Possible Bug in
Thu Dec 17 06:09:40 UTC 2020
On 16/12/2020 21:01, Joel Sherrill wrote:
> Hi
> The context switch recorder code -- _Record_Thread_switch in
> record-userext.c has this code:
>   items[ 0 ].event = RTEMS_RECORD_THREAD_SWITCH_OUT;
>   items[ 0 ].data = executing->Object.id;
>   items[ 1 ].event = RTEMS_RECORD_THREAD_STACK_CURRENT;
>   items[ 1 ].data =
> #if defined(__GNUC__)
>     (uintptr_t) __builtin_frame_address( 0 )
>       - (uintptr_t) executing->Start.Initial_stack.area;
> There isn't a comment about what items[1].data is supposed to be but I
> am assuming it is intended to be stack used. Unfortunately, it doesn't
> conditionalize on stack growing up or down. On the ARM, the stack
> grows down This means on the ARM, it is stack memory remaining.
> I think this needs a comment as to the intent and then some
> conditional logic on CPU_STACK_GROWS_UP like the stack checker has.
> Anyone know what the meaning of the value should be? I suppose
> remaining is good for quick monitoring if the size is captured on say
> create.
Yes, this code is broken. Another issue is that the current stack
pointer belongs to different tasks in SMP and non-SMP configurations. I
am not sure if there is a LTTNG event for the thread stack.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
