[PATCH] user: Mention use of LLVM
Sebastian Huber
Tue Dec 22 06:18:33 UTC 2020
user/tracing/eventrecording.rst | 4 ++++
1 file changed, 4 insertions(+)
diff --git a/user/tracing/eventrecording.rst b/user/tracing/eventrecording.rst
index 27e929c..4867db8 100644
--- a/user/tracing/eventrecording.rst
+++ b/user/tracing/eventrecording.rst
@@ -179,6 +179,10 @@ extra support for the
`Linux Trace Toolkit Next Generation (LTTng) <https://lttng.org/>`_. This
format can be analysed using `babeltrace <https://babeltrace.org/>`_ or
`Eclipse Trace Compass <https://www.eclipse.org/tracecompass/>`_.
+The command line tool :file:`rtems-record-lttng` optionally uses
+`LLVM <https://www.llvm.org/>`_ to translate target addresses to functions and
+source file locations. Make sure you have the LLVM development package
+installed when you build the RTEMS Tools to enable this feature.
For example, to get the event records from the record server running on the
target use:
2.26.2
