[PATCH] Add GMP as a prerequisite for GDB
Chris Johns
chrisj at rtems.org
Tue Dec 15 03:59:31 UTC 2020
Sorry, I have been distracted with other things....
On 14/12/20 5:55 pm, Sebastian Huber wrote:
> On 11/12/2020 14:00, Sebastian Huber wrote:
>> bare/config/devel/gmp-6.1.0.cfg | 18 ++++++++++
>> rtems/config/6/rtems-default.bset | 1 +
>> rtems/config/7/rtems-default.bset | 1 +
>> source-builder/config/gmp.cfg | 60 +++++++++++++++++++++++++++++++
>> 4 files changed, 80 insertions(+)
>> create mode 100644 bare/config/devel/gmp-6.1.0.cfg
>> create mode 100644 source-builder/config/gmp.cfg
> This change breaks the GCC build:
> https://lists.rtems.org/pipermail/devel/2020-December/063751.html
> I have no idea how to fix this. So, currently I am not able to do regular tool
> chain updates which help to catch issues early. For example:
Why is xgcc now dependent on a share libgmp? A FreeBSD gcc does not show any
shared library dependencies other than the standard OS ones. What happens if you
configure the GMP package that is built for gdb with --disable-shared (assuming
it supports it)?
Is gdb picking up a share library reference to it as well?
I have avoided any shared libraries with our tools and I would like to keep it
that way if possible. It is simpler for a number of reasons and what you have
tripped over is one of them.
Another confusing thing is xgcc not using the in tree source for GMP. I assume
that is still present as git master shows it is still in the gcc common recipe.
Is gcc picking up a shared lib over the in tree source?
