MSYS2 build: header file missing
Chris Johns
chrisj at rtems.org
Sun Dec 20 22:40:19 UTC 2020
On 19/12/20 9:51 pm, Robin Müller wrote:
> Thanks for the quick fix. I was able to build sparc-rtems6 on the Windows
> machine with the fix.
Thank you for letting us know.
> So basically, arm-rtesm6 is still problematic because of the missing headers
> (but worked on Linux using Canadian Cross Compiling) but with sparc-rtems6 it's
> the other way around, it works on Windows now, but not on Linux when doing CXC.
> RSB appears to compile SIS for Linux there because it also loads source files
> like line linenoise.c which are not compiled on Windows.
I wonder if the Cxc build failure is the sis build or the RSB recipe?
I test MSYS builds from time to time but I do not test Linux Cxc builds. The
native MSYS2 builds work fine so I have no need.
> In any case, the tool suites are both working now and I managed to build related
> BSPs on Windows without issues using waf.
Nice.
