[PATCH] cpukit: Merge FreeBSD values for the priorities
Joel Sherrill
joel at rtems.org
Wed Dec 23 22:20:17 UTC 2020
This looks ok if these priorities are mapped to Classic or Score. POSIX
thread priorities run opposite.
On Wed, Dec 23, 2020, 2:36 PM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> It seems we need valid values or assumptions in the FreeBSD about
> these values breaks some of the code.
> Closes #4207
> cpukit/include/sys/priority.h | 102 ++++++++++++++++++++++++++++------
> 1 file changed, 85 insertions(+), 17 deletions(-)
> diff --git a/cpukit/include/sys/priority.h b/cpukit/include/sys/priority.h
> index 025de6290c..855edb63c2 100644
> --- a/cpukit/include/sys/priority.h
> +++ b/cpukit/include/sys/priority.h
> @@ -1,5 +1,7 @@
> - * Copyright (c) 2015 embedded brains GmbH
> + * SPDX-License-Identifier: BSD-4-Clause
> + * Copyright (c) 1994, Henrik Vestergaard Draboel
> * All rights reserved.
> * Redistribution and use in source and binary forms, with or without
> @@ -10,6 +12,11 @@
> * 2. Redistributions in binary form must reproduce the above copyright
> * notice, this list of conditions and the following disclaimer in the
> * documentation and/or other materials provided with the distribution.
> + * 3. All advertising materials mentioning features or use of this
> software
> + * must display the following acknowledgement:
> + * This product includes software developed by Henrik Vestergaard
> Draboel.
> + * 4. The name of the author may not be used to endorse or promote
> products
> + * derived from this software without specific prior written
> permission.
> * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
> * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> @@ -22,23 +29,84 @@
> * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY
> WAY
> * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> * SUCH DAMAGE.
> + * $FreeBSD$
> #ifndef _SYS_PRIORITY_H_
> -#define _SYS_PRIORITY_H_
> -/* Dummy values to make the libbsd happy */
> -#define PRI_MAX_ITHD 0
> -#define PI_NET 0
> -#define PI_DISK 0
> -#define PI_SOFT 0
> -#define PI_SWI(x) 0
> -#define PRI_MIN_KERN 0
> -#define PVM 0
> -#define PRIBIO 0
> -#define PZERO 0
> -#define PSOCK 0
> -#define PWAIT 0
> -#define PPAUSE 0
> +#define _SYS_PRIORITY_H_
> + * Process priority specifications.
> + * Priority classes.
> +#define PRI_ITHD 1 /* Interrupt thread. */
> +#define PRI_REALTIME 2 /* Real time process. */
> +#define PRI_TIMESHARE 3 /* Time sharing process. */
> +#define PRI_IDLE 4 /* Idle process. */
> + * Priorities range from 0 to 255, but differences of less then 4 (RQ_PPQ)
> + * are insignificant. Ranges are as follows:
> + * Interrupt threads: 0 - 47
> + * Realtime user threads: 48 - 79
> + * Top half kernel threads: 80 - 119
> + * Time sharing user threads: 120 - 223
> + * Idle user threads: 224 - 255
> + * XXX If/When the specific interrupt thread and top half thread ranges
> + * disappear, a larger range can be used for user processes.
> +#define PRI_MIN (0) /* Highest priority. */
> +#define PRI_MAX (255) /* Lowest priority. */
> +#define PRI_MIN_ITHD (PRI_MIN)
> +#define PRI_MAX_ITHD (PRI_MIN_REALTIME - 1)
> +#define PI_REALTIME (PRI_MIN_ITHD + 0)
> +#define PI_AV (PRI_MIN_ITHD + 4)
> +#define PI_NET (PRI_MIN_ITHD + 8)
> +#define PI_DISK (PRI_MIN_ITHD + 12)
> +#define PI_TTY (PRI_MIN_ITHD + 16)
> +#define PI_DULL (PRI_MIN_ITHD + 20)
> +#define PI_SOFT (PRI_MIN_ITHD + 24)
> +#define PI_SWI(x) (PI_SOFT + (x) * RQ_PPQ)
> +#define PRI_MIN_REALTIME (48)
> +#define PRI_MAX_REALTIME (PRI_MIN_KERN - 1)
> +#define PRI_MIN_KERN (80)
> +#define PRI_MAX_KERN (PRI_MIN_TIMESHARE - 1)
> +#define PSWP (PRI_MIN_KERN + 0)
> +#define PVM (PRI_MIN_KERN + 4)
> +#define PINOD (PRI_MIN_KERN + 8)
> +#define PRIBIO (PRI_MIN_KERN + 12)
> +#define PVFS (PRI_MIN_KERN + 16)
> +#define PZERO (PRI_MIN_KERN + 20)
> +#define PSOCK (PRI_MIN_KERN + 24)
> +#define PWAIT (PRI_MIN_KERN + 28)
> +#define PLOCK (PRI_MIN_KERN + 32)
> +#define PPAUSE (PRI_MIN_KERN + 36)
> +#define PRI_MIN_TIMESHARE (120)
> +#define PRI_MAX_TIMESHARE (PRI_MIN_IDLE - 1)
> +#define PUSER (PRI_MIN_TIMESHARE)
> +#define PRI_MIN_IDLE (224)
> +#define PRI_MAX_IDLE (PRI_MAX)
> +#ifdef _KERNEL
> +/* Other arguments for kern_yield(9). */
> +#define PRI_USER -2 /* Change to current user priority. */
> +#define PRI_UNCHANGED -1 /* Do not change priority. */
> +#endif
> #endif /* !_SYS_PRIORITY_H_ */
> 2.24.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201223/66708898/attachment.html>
