[PATCH 11/13] bsps: Use header file for GIC architecture support
Sebastian Huber
Tue Dec 22 13:01:08 UTC 2020
This avoids a function call overhead in the interrupt dispatching.
Update #4202.
.../dev/irq/arm-gic-arch.h} | 20 ++++++++++++++++---
.../dev/irq/arm-gic-arch.h} | 18 ++++++++++++++---
bsps/include/dev/irq/arm-gic-irq.h | 13 ------------
bsps/shared/dev/irq/arm-gicv2.c | 1 +
bsps/shared/dev/irq/arm-gicv3.c | 1 +
.../libbsp/arm/altera-cyclone-v/Makefile.am | 1 -
c/src/lib/libbsp/arm/imx/Makefile.am | 1 -
.../libbsp/arm/realview-pbx-a9/Makefile.am | 1 -
c/src/lib/libbsp/arm/xen/Makefile.am | 1 -
c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am | 1 -
.../lib/libbsp/arm/xilinx-zynqmp/Makefile.am | 1 -
spec/build/bsps/aarch64/a53/obj.yml | 1 -
spec/build/bsps/aarch64/grp.yml | 1 +
spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml | 1 -
.../altera-cyclone-v/bspalteracyclonev.yml | 1 -
spec/build/bsps/arm/grp.yml | 1 +
spec/build/bsps/arm/imx/bspimx.yml | 1 -
.../arm/realview-pbx-a9/bsprealviewpbxa9.yml | 1 -
spec/build/bsps/arm/xen/bspxen.yml | 1 -
spec/build/bsps/arm/xilinx-zynq/obj.yml | 1 -
.../arm/xilinx-zynqmp/bspxilinxzynqmp.yml | 1 -
21 files changed, 36 insertions(+), 33 deletions(-)
rename bsps/aarch64/{shared/irq/irq-arm-gicvx-aarch64.c => include/dev/irq/arm-gic-arch.h} (84%)
rename bsps/arm/{shared/irq/irq-arm-gicvx-aarch32.c => include/dev/irq/arm-gic-arch.h} (84%)
diff --git a/bsps/aarch64/shared/irq/irq-arm-gicvx-aarch64.c b/bsps/aarch64/include/dev/irq/arm-gic-arch.h
similarity index 84%
rename from bsps/aarch64/shared/irq/irq-arm-gicvx-aarch64.c
rename to bsps/aarch64/include/dev/irq/arm-gic-arch.h
index 4c26ec3c2b..c3332faf42 100644
--- a/bsps/aarch64/shared/irq/irq-arm-gicvx-aarch64.c
+++ b/bsps/aarch64/include/dev/irq/arm-gic-arch.h
@@ -34,10 +34,18 @@
* POSSIBILITY OF SUCH DAMAGE.
-#include <dev/irq/arm-gic-irq.h>
+#ifndef _RTEMS_DEV_IRQ_ARM_GIC_AARCH64_H
+#define _RTEMS_DEV_IRQ_ARM_GIC_AARCH64_H
+#include <rtems/score/cpu.h>
#include <bsp/irq-generic.h>
-void arm_interrupt_handler_dispatch(rtems_vector_number vector)
+#ifdef __cplusplus
+extern "C" {
+#endif
+static inline void arm_interrupt_handler_dispatch(rtems_vector_number vector)
uint32_t interrupt_level = _CPU_ISR_Get_level();
AArch64_interrupt_enable(1);
@@ -45,7 +53,7 @@ void arm_interrupt_handler_dispatch(rtems_vector_number vector)
_CPU_ISR_Set_level(interrupt_level);
-void arm_interrupt_facility_set_exception_handler(void)
+static inline void arm_interrupt_facility_set_exception_handler(void)
AArch64_set_exception_handler(
AARCH64_EXCEPTION_SPx_IRQ,
@@ -56,3 +64,9 @@ void arm_interrupt_facility_set_exception_handler(void)
_AArch64_Exception_interrupt_nest
+#ifdef __cplusplus
+#endif
+#endif /* _RTEMS_DEV_IRQ_ARM_GIC_AARCH64_H */
diff --git a/bsps/arm/shared/irq/irq-arm-gicvx-aarch32.c b/bsps/arm/include/dev/irq/arm-gic-arch.h
rename from bsps/arm/shared/irq/irq-arm-gicvx-aarch32.c
rename to bsps/arm/include/dev/irq/arm-gic-arch.h
index 7c0462d04d..fe981da4f7 100644
--- a/bsps/arm/shared/irq/irq-arm-gicvx-aarch32.c
+++ b/bsps/arm/include/dev/irq/arm-gic-arch.h
@@ -34,12 +34,18 @@
+#ifndef _RTEMS_DEV_IRQ_ARM_GIC_ARM_H
+#define _RTEMS_DEV_IRQ_ARM_GIC_ARM_H
#include <libcpu/arm-cp15.h>
#include <rtems/score/armv4.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
uint32_t psr = _ARMV4_Status_irq_enable();
bsp_interrupt_handler_dispatch(vector);
@@ -47,10 +53,16 @@ void arm_interrupt_handler_dispatch(rtems_vector_number vector)
_ARMV4_Status_restore(psr);
arm_cp15_set_exception_handler(
ARM_EXCEPTION_IRQ,
_ARMV4_Exception_interrupt
+#ifdef __cplusplus
+#endif
+#endif /* _RTEMS_DEV_IRQ_ARM_GIC_ARM_H */
diff --git a/bsps/include/dev/irq/arm-gic-irq.h b/bsps/include/dev/irq/arm-gic-irq.h
index 5270331624..5ce9d54684 100644
--- a/bsps/include/dev/irq/arm-gic-irq.h
+++ b/bsps/include/dev/irq/arm-gic-irq.h
@@ -97,19 +97,6 @@ static inline rtems_status_code arm_gic_irq_generate_software_irq(
return sc;
- * This architecture-specific function sets the exception vector for handling
- * IRQs.
-void arm_interrupt_facility_set_exception_handler(void);
- * This architecture-specific function dispatches a triggered IRQ.
- * @param[in] vector The vector on which the IRQ occurred.
-void arm_interrupt_handler_dispatch(rtems_vector_number vector);
uint32_t arm_gic_irq_processor_count(void);
void arm_gic_irq_initialize_secondary_cpu(void);
diff --git a/bsps/shared/dev/irq/arm-gicv2.c b/bsps/shared/dev/irq/arm-gicv2.c
index 74989a4de5..c29cae1d97 100644
--- a/bsps/shared/dev/irq/arm-gicv2.c
+++ b/bsps/shared/dev/irq/arm-gicv2.c
@@ -13,6 +13,7 @@
#include <dev/irq/arm-gic.h>
+#include <dev/irq/arm-gic-arch.h>
#include <bsp/irq.h>
diff --git a/bsps/shared/dev/irq/arm-gicv3.c b/bsps/shared/dev/irq/arm-gicv3.c
index 77128adb5b..113b840068 100644
--- a/bsps/shared/dev/irq/arm-gicv3.c
+++ b/bsps/shared/dev/irq/arm-gicv3.c
@@ -26,6 +26,7 @@
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am b/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am
index 22be647261..314808ee6c 100644
--- a/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am
@@ -63,7 +63,6 @@ endif
# IRQ
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-default-handler.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/irq/arm-gicv2.c
-librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/irq/irq-arm-gicvx-aarch32.c
# Console
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termios-init.c
diff --git a/c/src/lib/libbsp/arm/imx/Makefile.am b/c/src/lib/libbsp/arm/imx/Makefile.am
index caef3c6170..fc66b7964e 100644
--- a/c/src/lib/libbsp/arm/imx/Makefile.am
+++ b/c/src/lib/libbsp/arm/imx/Makefile.am
@@ -52,7 +52,6 @@ endif
# IRQ
# Console
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termios.c
diff --git a/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am b/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
index d1597068ef..19a8529d9c 100644
--- a/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
+++ b/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
@@ -57,7 +57,6 @@ endif
# IRQ
# Console
diff --git a/c/src/lib/libbsp/arm/xen/Makefile.am b/c/src/lib/libbsp/arm/xen/Makefile.am
index e01c33deb5..c1a6251e86 100644
--- a/c/src/lib/libbsp/arm/xen/Makefile.am
+++ b/c/src/lib/libbsp/arm/xen/Makefile.am
@@ -36,7 +36,6 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cache/cache-cp15.c
# irq
# console
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xen/console/console.c
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
index a4b9496630..8804dc40da 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
@@ -56,7 +56,6 @@ endif
# IRQ
# Console
diff --git a/c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am b/c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am
index 11d6ab8039..21db56a0ea 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am
+++ b/c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am
# IRQ
# Console
diff --git a/spec/build/bsps/aarch64/a53/obj.yml b/spec/build/bsps/aarch64/a53/obj.yml
index 0d69b59416..235191742e 100644
--- a/spec/build/bsps/aarch64/a53/obj.yml
+++ b/spec/build/bsps/aarch64/a53/obj.yml
@@ -30,7 +30,6 @@ source:
- bsps/shared/start/sbrk.c
- bsps/shared/dev/irq/arm-gicv3.c
- bsps/shared/irq/irq-default-handler.c
-- bsps/aarch64/shared/irq/irq-arm-gicvx-aarch64.c
- bsps/shared/dev/btimer/btimer-cpucounter.c
- bsps/shared/dev/clock/arm-generic-timer.c
- bsps/aarch64/shared/clock/arm-generic-timer-aarch64.c
diff --git a/spec/build/bsps/aarch64/grp.yml b/spec/build/bsps/aarch64/grp.yml
index 1b8dc1c629..a6bc0d5a31 100644
--- a/spec/build/bsps/aarch64/grp.yml
+++ b/spec/build/bsps/aarch64/grp.yml
@@ -14,6 +14,7 @@ install:
- bsps/include/dev/clock/arm-generic-timer.h
- destination: ${BSP_INCLUDEDIR}/dev/irq
source:
+ - bsps/aarch64/include/dev/irq/arm-gic-arch.h
- bsps/include/dev/irq/arm-gic-irq.h
- bsps/include/dev/irq/arm-gic-regs.h
- bsps/include/dev/irq/arm-gic-tm27.h
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml
index 2ca4ef093b..c1a859af85 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml
@@ -29,7 +29,6 @@ source:
- bsps/shared/start/bspreset-arm-psci.c
- bsps/shared/dev/irq/arm-gicv2.c
diff --git a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
index c6732c4d47..b4b43ab106 100644
--- a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
+++ b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
@@ -129,7 +129,6 @@ source:
- bsps/arm/shared/cp15/arm-cp15-set-exception-handler.c
- bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
-- bsps/arm/shared/irq/irq-arm-gicvx-aarch32.c
- bsps/arm/shared/start/bsp-start-memcpy.S
- bsps/shared/dev/btimer/btimer-stub.c
- bsps/shared/dev/getentropy/getentropy-cpucounter.c
diff --git a/spec/build/bsps/arm/grp.yml b/spec/build/bsps/arm/grp.yml
index 408288044f..dbd21638fd 100644
--- a/spec/build/bsps/arm/grp.yml
+++ b/spec/build/bsps/arm/grp.yml
@@ -37,6 +37,7 @@ install:
- bsps/arm/include/bsp/start.h
source:
+ - bsps/arm/include/dev/irq/arm-gic-arch.h
diff --git a/spec/build/bsps/arm/imx/bspimx.yml b/spec/build/bsps/arm/imx/bspimx.yml
index 93628f0368..386a769bc0 100644
--- a/spec/build/bsps/arm/imx/bspimx.yml
+++ b/spec/build/bsps/arm/imx/bspimx.yml
@@ -97,7 +97,6 @@ source:
diff --git a/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml b/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml
index 6233aae2f0..2eb06e5348 100644
--- a/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml
+++ b/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml
@@ -68,7 +68,6 @@ source:
- bsps/arm/shared/fb/arm-pl111.c
- bsps/arm/shared/serial/arm-pl050.c
diff --git a/spec/build/bsps/arm/xen/bspxen.yml b/spec/build/bsps/arm/xen/bspxen.yml
index 1a3db8d172..c8de39a4f7 100644
--- a/spec/build/bsps/arm/xen/bspxen.yml
+++ b/spec/build/bsps/arm/xen/bspxen.yml
@@ -64,7 +64,6 @@ source:
- bsps/arm/xen/console/console.c
- bsps/arm/xen/start/bspstart.c
diff --git a/spec/build/bsps/arm/xilinx-zynq/obj.yml b/spec/build/bsps/arm/xilinx-zynq/obj.yml
index c2dde615b8..6602b20a03 100644
--- a/spec/build/bsps/arm/xilinx-zynq/obj.yml
+++ b/spec/build/bsps/arm/xilinx-zynq/obj.yml
@@ -25,7 +25,6 @@ source:
- bsps/arm/xilinx-zynq/console/console-config.c
- bsps/arm/xilinx-zynq/console/console-init.c
diff --git a/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml b/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
index b8cc1c043c..51d3268e99 100644
--- a/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
+++ b/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
@@ -82,7 +82,6 @@ source:
- bsps/arm/xilinx-zynqmp/console/console-config.c
- bsps/arm/xilinx-zynqmp/start/bspreset.c
2.26.2
