[PATCH 01/13] libdebugger: Fix for Armv8-R
Sebastian Huber
Tue Dec 22 13:00:58 UTC 2020
This architecture variant has no MMU.
Update #4202.
cpukit/libdebugger/rtems-debugger-arm.c | 7 +++++++
1 file changed, 7 insertions(+)
diff --git a/cpukit/libdebugger/rtems-debugger-arm.c b/cpukit/libdebugger/rtems-debugger-arm.c
index 106cbe8b8a..ba01a860c8 100644
--- a/cpukit/libdebugger/rtems-debugger-arm.c
+++ b/cpukit/libdebugger/rtems-debugger-arm.c
@@ -1678,6 +1678,7 @@ target_exception_data_abort(void)
#if ARM_CP15
+#if __ARM_ARCH_PROFILE == 'A'
* The init value for the text section.
@@ -1701,6 +1702,12 @@ rtems_debugger_target_set_mmu(void)
text_end,
ARMV7_MMU_DATA_READ_WRITE_CACHED);
+#else
+static void
+rtems_debugger_target_set_mmu(void)
+#endif
static void
rtems_debugger_target_set_vectors(void)
2.26.2
