MSYS2 build: header file missing
Robin Müller
robin.mueller.m at gmail.com
Fri Dec 18 16:15:45 UTC 2020
Hi Jiri,
Okay, I commented out that header on my Windows 10 machine (Version 20H2,
19042.685) and it compiled.
That error was on a different Linux machine when cross compiling the cross
toolchain for Windows (i686 rtems6-arm worked now, so that's nice). Maybe
this #define is also derived from the current OS?
I could try to supply it manually..
Kind Regards
Robin
On Fri, 18 Dec 2020 at 16:35, Jiri Gaisler <jiri at gaisler.se> wrote:
> On 12/18/20 2:10 PM, Robin Müller wrote:
> In case you're interested, this is the fail report for the SIS Cxc build
> on Linux (failed both for i686 and x86_64).
> I think it fails because _WIN32_WINNT (windows version) is not defined,
> causing winsock2.h to exclude requires sections.
> Build command was:
> ../source-builder/sb-set-builder
> --prefix=/c/Users/Robin/RTEMS/rtems-tools/rtems/6 --no-install
> --bset-tar-file --host=i686-w64-mingw32 6/rtems-sparc
> I had a quick look at this. The first problem with missing arpa/inet.h can
> be fixed by commenting out the include file, as it is not needed:
> i686-w64-mingw32-gcc -DHAVE_CONFIG_H -I. -DFAST_UART -O2 -g -pipe
> -I/home/rmueller/Documents/RTEMS/rtems-tools/src/rsb/rtems/build/tmp/sb-1000/6/rtems-sparc/c/Users/Robin/RTEMS/rtems-tools/rtems/6/include
> -MT greth.o -MD -MP -MF .deps/greth.Tpo -c -o greth.o greth.c
> greth.c:31:10: fatal error: arpa/inet.h: No such file or directory
> 31 | #include <arpa/inet.h>
> The second problem with winsock2.h is not obvious to me. On my old
> windows7/qemu system, remote.c compiles fine and winsock2.h provides the
> necessary defines. Which windows version are you using where it fails?
> I am about to release a new sis version with more RISCV support, so I
> could add fixes for MSYS2 if necessary ...
> Regards, Jiri.
> Kind Regards
> Robin
> On Fri, 18 Dec 2020 at 12:49, Robin Müller <robin.mueller.m at gmail.com>
> wrote:
>> If I understand correctly, the BSPs can be installed with waf only if the
>> tool suite for the given architecture has been installed.
>> Problem is, the RSB build will fail even if a tiny component is
>> problematic.
>> I thought the tool suite itself is installed using the build commands
>> required by the sources (make, automake, etc).
>> Is it possible to also build these sources with waf?
>> I have tried this cross compiling on linux for windows (I used x86_64
>> instead of i686) because everything was working on Linux, but there are
>> issues with the SIS tool for sparc-rtems6..
>> But SIS is now also problematic on the Windows machine where I almost
>> managed to build everything.
>> Everything except SIS was built by the RSB and I copied the installed
>> files manually to install them and tried to build a BSP (is there actually
>> some script like do-install which will perform this step?)
>> But now some RTEMS tool is missing (rtems-bin2c):
>> $ ./waf configure --prefix=$RTEMS_TOOLS --rtems-bsp=sparc/erc32
>> Setting top to :
>> C:/Users/Robin/Documents/RTEMS/rtems-tools/src/rtems
>> Setting out to :
>> C:/Users/Robin/Documents/RTEMS/rtems-tools/src/rtems/build
>> Configure board support package (BSP) : sparc/erc32
>> Checking for program 'sparc-rtems6-gcc' :
>> C:/Users/Robin/Documents/RTEMS/rtems-tools/rtems/6/bin/sparc-rtems6-gcc.exe
>> Checking for program 'sparc-rtems6-g++' :
>> C:/Users/Robin/Documents/RTEMS/rtems-tools/rtems/6/bin/sparc-rtems6-g++.exe
>> Checking for program 'sparc-rtems6-ar' :
>> C:/Users/Robin/Documents/RTEMS/rtems-tools/rtems/6/bin/sparc-rtems6-ar.exe
>> Checking for program 'sparc-rtems6-ld' :
>> C:/Users/Robin/Documents/RTEMS/rtems-tools/rtems/6/bin/sparc-rtems6-ld.exe
>> Checking for program 'ar' :
>> Checking for program 'g++, c++' :
>> Checking for program 'gas, gcc' :
>> Checking for program 'gcc, cc' :
>> Checking for program 'rtems-bin2c' : not found
>> Could not find the program ['rtems-bin2c']
>> (complete log in
>> C:/Users/Robin/Documents/RTEMS/rtems-tools/src/rtems/build/config.log)
>> In general the build process on Windows seems to be more "brittle" than
>> on Linux, so maybe installers would be a good idea? I generally installed
>> cross-compilers (e.g. arm-none-eabi-gcc) on Windows
>> using installers (for example https://xpack.github.io/arm-none-eabi-gcc/)
>> and have made very good experience with that.
>> Kind Regards
>> Robin
>> On Fri, 18 Dec 2020 at 12:24, Sebastian Huber <
>> sebastian.huber at embedded-brains.de> wrote:
>>> On 18/12/2020 11:35, Chris Johns wrote:
>>> >> Since all parts of RTEMS build now with waf I think it is possible to
>>> build RTEMS applications on Windows without having to install MSYS2/MinGW.
>>> It should work with only a Python installation, but I haven't tested this
>>> yet.
>>> > This maybe true In theory but I have not been able to achieve it.
>>> What was the missing piece?
>>> embedded brains GmbH
>>> Herr Sebastian HUBER
>>> Dornierstr. 4
>>> 82178 Puchheim
>>> Germany
>>> email: sebastian.huber at embedded-brains.de
>>> phone: +49-89-18 94 741 - 16
>>> fax: +49-89-18 94 741 - 08
>>> Registergericht: Amtsgericht München
>>> Registernummer: HRB 157899
>>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>>> Unsere Datenschutzerklärung finden Sie hier:
>>> https://embedded-brains.de/datenschutzerklaerung/
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
> devel mailing listdevel at rtems.orghttp://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201218/8c01eac6/attachment.html>
