[PATCH] user: Mention use of LLVM
Tue Dec 22 15:59:30 UTC 2020
On Tue, Dec 22, 2020, 12:18 AM Sebastian Huber <
>  user/tracing/eventrecording.rst | 4 ++++
>  1 file changed, 4 insertions(+)
> diff --git a/user/tracing/eventrecording.rst
> b/user/tracing/eventrecording.rst
> index 27e929c..4867db8 100644
> --- a/user/tracing/eventrecording.rst
> +++ b/user/tracing/eventrecording.rst
> @@ -179,6 +179,10 @@ extra support for the
>  `Linux Trace Toolkit Next Generation (LTTng) <https://lttng.org/>`_.
> This
>  format can be analysed using `babeltrace <https://babeltrace.org/>`_ or
>  `Eclipse Trace Compass <https://www.eclipse.org/tracecompass/>`_.
> +The command line tool :file:`rtems-record-lttng` optionally uses
> +`LLVM <https://www.llvm.org/>`_ to translate target addresses to
> functions and
> +source file locations.  Make sure you have the LLVM development package
> +installed when you build the RTEMS Tools to enable this feature.
Are the llvm development tools an RSB package that should be mentioned? How
does one get them?
And then should rtems-tools always be built with llvm?
>  For example, to get the event records from the record server running on
> the
>  target use:
> 2.26.2
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201222/577a3c1e/attachment.html>
