[PATCH] cpukit: Merge FreeBSD values for the priorities
chrisj at rtems.org
chrisj at rtems.org
Wed Dec 23 19:36:03 UTC 2020
It seems we need valid values or assumptions in the FreeBSD about
these values breaks some of the code.
Closes #4207
cpukit/include/sys/priority.h | 102 ++++++++++++++++++++++++++++------
1 file changed, 85 insertions(+), 17 deletions(-)
diff --git a/cpukit/include/sys/priority.h b/cpukit/include/sys/priority.h
index 025de6290c..855edb63c2 100644
--- a/cpukit/include/sys/priority.h
+++ b/cpukit/include/sys/priority.h
@@ -1,5 +1,7 @@
- * Copyright (c) 2015 embedded brains GmbH
+ * SPDX-License-Identifier: BSD-4-Clause
+ * Copyright (c) 1994, Henrik Vestergaard Draboel
* All rights reserved.
@@ -10,6 +12,11 @@
* 2. Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
+ * 3. All advertising materials mentioning features or use of this software
+ * must display the following acknowledgement:
+ * This product includes software developed by Henrik Vestergaard Draboel.
+ * 4. The name of the author may not be used to endorse or promote products
+ * derived from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
@@ -22,23 +29,84 @@
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
* SUCH DAMAGE.
+ * $FreeBSD$
#ifndef _SYS_PRIORITY_H_
-#define _SYS_PRIORITY_H_
-/* Dummy values to make the libbsd happy */
-#define PRI_MAX_ITHD 0
-#define PI_NET 0
-#define PI_DISK 0
-#define PI_SOFT 0
-#define PI_SWI(x) 0
-#define PRI_MIN_KERN 0
-#define PVM 0
-#define PRIBIO 0
-#define PZERO 0
-#define PSOCK 0
-#define PWAIT 0
-#define PPAUSE 0
+#define _SYS_PRIORITY_H_
+ * Process priority specifications.
+ * Priority classes.
+#define PRI_ITHD 1 /* Interrupt thread. */
+#define PRI_REALTIME 2 /* Real time process. */
+#define PRI_TIMESHARE 3 /* Time sharing process. */
+#define PRI_IDLE 4 /* Idle process. */
+ * Priorities range from 0 to 255, but differences of less then 4 (RQ_PPQ)
+ * are insignificant. Ranges are as follows:
+ * Interrupt threads: 0 - 47
+ * Realtime user threads: 48 - 79
+ * Top half kernel threads: 80 - 119
+ * Time sharing user threads: 120 - 223
+ * Idle user threads: 224 - 255
+ * XXX If/When the specific interrupt thread and top half thread ranges
+ * disappear, a larger range can be used for user processes.
+#define PRI_MIN (0) /* Highest priority. */
+#define PRI_MAX (255) /* Lowest priority. */
+#define PRI_MIN_ITHD (PRI_MIN)
+#define PRI_MAX_ITHD (PRI_MIN_REALTIME - 1)
+#define PI_REALTIME (PRI_MIN_ITHD + 0)
+#define PI_AV (PRI_MIN_ITHD + 4)
+#define PI_NET (PRI_MIN_ITHD + 8)
+#define PI_DISK (PRI_MIN_ITHD + 12)
+#define PI_TTY (PRI_MIN_ITHD + 16)
+#define PI_DULL (PRI_MIN_ITHD + 20)
+#define PI_SOFT (PRI_MIN_ITHD + 24)
+#define PI_SWI(x) (PI_SOFT + (x) * RQ_PPQ)
+#define PRI_MIN_REALTIME (48)
+#define PRI_MAX_REALTIME (PRI_MIN_KERN - 1)
+#define PRI_MIN_KERN (80)
+#define PRI_MAX_KERN (PRI_MIN_TIMESHARE - 1)
+#define PSWP (PRI_MIN_KERN + 0)
+#define PVM (PRI_MIN_KERN + 4)
+#define PINOD (PRI_MIN_KERN + 8)
+#define PRIBIO (PRI_MIN_KERN + 12)
+#define PVFS (PRI_MIN_KERN + 16)
+#define PZERO (PRI_MIN_KERN + 20)
+#define PSOCK (PRI_MIN_KERN + 24)
+#define PWAIT (PRI_MIN_KERN + 28)
+#define PLOCK (PRI_MIN_KERN + 32)
+#define PPAUSE (PRI_MIN_KERN + 36)
+#define PRI_MIN_TIMESHARE (120)
+#define PRI_MAX_TIMESHARE (PRI_MIN_IDLE - 1)
+#define PUSER (PRI_MIN_TIMESHARE)
+#define PRI_MIN_IDLE (224)
+#define PRI_MAX_IDLE (PRI_MAX)
+#ifdef _KERNEL
+/* Other arguments for kern_yield(9). */
+#define PRI_USER -2 /* Change to current user priority. */
+#define PRI_UNCHANGED -1 /* Do not change priority. */
+#endif
#endif /* !_SYS_PRIORITY_H_ */
2.24.1
