powerpc/virtex : 12 warning(s)
> : 0 |
> > | powerpc/virtex4 : 0 warning(s)
> > | powerpc/virtex5 : 0 warning(s)
> > | riscv/rv32i : 0 warning(s)
> > | riscv/rv32iac : 0 warning(s)
> > | riscv/rv32im : 0 warning(s)
> > | riscv/rv32imac : 0 warning(s)
> > | riscv/rv32imafc : 0 warning(s)
> > | riscv/rv32imafd : 0 warning(s)
> > | riscv/rv32imafdc : 0 warning(s)
> > | riscv/rv64imac : 0 warning(s)
> > | riscv/rv64imac_medany : 0 warning(s)
> > | riscv/rv64imafd : 0 warning(s)
> > | riscv/rv64imafd_medany : 0 warning(s)
> > | riscv/rv64imafdc : 0 warning(s)
> > | riscv/rv64imafdc_medany : 0 warning(s)
> > | sh/gensh1 : 1 warning(s)
> : 0 |
> > | sh/gensh2 : 1 warning(s)
> : 0 |
> > | sh/gensh4 : 1 warning(s)
> : 0 |
> > | sh/simsh1 : 0 warning(s)
> > | sh/simsh2 : 0 warning(s)
> > | sh/simsh2e : 0 warning(s)
> > | sh/simsh4 : 0 warning(s)
> > | sparc/at697f : 0 warning(s)
> > | sparc/erc32 : 0 warning(s)
> > | sparc/gr712rc : 0 warning(s)
> > | sparc/gr740 : 0 warning(s)
> > | sparc/leon2 : 0 warning(s)
> > | sparc/leon3 : 0 warning(s)
> > | sparc/ut699 : 0 warning(s)
> > | sparc/ut700 : 0 warning(s)
> > | sparc64/niagara : 0 warning(s)
> > | sparc64/usiii : 1 warning(s)
> > | Shared : 9 | BSP : 0 | Network : 336 | Tests
> : 0 |
> > | LibCPU : 0 | CPU Kit : 42 | |
> > | v850/v850e1sim : 0 warning(s)
> > | v850/v850e2sim : 0 warning(s)
> > | v850/v850e2v3sim : 0 warning(s)
> > | v850/v850esim : 0 warning(s)
> > | v850/v850essim : 0 warning(s)
> > | v850/v850sim : 0 warning(s)
> > | By Build (total : 91686)
> > | common : 707 warning(s)
> > | Shared : 8178 | BSP : 0 |Network : 76150 | Tests
> : 0 |
> > | LibCPU : 312 | CPU Kit : 9452 | |
> > | debug : 0 warning(s)
> > | network : 0 warning(s)
> > | network-debug : 0 warning(s)
> > | no-network : 0 warning(s)
> > | no-posix : 0 warning(s)
> > | posix-debug : 0 warning(s)
> > | posix-profiling : 0 warning(s)
> > | smp : 0 warning(s)
> > | smp-debug : 0 warning(s)
> > | smp-network : 0 warning(s)
> > | smp-network-debug : 0 warning(s)
> > build mailing list
> > build at rtems.org <mailto:build at rtems.org> <mailto:build at rtems.org
> > http://lists.rtems.org/mailman/listinfo/build
> <http://lists.rtems.org/mailman/listinfo/build>
> <http://lists.rtems.org/mailman/listinfo/build>>
> > devel mailing list
> > devel at rtems.org <mailto:devel at rtems.org>
> <http://lists.rtems.org/mailman/listinfo/devel>
> devel mailing list
> devel at rtems.org
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
