MSYS2 build: header file missing
Jiri Gaisler
jiri at gaisler.se
Fri Dec 18 15:34:57 UTC 2020
On 12/18/20 2:10 PM, Robin Müller wrote:
> In case you're interested, this is the fail report for the SIS Cxc build on Linux (failed both for i686 and x86_64).
> I think it fails because _WIN32_WINNT (windows version) is not defined, causing winsock2.h to exclude requires sections.
> Build command was:
> ../source-builder/sb-set-builder --prefix=/c/Users/Robin/RTEMS/rtems-tools/rtems/6 --no-install --bset-tar-file --host=i686-w64-mingw32 6/rtems-sparc
I had a quick look at this. The first problem with missing arpa/inet.h can be fixed by commenting out the include file, as it is not needed:
i686-w64-mingw32-gcc -DHAVE_CONFIG_H -I. -DFAST_UART -O2 -g -pipe -I/home/rmueller/Documents/RTEMS/rtems-tools/src/rsb/rtems/build/tmp/sb-1000/6/rtems-sparc/c/Users/Robin/RTEMS/rtems-tools/rtems/6/include -MT greth.o -MD -MP -MF .deps/greth.Tpo -c -o greth.o greth.c
greth.c:31:10: fatal error: arpa/inet.h: No such file or directory
31 | #include <arpa/inet.h>
The second problem with winsock2.h is not obvious to me. On my old windows7/qemu system, remote.c compiles fine and winsock2.h provides the necessary defines. Which windows version are you using where it fails?
I am about to release a new sis version with more RISCV support, so I could add fixes for MSYS2 if necessary ...
Regards, Jiri.
> Kind Regards
> Robin
> On Fri, 18 Dec 2020 at 12:49, Robin Müller <robin.mueller.m at gmail.com <mailto:robin.mueller.m at gmail.com>> wrote:
> If I understand correctly, the BSPs can be installed with waf only if the tool suite for the given architecture has been installed.
> Problem is, the RSB build will fail even if a tiny component is problematic.
> I thought the tool suite itself is installed using the build commands required by the sources (make, automake, etc).
> Is it possible to also build these sources with waf?
> I have tried this cross compiling on linux for windows (I used x86_64 instead of i686) because everything was working on Linux, but there are issues with the SIS tool for sparc-rtems6..
> But SIS is now also problematic on the Windows machine where I almost managed to build everything.
> Everything except SIS was built by the RSB and I copied the installed files manually to install them and tried to build a BSP (is there actually some script like do-install which will perform this step?)
> But now some RTEMS tool is missing (rtems-bin2c):
> $ ./waf configure --prefix=$RTEMS_TOOLS --rtems-bsp=sparc/erc32
> Setting top to : C:/Users/Robin/Documents/RTEMS/rtems-tools/src/rtems
> Setting out to : C:/Users/Robin/Documents/RTEMS/rtems-tools/src/rtems/build
> Configure board support package (BSP) : sparc/erc32
> Checking for program 'sparc-rtems6-gcc' : C:/Users/Robin/Documents/RTEMS/rtems-tools/rtems/6/bin/sparc-rtems6-gcc.exe
> Checking for program 'sparc-rtems6-g++' : C:/Users/Robin/Documents/RTEMS/rtems-tools/rtems/6/bin/sparc-rtems6-g++.exe
> Checking for program 'sparc-rtems6-ar' : C:/Users/Robin/Documents/RTEMS/rtems-tools/rtems/6/bin/sparc-rtems6-ar.exe
> Checking for program 'sparc-rtems6-ld' : C:/Users/Robin/Documents/RTEMS/rtems-tools/rtems/6/bin/sparc-rtems6-ld.exe
> Checking for program 'ar' : C:/Users/Robin/Documents/RTEMS/rtems-tools/rtems/6/bin/sparc-rtems6-ar.exe
> Checking for program 'g++, c++' : C:/Users/Robin/Documents/RTEMS/rtems-tools/rtems/6/bin/sparc-rtems6-g++.exe
> Checking for program 'gas, gcc' : C:/Users/Robin/Documents/RTEMS/rtems-tools/rtems/6/bin/sparc-rtems6-gcc.exe
> Checking for program 'gcc, cc' : C:/Users/Robin/Documents/RTEMS/rtems-tools/rtems/6/bin/sparc-rtems6-gcc.exe
> Checking for program 'rtems-bin2c' : not found
> Could not find the program ['rtems-bin2c']
> (complete log in C:/Users/Robin/Documents/RTEMS/rtems-tools/src/rtems/build/config.log)
> In general the build process on Windows seems to be more "brittle" than on Linux, so maybe installers would be a good idea? I generally installed cross-compilers (e.g. arm-none-eabi-gcc) on Windows
> using installers (for example https://xpack.github.io/arm-none-eabi-gcc/) and have made very good experience with that.
> Kind Regards
> Robin
> On Fri, 18 Dec 2020 at 12:24, Sebastian Huber <sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 18/12/2020 11:35, Chris Johns wrote:
> >> Since all parts of RTEMS build now with waf I think it is possible to build RTEMS applications on Windows without having to install MSYS2/MinGW. It should work with only a Python installation, but I haven't tested this yet.
> > This maybe true In theory but I have not been able to achieve it.
> What was the missing piece?
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org <mailto:devel at rtems.org>
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201218/3a0b83e3/attachment-0001.html>
