[rtems-bsp-builder] 2020-12-21 07:39:31: Profile(s): everything
Chris Johns
chrisj at rtems.org
Wed Dec 23 08:17:55 UTC 2020
> On 23 Dec 2020, at 5:31 am, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 22/12/2020 18:54, Joel Sherrill wrote:
>> On Tue, Dec 22, 2020, 10:28 AM Sebastian Huber <sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>> wrote:
>> On 22/12/2020 17:00, Joel Sherrill wrote:
>> > On Tue, Dec 22, 2020, 8:14 AM Sebastian Huber
>> <mailto:sebastian.huber at embedded-brains.de>>> wrote:
>> > On 22/12/2020 10:53, joel at rtems.org <mailto:joel at rtems.org>
>> <mailto:joel at rtems.org <mailto:joel at rtems.org>> wrote:
>> > > Failures Report
>> > > No failures
>> > Time to remove the old build system?
>> > If the bsp tester had been converted to waf.
>> > This was not my script which builds every bsp with waf and autoconf
>> Maintaining the old build system needs time and this time is not
>> available to convert existing tools to use the new build system.
>> I don't understand this statement. The rtems-bsp-builder was added to rtems-tools in 2016. It, along with rtems-tester, are the key linchpins in the tier definitions and their enforcement.
> I have too many loose ends to deal with at the moment.
I am deep in NFSv4 so if we can please discuss this next year I would appreciate it. I understand it is important.
