[PATCH 00/13] Add BSP for Arm Fixed Virtual Platform
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Dec 22 20:25:54 UTC 2020
This patch set looks good though it looks like patch 02 should probably have been merged into patch 11.
Kinsey
-----Original Message-----
From: devel <devel-bounces at rtems.org> On Behalf Of Sebastian Huber
Sent: Tuesday, December 22, 2020 07:01
To: devel at rtems.org
Subject: [PATCH 00/13] Add BSP for Arm Fixed Virtual Platform
This patch set adds a BSP to support the Arm Fixed Virtual Platform.
Only the Cortex-R52 processor configuration is supported by the BSP. It
should be easy to add support for other variants if needed.
The patch set consolidates the low-level initialization and moves the
architecture-specific (Armv7-AR and later) initialization from
BSP-specific routines to start.S. This was tested on the following Qemu
BSPs:
* aarch64/xilinx_zynqmp_ilp32
* aarch64/xilinx_zynqmp_lp64
* arm/fvp_cortex_r52
* arm/realview_pbx_a9_qemu
* arm/xilinx_zynq_a9_qemu
Sebastian Huber (13):
libdebugger: Fix for Armv8-R
bsps: Fix includes
arm: Add header file for AArch32 System Registers
arm: Add support for Arm PMSAv8-32
bsps/arm: Set VBAR in start.S
bsps/arm: Invalidate branch predictors earlier
bsps/arm: Remove optional start hook arguments
bsps/arm: Add arm-data-cache-loop-set-way.h
bsps/arm: Clear SCTLR[M, I, A, C] in start.S
bsps/arm: Invalidate TLB in start.S
bsps: Use header file for GIC architecture support
bsps/arm: Rely on initialized vector table
arm/fvp: New BSP
.../dev/irq/arm-gic-arch.h} | 21 +-
.../altera-cyclone-v/start/bspstarthooks.c | 2 -
bsps/arm/beagle/start/bspstarthooks.c | 4 -
bsps/arm/fvp/console/console.c | 83 +
bsps/arm/fvp/console/printk-support.c | 47 +
bsps/arm/fvp/include/bsp.h | 70 +
bsps/arm/fvp/include/bsp/irq.h | 47 +
bsps/arm/fvp/include/bsp/semihosting.h | 130 +
bsps/arm/fvp/include/tm27.h | 1 +
bsps/arm/fvp/start/bspreset.c | 48 +
bsps/arm/fvp/start/bspsmp.c | 49 +
bsps/arm/fvp/start/bspstart.c | 66 +
bsps/arm/fvp/start/bspstarthooks.c | 97 +
bsps/arm/fvp/start/pmsa-sections.c | 56 +
bsps/arm/headers.am | 1 -
bsps/arm/imx/start/bspstarthooks.c | 1 -
bsps/arm/include/bsp/arm-a8core-start.h | 55 -
bsps/arm/include/bsp/arm-a9mpcore-start.h | 29 +-
bsps/arm/include/bsp/start.h | 13 +-
.../dev/cache/arm-data-cache-loop-set-way.h | 96 +
.../dev/irq/arm-gic-arch.h} | 27 +-
bsps/arm/raspberrypi/start/bspsmp_init.c | 5 +-
bsps/arm/raspberrypi/start/bspstarthooks.c | 52 +-
.../shared/cache/cache-v7ar-disable-data.S | 71 +-
bsps/arm/shared/start/start.S | 142 +-
bsps/arm/xen/start/bspstarthooks.c | 2 -
bsps/arm/xilinx-zynq/start/bspstarthooks.c | 36 -
bsps/arm/xilinx-zynqmp/start/bspstarthooks.c | 43 +-
bsps/include/dev/irq/arm-gic-irq.h | 13 -
bsps/shared/dev/irq/arm-gicv2.c | 1 +
bsps/shared/dev/irq/arm-gicv3.c | 7 +
.../libbsp/arm/altera-cyclone-v/Makefile.am | 1 -
c/src/lib/libbsp/arm/imx/Makefile.am | 1 -
.../libbsp/arm/realview-pbx-a9/Makefile.am | 1 -
c/src/lib/libbsp/arm/xen/Makefile.am | 1 -
c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am | 1 -
.../lib/libbsp/arm/xilinx-zynqmp/Makefile.am | 1 -
cpukit/libdebugger/rtems-debugger-arm.c | 7 +
.../score/cpu/arm/aarch32-psma-init-default.c | 60 +
cpukit/score/cpu/arm/aarch32-psma-init.c | 194 +
.../arm/include/rtems/score/aarch32-pmsa.h | 314 +
.../rtems/score/aarch32-system-registers.h | 14657 ++++++++++++++++
spec/build/bsps/aarch64/a53/obj.yml | 1 -
spec/build/bsps/aarch64/grp.yml | 1 +
spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml | 1 -
.../altera-cyclone-v/bspalteracyclonev.yml | 1 -
spec/build/bsps/arm/fvp/abi.yml | 20 +
spec/build/bsps/arm/fvp/bspcortexr52.yml | 19 +
spec/build/bsps/arm/fvp/grp.yml | 58 +
spec/build/bsps/arm/fvp/linkcmds.yml | 53 +
spec/build/bsps/arm/fvp/obj.yml | 44 +
spec/build/bsps/arm/fvp/objsmp.yml | 16 +
spec/build/bsps/arm/fvp/optdevbegin.yml | 22 +
spec/build/bsps/arm/fvp/optdevsize.yml | 18 +
spec/build/bsps/arm/fvp/optdrambegin.yml | 22 +
spec/build/bsps/arm/fvp/optdramsize.yml | 23 +
spec/build/bsps/arm/fvp/optnullsize.yml | 21 +
spec/build/bsps/arm/grp.yml | 2 +-
spec/build/bsps/arm/imx/bspimx.yml | 1 -
spec/build/bsps/arm/optgiccpuif.yml | 19 +
spec/build/bsps/arm/optgicdist.yml | 19 +
spec/build/bsps/arm/optgicredist.yml | 19 +
spec/build/bsps/arm/optgicspicount.yml | 17 +
spec/build/bsps/arm/optgtfreq.yml | 5 +-
.../arm/realview-pbx-a9/bsprealviewpbxa9.yml | 1 -
spec/build/bsps/arm/xen/bspxen.yml | 1 -
spec/build/bsps/arm/xilinx-zynq/obj.yml | 1 -
.../arm/xilinx-zynqmp/bspxilinxzynqmp.yml | 1 -
spec/build/cpukit/cpuarm.yml | 2 +
spec/build/cpukit/optsmp.yml | 1 +
70 files changed, 16589 insertions(+), 373 deletions(-)
rename bsps/aarch64/{shared/irq/irq-arm-gicvx-aarch64.c => include/dev/irq/arm-gic-arch.h} (84%)
create mode 100644 bsps/arm/fvp/console/console.c
create mode 100644 bsps/arm/fvp/console/printk-support.c
create mode 100644 bsps/arm/fvp/include/bsp.h
create mode 100644 bsps/arm/fvp/include/bsp/irq.h
create mode 100644 bsps/arm/fvp/include/bsp/semihosting.h
create mode 100644 bsps/arm/fvp/include/tm27.h
create mode 100644 bsps/arm/fvp/start/bspreset.c
create mode 100644 bsps/arm/fvp/start/bspsmp.c
create mode 100644 bsps/arm/fvp/start/bspstart.c
create mode 100644 bsps/arm/fvp/start/bspstarthooks.c
create mode 100644 bsps/arm/fvp/start/pmsa-sections.c
delete mode 100644 bsps/arm/include/bsp/arm-a8core-start.h
create mode 100644 bsps/arm/include/dev/cache/arm-data-cache-loop-set-way.h
rename bsps/arm/{shared/irq/irq-arm-gicvx-aarch32.c => include/dev/irq/arm-gic-arch.h} (79%)
create mode 100644 cpukit/score/cpu/arm/aarch32-psma-init-default.c
create mode 100644 cpukit/score/cpu/arm/aarch32-psma-init.c
create mode 100644 cpukit/score/cpu/arm/include/rtems/score/aarch32-pmsa.h
create mode 100644 cpukit/score/cpu/arm/include/rtems/score/aarch32-system-registers.h
create mode 100644 spec/build/bsps/arm/fvp/abi.yml
create mode 100644 spec/build/bsps/arm/fvp/bspcortexr52.yml
create mode 100644 spec/build/bsps/arm/fvp/grp.yml
create mode 100644 spec/build/bsps/arm/fvp/linkcmds.yml
create mode 100644 spec/build/bsps/arm/fvp/obj.yml
create mode 100644 spec/build/bsps/arm/fvp/objsmp.yml
create mode 100644 spec/build/bsps/arm/fvp/optdevbegin.yml
create mode 100644 spec/build/bsps/arm/fvp/optdevsize.yml
create mode 100644 spec/build/bsps/arm/fvp/optdrambegin.yml
create mode 100644 spec/build/bsps/arm/fvp/optdramsize.yml
create mode 100644 spec/build/bsps/arm/fvp/optnullsize.yml
create mode 100644 spec/build/bsps/arm/optgiccpuif.yml
create mode 100644 spec/build/bsps/arm/optgicdist.yml
create mode 100644 spec/build/bsps/arm/optgicredist.yml
create mode 100644 spec/build/bsps/arm/optgicspicount.yml
2.26.2
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
