[PATCH 12/13] bsps/arm: Rely on initialized vector table
Sebastian Huber
Tue Dec 22 13:01:09 UTC 2020
The arm_cp15_set_exception_handler() is a complicated function which
should be avoided if possible.
Update #4202.
bsps/arm/include/dev/irq/arm-gic-arch.h | 9 ++++-----
1 file changed, 4 insertions(+), 5 deletions(-)
diff --git a/bsps/arm/include/dev/irq/arm-gic-arch.h b/bsps/arm/include/dev/irq/arm-gic-arch.h
index fe981da4f7..c9931be61a 100644
--- a/bsps/arm/include/dev/irq/arm-gic-arch.h
+++ b/bsps/arm/include/dev/irq/arm-gic-arch.h
@@ -37,7 +37,6 @@
#ifndef _RTEMS_DEV_IRQ_ARM_GIC_ARM_H
#define _RTEMS_DEV_IRQ_ARM_GIC_ARM_H
-#include <libcpu/arm-cp15.h>
#include <bsp/irq-generic.h>
#include <rtems/score/armv4.h>
@@ -55,10 +54,10 @@ static inline void arm_interrupt_handler_dispatch(rtems_vector_number vector)
static inline void arm_interrupt_facility_set_exception_handler(void)
- arm_cp15_set_exception_handler(
- ARM_EXCEPTION_IRQ,
- _ARMV4_Exception_interrupt
+ * There is no need to install _ARMV4_Exception_interrupt() since this
+ * handler is already set by start.S.
#ifdef __cplusplus
2.26.2
