[PATCH] user: Mention use of LLVM
Sebastian Huber
Tue Dec 22 18:28:39 UTC 2020
On 22/12/2020 16:59, Joel Sherrill wrote:
> On Tue, Dec 22, 2020, 12:18 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> user/tracing/eventrecording.rst | 4 ++++
> 1 file changed, 4 insertions(+)
> diff --git a/user/tracing/eventrecording.rst
> b/user/tracing/eventrecording.rst
> index 27e929c..4867db8 100644
> --- a/user/tracing/eventrecording.rst
> +++ b/user/tracing/eventrecording.rst
> @@ -179,6 +179,10 @@ extra support for the
> `Linux Trace Toolkit Next Generation (LTTng) <https://lttng.org/
> <https://lttng.org/>>`_. This
> format can be analysed using `babeltrace <https://babeltrace.org/
> <https://babeltrace.org/>>`_ or
> `Eclipse Trace Compass <https://www.eclipse.org/tracecompass/
> <https://www.eclipse.org/tracecompass/>>`_.
> +The command line tool :file:`rtems-record-lttng` optionally uses
> +`LLVM <https://www.llvm.org/ <https://www.llvm.org/>>`_ to
> translate target addresses to functions and
> +source file locations. Make sure you have the LLVM development
> package
> +installed when you build the RTEMS Tools to enable this feature.
> Are the llvm development tools an RSB package that should be
> mentioned? How does one get them?
There is an RSB package for this, but it didn't work for me. I use the
package from my Linux distribution.
> And then should rtems-tools always be built with llvm?
I think this would be a bit of an overkill for an optional feature.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
