Fwd: Build FreeBSD: FAILED 6/rtems-moxie on x86_64-freebsd12.2 (dtc-1.6.0-x86_64-freebsd12.2-1)
Mon Dec 28 23:15:23 UTC 2020
Is this failure because a yaml package is missing on this computer?
https://lists.rtems.org/pipermail/build/2020-December/023256.html
If so, which package is it? Seems like we need to update the documentation.
--joel
---------- Forwarded message ---------
Date: Mon, Dec 28, 2020, 5:02 PM
Subject: Build FreeBSD: FAILED 6/rtems-moxie on x86_64-freebsd12.2
To: <build at rtems.org>
RTEMS Source Builder - Set Builder, 6 (d3dc0bc38613)
Host: FreeBSD-12.2-RELEASE-amd64-64bit-ELF
       FreeBSD rtbf64b 12.2-RELEASE FreeBSD 12.2-RELEASE r366954 GENERIC
amd64
       amd64
Build Time: 0:27:40.349350
Build FAILED: dtc-1.6.0-x86_64-freebsd12.2-1
x -rw-rw-r--  0 root   root    33437 Mar  4  2020
dtc-1.6.0/pylibfdt/libfdt.i
x -rwxrwxr-x  0 root   root     1068 Mar  4  2020
dtc-1.6.0/pylibfdt/setup.py
x drwxrwxr-x  0 root   root        0 Mar  4  2020 dtc-1.6.0/scripts/
x -rwxrwxr-x  0 root   root      610 Mar  4  2020 dtc-1.6.0/scripts/kup-dtc
x -rwxrwxr-x  0 root   root      571 Mar  4  2020
dtc-1.6.0/scripts/setlocalversion
x -rw-rw-r--  0 root   root     8772 Mar  4  2020 dtc-1.6.0/srcpos.c
x -rw-rw-r--  0 root   root     2948 Mar  4  2020 dtc-1.6.0/srcpos.h
x drwxrwxr-x  0 root   root        0 Mar  4  2020 dtc-1.6.0/tests/
x -rw-rw-r--  0 root   root     1096 Mar  4  2020 dtc-1.6.0/tests/.gitignore
x -rw-rw-r--  0 root   root     2925 Mar  4  2020
dtc-1.6.0/tests/Makefile.tests
x -rw-rw-r--  0 root   root     1424 Mar  4  2020
dtc-1.6.0/tests/add_subnode_with_nops.c
x -rw-rw-r--  0 root   root     1404 Mar  4  2020
dtc-1.6.0/tests/addr_size_cells.c
x -rw-rw-r--  0 root   root     1022 Mar  4  2020
dtc-1.6.0/tests/addr_size_cells2.c
x -rw-rw-r--  0 root   root      516 Mar  4  2020
dtc-1.6.0/tests/addresses.dts
x -rw-rw-r--  0 root   root      360 Mar  4  2020
dtc-1.6.0/tests/aliases.dts
x -rw-rw-r--  0 root   root      219 Mar  4  2020
dtc-1.6.0/tests/appendprop.dts
x -rw-rw-r--  0 root   root     1243 Mar  4  2020
dtc-1.6.0/tests/appendprop1.c
x -rw-rw-r--  0 root   root     1063 Mar  4  2020
dtc-1.6.0/tests/appendprop2.c
x -rw-rw-r--  0 root   root     2239 Mar  4  2020
dtc-1.6.0/tests/appendprop_addrrange.c
x -rw-rw-r--  0 root   root      954 Mar  4  2020
dtc-1.6.0/tests/asm_tree_dump.c
x -rw-rw-r--  0 root   root       97 Mar  4  2020
dtc-1.6.0/tests/bad-chosen.dts
x -rw-rw-r--  0 root   root      156 Mar  4  2020
dtc-1.6.0/tests/bad-dma-ranges.dts
x -rw-rw-r--  0 root   root      128 Mar  4  2020
dtc-1.6.0/tests/bad-empty-ranges.dts
x -rw-rw-r--  0 root   root      150 Mar  4  2020
dtc-1.6.0/tests/bad-gpio.dts
x -rw-rw-r--  0 root   root      277 Mar  4  2020
dtc-1.6.0/tests/bad-graph.dts
x -rw-rw-r--  0 root   root      140 Mar  4  2020
dtc-1.6.0/tests/bad-interrupt-cells.dts
x -rw-rw-r--  0 root   root       53 Mar  4  2020
dtc-1.6.0/tests/bad-name-property.dts
x -rw-rw-r--  0 root   root      107 Mar  4  2020
dtc-1.6.0/tests/bad-ncells.dts
x -rw-rw-r--  0 root   root       29 Mar  4  2020
dtc-1.6.0/tests/bad-octal-literal.dts
x -rw-rw-r--  0 root   root      124 Mar  4  2020
dtc-1.6.0/tests/bad-phandle-cells.dts
x -rw-rw-r--  0 root   root      153 Mar  4  2020
dtc-1.6.0/tests/bad-reg-ranges.dts
x -rw-rw-r--  0 root   root      142 Mar  4  2020
dtc-1.6.0/tests/bad-size-cells.dts
x -rw-rw-r--  0 root   root      196 Mar  4  2020
dtc-1.6.0/tests/bad-string-props.dts
x -rw-rw-r--  0 root   root     2967 Mar  4  2020 dtc-1.6.0/tests/base01.asm
x -rw-rw-r--  0 root   root       32 Mar  4  2020 dtc-1.6.0/tests/base01.cmd
x -rw-rw-r--  0 root   root      653 Mar  4  2020 dtc-1.6.0/tests/base01.dts
x -rw-rw-r--  0 root   root      250 Mar  4  2020
dtc-1.6.0/tests/base01.stderr
x -rw-rw-r--  0 root   root      624 Mar  4  2020
dtc-1.6.0/tests/boot-cpuid.c
x -rw-rw-r--  0 root   root      200 Mar  4  2020
dtc-1.6.0/tests/boot-cpuid.dts
x -rw-rw-r--  0 root   root      950 Mar  4  2020
dtc-1.6.0/tests/char_literal.c
x -rw-rw-r--  0 root   root       69 Mar  4  2020
dtc-1.6.0/tests/char_literal.dts
x -rw-rw-r--  0 root   root     1078 Mar  4  2020
dtc-1.6.0/tests/check_full.c
x -rw-rw-r--  0 root   root     2961 Mar  4  2020
dtc-1.6.0/tests/check_header.c
x -rw-rw-r--  0 root   root     1232 Mar  4  2020
dtc-1.6.0/tests/check_path.c
x -rw-rw-r--  0 root   root      112 Mar  4  2020
dtc-1.6.0/tests/comments-cmp.dts
x -rw-rw-r--  0 root   root      456 Mar  4  2020
dtc-1.6.0/tests/comments.dts
x -rw-rw-r--  0 root   root      109 Mar  4  2020 dtc-1.6.0/tests/data.S
x -rw-rw-r--  0 root   root       47 Mar  4  2020
dtc-1.6.0/tests/default-addr-size.dts
x -rw-rw-r--  0 root   root     3406 Mar  4  2020 dtc-1.6.0/tests/del_node.c
x -rw-rw-r--  0 root   root     1863 Mar  4  2020
dtc-1.6.0/tests/del_property.c
x -rw-rw-r--  0 root   root      823 Mar  4  2020
dtc-1.6.0/tests/delete_reinstate_multilabel.dts
x -rw-rw-r--  0 root   root       66 Mar  4  2020
dtc-1.6.0/tests/delete_reinstate_multilabel_ref.dts
x -rw-rw-r--  0 root   root       70 Mar  4  2020
dtc-1.6.0/tests/dependencies.cmp
x -rw-rw-r--  0 root   root       46 Mar  4  2020
dtc-1.6.0/tests/dependencies.dts
x -rw-rw-r--  0 root   root       27 Mar  4  2020
dtc-1.6.0/tests/deps_inc1.dtsi
x -rw-rw-r--  0 root   root       12 Mar  4  2020
dtc-1.6.0/tests/deps_inc2.dtsi
x -rw-rw-r--  0 root   root       64 Mar  4  2020
dtc-1.6.0/tests/division-by-zero.dts
x -rw-rw-r--  0 root   root     3463 Mar  4  2020
dtc-1.6.0/tests/dtb_reverse.c
x -rw-rw-r--  0 root   root     3959 Mar  4  2020
dtc-1.6.0/tests/dtbs_equal_ordered.c
x -rw-rw-r--  0 root   root     5679 Mar  4  2020
dtc-1.6.0/tests/dtbs_equal_unordered.c
x -rwxrwxr-x  0 root   root      734 Mar  4  2020
dtc-1.6.0/tests/dtc-checkfails.sh
x -rwxrwxr-x  0 root   root      402 Mar  4  2020
dtc-1.6.0/tests/dtc-fails.sh
x -rwxrwxr-x  0 root   root      284 Mar  4  2020
dtc-1.6.0/tests/dtc-fatal.sh
x -rw-rw-r--  0 root   root     1303 Mar  4  2020
dtc-1.6.0/tests/dumptrees.c
x -rw-rw-r--  0 root   root       42 Mar  4  2020
dtc-1.6.0/tests/dup-nodename.dts
x -rw-rw-r--  0 root   root       90 Mar  4  2020
dtc-1.6.0/tests/dup-phandle.dts
dtc-1.6.0/tests/dup-propname.dts
x -rw-rw-r--  0 root   root      152 Mar  4  2020
dtc-1.6.0/tests/embedded_nul.dts
x -rw-rw-r--  0 root   root      154 Mar  4  2020
dtc-1.6.0/tests/embedded_nul_equiv.dts
x -rw-rw-r--  0 root   root       18 Mar  4  2020 dtc-1.6.0/tests/empty.dts
dtc-1.6.0/tests/escapes.dts
x -rw-rw-r--  0 root   root     1153 Mar  4  2020
dtc-1.6.0/tests/extra-terminating-null.c
x -rw-rw-r--  0 root   root      263 Mar  4  2020
dtc-1.6.0/tests/extra-terminating-null.dts
x -rwxrwxr-x  0 root   root      562 Mar  4  2020
dtc-1.6.0/tests/fdtdump-runtest.sh
x -rw-rw-r--  0 root   root      724 Mar  4  2020
dtc-1.6.0/tests/fdtdump.dts
x -rwxrwxr-x  0 root   root      417 Mar  4  2020
dtc-1.6.0/tests/fdtget-runtest.sh
x -rwxrwxr-x  0 root   root      864 Mar  4  2020
dtc-1.6.0/tests/fdtoverlay-runtest.sh
x -rwxrwxr-x  0 root   root      809 Mar  4  2020
dtc-1.6.0/tests/fdtput-runtest.sh
x -rw-rw-r--  0 root   root      581 Mar  4  2020
dtc-1.6.0/tests/find_property.c
x -rw-rw-r--  0 root   root     2907 Mar  4  2020 dtc-1.6.0/tests/fs_tree1.c
x -rw-rw-r--  0 root   root      936 Mar  4  2020
dtc-1.6.0/tests/get_alias.c
x -rw-rw-r--  0 root   root      740 Mar  4  2020
dtc-1.6.0/tests/get_mem_rsv.c
x -rw-rw-r--  0 root   root     1691 Mar  4  2020 dtc-1.6.0/tests/get_name.c
x -rw-rw-r--  0 root   root     1991 Mar  4  2020 dtc-1.6.0/tests/get_path.c
x -rw-rw-r--  0 root   root     1943 Mar  4  2020
dtc-1.6.0/tests/get_phandle.c
x -rw-rw-r--  0 root   root      952 Mar  4  2020
dtc-1.6.0/tests/get_prop_offset.c
x -rw-rw-r--  0 root   root      572 Mar  4  2020 dtc-1.6.0/tests/getprop.c
x -rw-rw-r--  0 root   root       52 Mar  4  2020 dtc-1.6.0/tests/incbin.bin
x -rw-rw-r--  0 root   root     1222 Mar  4  2020 dtc-1.6.0/tests/incbin.c
x -rw-rw-r--  0 root   root      102 Mar  4  2020 dtc-1.6.0/tests/incbin.dts
x -rw-rw-r--  0 root   root       25 Mar  4  2020
dtc-1.6.0/tests/include0.dts
x -rw-rw-r--  0 root   root      571 Mar  4  2020
dtc-1.6.0/tests/include1.dts
dtc-1.6.0/tests/include2.dts
x -rw-rw-r--  0 root   root       17 Mar  4  2020
dtc-1.6.0/tests/include3.dts
x -rw-rw-r--  0 root   root       28 Mar  4  2020
dtc-1.6.0/tests/include4.dts
x -rw-rw-r--  0 root   root        9 Mar  4  2020
dtc-1.6.0/tests/include5.dts
dtc-1.6.0/tests/include5a.dts
x -rw-rw-r--  0 root   root       14 Mar  4  2020
dtc-1.6.0/tests/include6.dts
dtc-1.6.0/tests/include7.dts
dtc-1.6.0/tests/include8.dts
x -rw-rw-r--  0 root   root     2453 Mar  4  2020
dtc-1.6.0/tests/integer-expressions.c
x -rw-rw-r--  0 root   root     1482 Mar  4  2020
dtc-1.6.0/tests/label01.dts
x -rw-rw-r--  0 root   root       98 Mar  4  2020
dtc-1.6.0/tests/label_repeated.dts
x -rw-rw-r--  0 root   root      554 Mar  4  2020
dtc-1.6.0/tests/line_directives.dts
x -rw-rw-r--  0 root   root     2055 Mar  4  2020 dtc-1.6.0/tests/lorem.txt
x -rw-rw-r--  0 root   root     3104 Mar  4  2020
dtc-1.6.0/tests/mangle-layout.c
x -rw-rw-r--  0 root   root       62 Mar  4  2020
dtc-1.6.0/tests/minusone-phandle.dts
x -rw-rw-r--  0 root   root     1392 Mar  4  2020
dtc-1.6.0/tests/move_and_save.c
x -rw-rw-r--  0 root   root      989 Mar  4  2020
dtc-1.6.0/tests/multilabel.dts
x -rw-rw-r--  0 root   root     1357 Mar  4  2020
dtc-1.6.0/tests/multilabel_merge.dts
x -rw-rw-r--  0 root   root     1805 Mar  4  2020
dtc-1.6.0/tests/node_check_compatible.c
x -rw-rw-r--  0 root   root     2139 Mar  4  2020
dtc-1.6.0/tests/node_offset_by_compatible.c
x -rw-rw-r--  0 root   root     1242 Mar  4  2020
dtc-1.6.0/tests/node_offset_by_phandle.c
x -rw-rw-r--  0 root   root     2606 Mar  4  2020
dtc-1.6.0/tests/node_offset_by_prop_value.c
x -rw-rw-r--  0 root   root       80 Mar  4  2020
dtc-1.6.0/tests/nonexist-label-ref.dts
x -rw-rw-r--  0 root   root       88 Mar  4  2020
dtc-1.6.0/tests/nonexist-node-ref.dts
x -rw-rw-r--  0 root   root      111 Mar  4  2020
dtc-1.6.0/tests/nonexist-node-ref2.dts
x -rw-rw-r--  0 root   root     2996 Mar  4  2020 dtc-1.6.0/tests/nop_node.c
x -rw-rw-r--  0 root   root     1445 Mar  4  2020
dtc-1.6.0/tests/nop_property.c
x -rw-rw-r--  0 root   root     2184 Mar  4  2020 dtc-1.6.0/tests/nopulate.c
x -rw-rw-r--  0 root   root     1572 Mar  4  2020 dtc-1.6.0/tests/notfound.c
x -rw-rw-r--  0 root   root       36 Mar  4  2020
dtc-1.6.0/tests/nul-in-escape.dts
x -rw-rw-r--  0 root   root        8 Mar  4  2020
dtc-1.6.0/tests/nul-in-line-info1.dts
dtc-1.6.0/tests/nul-in-line-info2.dts
x -rw-rw-r--  0 root   root      170 Mar  4  2020
dtc-1.6.0/tests/obsolete-chosen-interrupt-controller.dts
x -rw-rw-r--  0 root   root      305 Mar  4  2020
dtc-1.6.0/tests/omit-no-ref.dts
x -rw-rw-r--  0 root   root     1226 Mar  4  2020
dtc-1.6.0/tests/open_pack.c
x -rw-rw-r--  0 root   root     4733 Mar  4  2020 dtc-1.6.0/tests/overlay.c
x -rw-rw-r--  0 root   root     1084 Mar  4  2020
dtc-1.6.0/tests/overlay_bad_fixup.c
x -rw-rw-r--  0 root   root      220 Mar  4  2020
dtc-1.6.0/tests/overlay_bad_fixup_bad_index.dts
x -rw-rw-r--  0 root   root      221 Mar  4  2020
dtc-1.6.0/tests/overlay_bad_fixup_base.dtsi
x -rw-rw-r--  0 root   root      199 Mar  4  2020
dtc-1.6.0/tests/overlay_bad_fixup_empty.dts
x -rw-rw-r--  0 root   root      218 Mar  4  2020
dtc-1.6.0/tests/overlay_bad_fixup_empty_index.dts
dtc-1.6.0/tests/overlay_bad_fixup_index_trailing.dts
x -rw-rw-r--  0 root   root      212 Mar  4  2020
dtc-1.6.0/tests/overlay_bad_fixup_path_empty_prop.dts
x -rw-rw-r--  0 root   root      210 Mar  4  2020
dtc-1.6.0/tests/overlay_bad_fixup_path_only.dts
x -rw-rw-r--  0 root   root      211 Mar  4  2020
dtc-1.6.0/tests/overlay_bad_fixup_path_only_sep.dts
x -rw-rw-r--  0 root   root      217 Mar  4  2020
dtc-1.6.0/tests/overlay_bad_fixup_path_prop.dts
x -rw-rw-r--  0 root   root      381 Mar  4  2020
dtc-1.6.0/tests/overlay_base.dts
x -rw-rw-r--  0 root   root      362 Mar  4  2020
dtc-1.6.0/tests/overlay_base_manual_symbols.dts
x -rw-rw-r--  0 root   root      755 Mar  4  2020
dtc-1.6.0/tests/overlay_overlay.dts
x -rw-rw-r--  0 root   root      746 Mar  4  2020
dtc-1.6.0/tests/overlay_overlay_bypath.dts
x -rw-rw-r--  0 root   root      364 Mar  4  2020
dtc-1.6.0/tests/overlay_overlay_local_merge.dts
x -rw-rw-r--  0 root   root      343 Mar  4  2020
dtc-1.6.0/tests/overlay_overlay_long_path.dts
x -rw-rw-r--  0 root   root     1906 Mar  4  2020
dtc-1.6.0/tests/overlay_overlay_manual_fixups.dts
x -rw-rw-r--  0 root   root     1099 Mar  4  2020
dtc-1.6.0/tests/overlay_overlay_no_fixups.dts
x -rw-rw-r--  0 root   root     1186 Mar  4  2020
dtc-1.6.0/tests/overlay_overlay_nosugar.dts
x -rw-rw-r--  0 root   root      143 Mar  4  2020
dtc-1.6.0/tests/overlay_overlay_simple.dts
x -rw-rw-r--  0 root   root     1880 Mar  4  2020
dtc-1.6.0/tests/parent_offset.c
x -rw-rw-r--  0 root   root     2467 Mar  4  2020
dtc-1.6.0/tests/path-references.c
x -rw-rw-r--  0 root   root      461 Mar  4  2020
dtc-1.6.0/tests/path-references.dts
x -rw-rw-r--  0 root   root     4111 Mar  4  2020
dtc-1.6.0/tests/path_offset.c
x -rw-rw-r--  0 root   root     1241 Mar  4  2020
dtc-1.6.0/tests/path_offset_aliases.c
x -rw-rw-r--  0 root   root      313 Mar  4  2020
dtc-1.6.0/tests/pci-bridge-bad1.dts
x -rw-rw-r--  0 root   root      306 Mar  4  2020
dtc-1.6.0/tests/pci-bridge-bad2.dts
x -rw-rw-r--  0 root   root      536 Mar  4  2020
dtc-1.6.0/tests/pci-bridge-ok.dts
x -rw-rw-r--  0 root   root     1539 Mar  4  2020
dtc-1.6.0/tests/phandle_format.c
x -rw-rw-r--  0 root   root       51 Mar  4  2020
dtc-1.6.0/tests/prop-after-subnode.dts
x -rw-rw-r--  0 root   root     1686 Mar  4  2020
dtc-1.6.0/tests/property_iterate.c
x -rw-rw-r--  0 root   root      242 Mar  4  2020
dtc-1.6.0/tests/property_iterate.dts
x -rw-rw-r--  0 root   root      579 Mar  4  2020
dtc-1.6.0/tests/propname_escapes.c
dtc-1.6.0/tests/propname_escapes.dts
x -rw-rw-r--  0 root   root    23620 Mar  4  2020
dtc-1.6.0/tests/pylibfdt_tests.py
x -rw-rw-r--  0 root   root     3518 Mar  4  2020
dtc-1.6.0/tests/references.c
x -rw-rw-r--  0 root   root      853 Mar  4  2020
dtc-1.6.0/tests/references.dts
x -rw-rw-r--  0 root   root      117 Mar  4  2020
dtc-1.6.0/tests/reg-ranges-root.dts
x -rw-rw-r--  0 root   root       89 Mar  4  2020
dtc-1.6.0/tests/reg-without-unit-addr.dts
x -rw-rw-r--  0 root   root      163 Mar  4  2020
dtc-1.6.0/tests/reuse-label.dts
dtc-1.6.0/tests/reuse-label1.dts
x -rw-rw-r--  0 root   root       72 Mar  4  2020
dtc-1.6.0/tests/reuse-label2.dts
x -rw-rw-r--  0 root   root       84 Mar  4  2020
dtc-1.6.0/tests/reuse-label3.dts
dtc-1.6.0/tests/reuse-label4.dts
dtc-1.6.0/tests/reuse-label5.dts
dtc-1.6.0/tests/reuse-label6.dts
x -rw-rw-r--  0 root   root      765 Mar  4  2020
dtc-1.6.0/tests/root_node.c
x -rwxrwxr-x  0 root   root    42763 Mar  4  2020
dtc-1.6.0/tests/run_tests.sh
x -rw-rw-r--  0 root   root     2022 Mar  4  2020 dtc-1.6.0/tests/rw_oom.c
x -rw-rw-r--  0 root   root     2225 Mar  4  2020 dtc-1.6.0/tests/rw_tree1.c
dtc-1.6.0/tests/search_dir/
x -rw-rw-r--  0 root   root       38 Mar  4  2020
dtc-1.6.0/tests/search_dir/search_test.dtsi
dtc-1.6.0/tests/search_dir/search_test2.dtsi
dtc-1.6.0/tests/search_dir_b/
x -rw-rw-r--  0 root   root       50 Mar  4  2020
dtc-1.6.0/tests/search_dir_b/search_paths_subdir.dts
x -rw-rw-r--  0 root   root       40 Mar  4  2020
dtc-1.6.0/tests/search_dir_b/search_test_b.dtsi
dtc-1.6.0/tests/search_dir_b/search_test_b2.dtsi
x -rw-rw-r--  0 root   root        7 Mar  4  2020
dtc-1.6.0/tests/search_dir_b/search_test_c.dtsi
x -rw-rw-r--  0 root   root       48 Mar  4  2020
dtc-1.6.0/tests/search_paths.dts
dtc-1.6.0/tests/search_paths_b.dts
x -rw-rw-r--  0 root   root     1930 Mar  4  2020 dtc-1.6.0/tests/set_name.c
x -rw-rw-r--  0 root   root     2121 Mar  4  2020 dtc-1.6.0/tests/setprop.c
x -rw-rw-r--  0 root   root     2410 Mar  4  2020
dtc-1.6.0/tests/setprop_inplace.c
x -rw-rw-r--  0 root   root     1756 Mar  4  2020
dtc-1.6.0/tests/sized_cells.c
dtc-1.6.0/tests/sized_cells.dts
x -rw-rw-r--  0 root   root      405 Mar  4  2020
dtc-1.6.0/tests/sourceoutput.dts
x -rw-rw-r--  0 root   root      205 Mar  4  2020
dtc-1.6.0/tests/stacked_overlay_addlabel.dts
x -rw-rw-r--  0 root   root      158 Mar  4  2020
dtc-1.6.0/tests/stacked_overlay_bar.dts
x -rw-rw-r--  0 root   root       61 Mar  4  2020
dtc-1.6.0/tests/stacked_overlay_base.dts
x -rw-rw-r--  0 root   root       56 Mar  4  2020
dtc-1.6.0/tests/stacked_overlay_base_nolabel.dts
dtc-1.6.0/tests/stacked_overlay_baz.dts
x -rw-rw-r--  0 root   root      622 Mar  4  2020
dtc-1.6.0/tests/string_escapes.c
x -rw-rw-r--  0 root   root     4087 Mar  4  2020
dtc-1.6.0/tests/stringlist.c
x -rw-rw-r--  0 root   root      149 Mar  4  2020
dtc-1.6.0/tests/stringlist.dts
x -rw-rw-r--  0 root   root     1522 Mar  4  2020
dtc-1.6.0/tests/subnode_iterate.c
x -rw-rw-r--  0 root   root      761 Mar  4  2020
dtc-1.6.0/tests/subnode_iterate.dts
x -rw-rw-r--  0 root   root     2636 Mar  4  2020
dtc-1.6.0/tests/subnode_offset.c
x -rw-rw-r--  0 root   root     3145 Mar  4  2020
dtc-1.6.0/tests/supernode_atdepth_offset.c
x -rw-rw-r--  0 root   root     3850 Mar  4  2020
dtc-1.6.0/tests/sw_states.c
x -rw-rw-r--  0 root   root     5369 Mar  4  2020 dtc-1.6.0/tests/sw_tree1.c
x -rw-rw-r--  0 root   root     4884 Mar  4  2020 dtc-1.6.0/tests/test01.asm
x -rw-rw-r--  0 root   root     1184 Mar  4  2020 dtc-1.6.0/tests/test01.dts
dtc-1.6.0/tests/test01.stderr
x -rwxrwxr-x  0 root   root     2056 Mar  4  2020
dtc-1.6.0/tests/test_kernel_dts
x -rw-rw-r--  0 root   root       41 Mar  4  2020
dtc-1.6.0/tests/test_label_ref.dts
x -rw-rw-r--  0 root   root      264 Mar  4  2020
dtc-1.6.0/tests/test_props.dts
x -rw-rw-r--  0 root   root      796 Mar  4  2020
dtc-1.6.0/tests/test_tree1.dts
x -rw-rw-r--  0 root   root      732 Mar  4  2020
dtc-1.6.0/tests/test_tree1_delete.dts
x -rw-rw-r--  0 root   root      933 Mar  4  2020
dtc-1.6.0/tests/test_tree1_label_noderef.dts
x -rw-rw-r--  0 root   root      798 Mar  4  2020
dtc-1.6.0/tests/test_tree1_merge.dts
x -rw-rw-r--  0 root   root      767 Mar  4  2020
dtc-1.6.0/tests/test_tree1_merge_labelled.dts
x -rw-rw-r--  0 root   root      788 Mar  4  2020
dtc-1.6.0/tests/test_tree1_merge_path.dts
x -rw-rw-r--  0 root   root      642 Mar  4  2020
dtc-1.6.0/tests/test_tree1_wrong1.dts
x -rw-rw-r--  0 root   root      658 Mar  4  2020
dtc-1.6.0/tests/test_tree1_wrong2.dts
x -rw-rw-r--  0 root   root      659 Mar  4  2020
dtc-1.6.0/tests/test_tree1_wrong3.dts
x -rw-rw-r--  0 root   root      670 Mar  4  2020
dtc-1.6.0/tests/test_tree1_wrong4.dts
x -rw-rw-r--  0 root   root      684 Mar  4  2020
dtc-1.6.0/tests/test_tree1_wrong5.dts
x -rw-rw-r--  0 root   root      699 Mar  4  2020
dtc-1.6.0/tests/test_tree1_wrong6.dts
x -rw-rw-r--  0 root   root      705 Mar  4  2020
dtc-1.6.0/tests/test_tree1_wrong7.dts
dtc-1.6.0/tests/test_tree1_wrong8.dts
x -rw-rw-r--  0 root   root      702 Mar  4  2020
dtc-1.6.0/tests/test_tree1_wrong9.dts
x -rw-rw-r--  0 root   root     1890 Mar  4  2020 dtc-1.6.0/tests/testdata.h
x -rw-rw-r--  0 root   root     3430 Mar  4  2020 dtc-1.6.0/tests/tests.h
x -rw-rw-r--  0 root   root     8645 Mar  4  2020
dtc-1.6.0/tests/testutils.c
x -rw-rw-r--  0 root   root     1038 Mar  4  2020
dtc-1.6.0/tests/testutils.sh
x -rw-rw-r--  0 root   root     6409 Mar  4  2020 dtc-1.6.0/tests/trees.S
x -rw-rw-r--  0 root   root     1235 Mar  4  2020
dtc-1.6.0/tests/truncated_memrsv.c
x -rw-rw-r--  0 root   root      801 Mar  4  2020
dtc-1.6.0/tests/truncated_property.c
x -rw-rw-r--  0 root   root     2007 Mar  4  2020
dtc-1.6.0/tests/truncated_string.c
x -rw-rw-r--  0 root   root      644 Mar  4  2020
dtc-1.6.0/tests/type-preservation.dt.yaml
x -rw-rw-r--  0 root   root      754 Mar  4  2020
dtc-1.6.0/tests/type-preservation.dts
dtc-1.6.0/tests/unit-addr-leading-0s.dts
dtc-1.6.0/tests/unit-addr-leading-0x.dts
x -rw-rw-r--  0 root   root      245 Mar  4  2020
dtc-1.6.0/tests/unit-addr-simple-bus-compatible.dts
x -rw-rw-r--  0 root   root      234 Mar  4  2020
dtc-1.6.0/tests/unit-addr-simple-bus-reg-mismatch.dts
x -rw-rw-r--  0 root   root      115 Mar  4  2020
dtc-1.6.0/tests/unit-addr-unique.dts
x -rw-rw-r--  0 root   root       76 Mar  4  2020
dtc-1.6.0/tests/unit-addr-without-reg.dts
x -rw-rw-r--  0 root   root     2461 Mar  4  2020
dtc-1.6.0/tests/utilfdt_test.c
x -rw-rw-r--  0 root   root     2417 Mar  4  2020
dtc-1.6.0/tests/value-labels.c
x -rw-rw-r--  0 root   root      233 Mar  4  2020
dtc-1.6.0/tests/value-labels.dts
dtc-1.6.0/tests/zero-phandle.dts
x -rw-rw-r--  0 root   root     7054 Mar  4  2020 dtc-1.6.0/treesource.c
x -rw-rw-r--  0 root   root     8701 Mar  4  2020 dtc-1.6.0/util.c
x -rw-rw-r--  0 root   root     7112 Mar  4  2020 dtc-1.6.0/util.h
x -rw-rw-r--  0 root   root     6380 Mar  4  2020 dtc-1.6.0/yamltree.c
+ tar_exit=0
+ cd dtc-1.6.0
+ /bin/chmod -R a+rX,g-w,o-w .
+ cd
/usr/home/joel/rtems-cron-6/rtems-source-builder/rtems/build/dtc-1.6.0-x86_64-freebsd12.2-1
==> clean %{buildroot}:
/usr/home/joel/rtems-cron-6/rtems-source-builder/rtems/build/tmp/dtc-1.6.0-x86_64-freebsd12.2-1-1002
+ SB_CXC=no
+ echo '==> clean %{buildroot}:
/usr/home/joel/rtems-cron-6/rtems-source-builder/rtems/build/tmp/dtc-1.6.0-x86_64-freebsd12.2-1-1002'
+ /bin/rm -rf
+ /bin/mkdir -p
+ echo '==> %build:'
==> %build:
+ pwd
build_top=/usr/home/joel/rtems-cron-6/rtems-source-builder/rtems/build/dtc-1.6.0-x86_64-freebsd12.2-1
+ cd dtc-1.6.0
+ LDFLAGS='-L/usr/local/lib
-L/usr/home/joel/rtems-cron-6/rtems-source-builder/rtems/build/tmp/sb-1002/6/rtems-moxie/home/joel/rtems-cron-6/tools/6/lib'
+ LIBS=''
+ echo '/usr/bin/cc -O2 -pipe -fbracket-depth=1024
-I/usr/home/joel/rtems-cron-6/rtems-source-builder/rtems/build/tmp/sb-1002/6/rtems-moxie/home/joel/rtems-cron-6/tools/6/include
+ sed -e 's,-std=gnu99 ,,'
+ CC='/usr/bin/cc -O2 -pipe -fbracket-depth=1024
+ echo '/usr/bin/c++ -O2 -pipe -fbracket-depth=1024
+ CXX='/usr/bin/c++ -O2 -pipe -fbracket-depth=1024
+ CC_FOR_BUILD='/usr/bin/cc -O2 -pipe -fbracket-depth=1024
+ CXX_FOR_BUILD='/usr/bin/c++ -O2 -pipe -fbracket-depth=1024
+ export CC CXX CC_FOR_BUILD CXX_FOR_BUILD CFLAGS LDFLAGS LIBS
+ gmake 'PREFIX=/home/joel/rtems-cron-6/tools/6'
         DEP tests/dumptrees.c
         DEP tests/trees.S
         DEP tests/testutils.c
         DEP tests/value-labels.c
         DEP tests/asm_tree_dump.c
         DEP tests/truncated_memrsv.c
         DEP tests/truncated_string.c
         DEP tests/truncated_property.c
         DEP tests/fs_tree1.c
         DEP tests/check_full.c
         DEP tests/check_header.c
         DEP tests/check_path.c
         DEP tests/overlay_bad_fixup.c
         DEP tests/overlay.c
         DEP tests/subnode_iterate.c
         DEP tests/property_iterate.c
         DEP tests/integer-expressions.c
         DEP tests/utilfdt_test.c
         DEP tests/path_offset_aliases.c
         DEP tests/add_subnode_with_nops.c
         DEP tests/dtbs_equal_unordered.c
         DEP tests/dtb_reverse.c
         DEP tests/dtbs_equal_ordered.c
         DEP tests/extra-terminating-null.c
         DEP tests/incbin.c
         DEP tests/boot-cpuid.c
         DEP tests/phandle_format.c
         DEP tests/path-references.c
         DEP tests/references.c
         DEP tests/string_escapes.c
         DEP tests/propname_escapes.c
         DEP tests/appendprop2.c
         DEP tests/appendprop1.c
         DEP tests/del_node.c
         DEP tests/del_property.c
         DEP tests/setprop.c
         DEP tests/set_name.c
         DEP tests/rw_oom.c
         DEP tests/rw_tree1.c
         DEP tests/open_pack.c
         DEP tests/nopulate.c
         DEP tests/mangle-layout.c
         DEP tests/move_and_save.c
         DEP tests/sw_states.c
         DEP tests/sw_tree1.c
         DEP tests/nop_node.c
         DEP tests/nop_property.c
         DEP tests/setprop_inplace.c
         DEP tests/stringlist.c
         DEP tests/appendprop_addrrange.c
         DEP tests/addr_size_cells2.c
         DEP tests/addr_size_cells.c
         DEP tests/notfound.c
         DEP tests/sized_cells.c
         DEP tests/char_literal.c
         DEP tests/get_alias.c
         DEP tests/node_offset_by_compatible.c
         DEP tests/node_check_compatible.c
         DEP tests/node_offset_by_phandle.c
         DEP tests/node_offset_by_prop_value.c
         DEP tests/parent_offset.c
         DEP tests/supernode_atdepth_offset.c
         DEP tests/get_path.c
         DEP tests/get_phandle.c
         DEP tests/get_prop_offset.c
         DEP tests/getprop.c
         DEP tests/get_name.c
         DEP tests/path_offset.c
         DEP tests/subnode_offset.c
         DEP tests/find_property.c
         DEP tests/root_node.c
         DEP tests/get_mem_rsv.c
         DEP libfdt/fdt_check.c
         DEP libfdt/fdt_overlay.c
         DEP libfdt/fdt_addresses.c
         DEP libfdt/fdt_empty_tree.c
         DEP libfdt/fdt_strerror.c
         DEP libfdt/fdt_rw.c
         DEP libfdt/fdt_sw.c
         DEP libfdt/fdt_wip.c
         DEP libfdt/fdt_ro.c
         DEP libfdt/fdt.c
         DEP util.c
         DEP fdtoverlay.c
         DEP fdtput.c
         DEP fdtget.c
         DEP fdtdump.c
         LEX convert-dtsv0-lexer.lex.c
         DEP convert-dtsv0-lexer.lex.c
         DEP srcpos.c
         BISON dtc-parser.tab.c
         DEP dtc-parser.tab.c
         LEX dtc-lexer.lex.c
         DEP dtc-lexer.lex.c
         DEP yamltree.c
         DEP treesource.c
         DEP livetree.c
         DEP fstree.c
         DEP flattree.c
         DEP dtc.c
         DEP data.c
         DEP checks.c
        CHK version_gen.h
        UPD version_gen.h
         DEP util.c
        CHK version_gen.h
         CC srcpos.o
         CC util.o
         CC convert-dtsv0-lexer.lex.o
         LD convert-dtsv0
         CC dtc.o
         CC checks.o
         CC data.o
         CC flattree.o
         CC fstree.o
         CC livetree.o
         CC treesource.o
gmake: *** No rule to make target 'yaml.h', needed by 'yamltree.o'.  Stop.
shell cmd failed: /bin/sh -ex
/usr/home/joel/rtems-cron-6/rtems-source-builder/rtems/build/dtc-1.6.0-x86_64-freebsd12.2-1/do-build
error: building dtc-1.6.0-x86_64-freebsd12.2-1
  See error report: rsb-report-dtc-1.6.0-x86_64-freebsd12.2-1.txt
Sizes
Maximum build usage: 1.734GB
Total size: 1.959GB
Installed : 309.145MB
Sources: 1.657GB
Patches: 29.274KB
Output
Build Set: 6/rtems-moxie
config: devel/dtc-1.6.0-1.cfg
package: dtc-1.6.0-x86_64-freebsd12.2-1
building: dtc-1.6.0-x86_64-freebsd12.2-1
Build FAILED
Build Set: 6/rtems-autotools.bset
Build Set: 6/rtems-autotools-internal.bset
config: tools/rtems-autoconf-2.69-1.cfg
package: autoconf-2.69-x86_64-freebsd12.2-1
building: autoconf-2.69-x86_64-freebsd12.2-1
sizes: autoconf-2.69-x86_64-freebsd12.2-1: 7.501MB (installed: 0.000B)
cleaning: autoconf-2.69-x86_64-freebsd12.2-1
config: tools/rtems-automake-1.12.6-1.cfg
package: automake-1.12.6-x86_64-freebsd12.2-1
building: automake-1.12.6-x86_64-freebsd12.2-1
sizes: automake-1.12.6-x86_64-freebsd12.2-1: 8.327MB (installed: 0.000B)
cleaning: automake-1.12.6-x86_64-freebsd12.2-1
Build Sizes: usage: 8.327MB total: 1.657GB (sources: 1.657GB, patches:
29.274KB, installed 0.000B)
Build Set: Time 0:00:10.387895
Build Set: 6/rtems-autotools-base.bset
sizes: autoconf-2.69-x86_64-freebsd12.2-1: 10.519MB (installed: 3.021MB)
reporting: tools/rtems-autoconf-2.69-1.cfg ->
autoconf-2.69-x86_64-freebsd12.2-1.txt
autoconf-2.69-x86_64-freebsd12.2-1.xml
sizes: automake-1.12.6-x86_64-freebsd12.2-1: 10.590MB (installed: 2.265MB)
reporting: tools/rtems-automake-1.12.6-1.cfg ->
automake-1.12.6-x86_64-freebsd12.2-1.txt
automake-1.12.6-x86_64-freebsd12.2-1.xml
staging: autoconf-2.69-x86_64-freebsd12.2-1 ->
/usr/home/joel/rtems-cron-6/rtems-source-builder/rtems/build/tmp/sb-1002-staging
staging: automake-1.12.6-x86_64-freebsd12.2-1 ->
Build Sizes: usage: 15.875MB total: 1.663GB (sources: 1.657GB, patches:
29.274KB, installed 5.285MB)
Build Set: Time 0:00:21.642219
Build Set: Time 0:00:32.041017
config: devel/expat-2.1.0-1.cfg
package: expat-2.1.0-x86_64-freebsd12.2-1
building: expat-2.1.0-x86_64-freebsd12.2-1
sizes: expat-2.1.0-x86_64-freebsd12.2-1: 4.743MB (installed: 609.402KB)
cleaning: expat-2.1.0-x86_64-freebsd12.2-1
reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-freebsd12.2-1.txt
reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-freebsd12.2-1.xml
config: devel/gmp-6.1.0.cfg
package: gmp-6.1.0-x86_64-freebsd12.2-1
building: gmp-6.1.0-x86_64-freebsd12.2-1
sizes: gmp-6.1.0-x86_64-freebsd12.2-1: 21.862MB (installed: 1.731MB)
cleaning: gmp-6.1.0-x86_64-freebsd12.2-1
reporting: devel/gmp-6.1.0.cfg -> gmp-6.1.0-x86_64-freebsd12.2-1.txt
reporting: devel/gmp-6.1.0.cfg -> gmp-6.1.0-x86_64-freebsd12.2-1.xml
config: tools/rtems-gdb-head.cfg
package: moxie-rtems6-gdb-acf10ca-x86_64-freebsd12.2-1
building: moxie-rtems6-gdb-acf10ca-x86_64-freebsd12.2-1
sizes: moxie-rtems6-gdb-acf10ca-x86_64-freebsd12.2-1: 407.904MB (installed:
14.336MB)
cleaning: moxie-rtems6-gdb-acf10ca-x86_64-freebsd12.2-1
reporting: tools/rtems-gdb-head.cfg ->
moxie-rtems6-gdb-acf10ca-x86_64-freebsd12.2-1.txt
moxie-rtems6-gdb-acf10ca-x86_64-freebsd12.2-1.xml
config: tools/rtems-binutils-head.cfg
package: moxie-rtems6-binutils-acf10ca-x86_64-freebsd12.2-1
building: moxie-rtems6-binutils-acf10ca-x86_64-freebsd12.2-1
sizes: moxie-rtems6-binutils-acf10ca-x86_64-freebsd12.2-1: 406.882MB
(installed: 28.898MB)
cleaning: moxie-rtems6-binutils-acf10ca-x86_64-freebsd12.2-1
reporting: tools/rtems-binutils-head.cfg ->
moxie-rtems6-binutils-acf10ca-x86_64-freebsd12.2-1.txt
moxie-rtems6-binutils-acf10ca-x86_64-freebsd12.2-1.xml
config: tools/rtems-gcc-10-newlib-head.cfg
package: moxie-rtems6-gcc-03e2d83-newlib-415fdd4-x86_64-freebsd12.2-1
building: moxie-rtems6-gcc-03e2d83-newlib-415fdd4-x86_64-freebsd12.2-1
sizes: moxie-rtems6-gcc-03e2d83-newlib-415fdd4-x86_64-freebsd12.2-1:
1.432GB (installed: 190.542MB)
cleaning: moxie-rtems6-gcc-03e2d83-newlib-415fdd4-x86_64-freebsd12.2-1
reporting: tools/rtems-gcc-10-newlib-head.cfg ->
moxie-rtems6-gcc-03e2d83-newlib-415fdd4-x86_64-freebsd12.2-1.txt
moxie-rtems6-gcc-03e2d83-newlib-415fdd4-x86_64-freebsd12.2-1.xml
config: tools/rtems-tools-6.cfg
package: rtems-tools-2251c5a878c24e9120d9dd53751f69790e3d7387-1
building: rtems-tools-2251c5a878c24e9120d9dd53751f69790e3d7387-1
sizes: rtems-tools-2251c5a878c24e9120d9dd53751f69790e3d7387-1: 270.904MB
(installed: 73.042MB)
cleaning: rtems-tools-2251c5a878c24e9120d9dd53751f69790e3d7387-1
reporting: tools/rtems-tools-6.cfg ->
rtems-tools-2251c5a878c24e9120d9dd53751f69790e3d7387-1.txt
rtems-tools-2251c5a878c24e9120d9dd53751f69790e3d7387-1.xml
Build Sizes: usage: 1.734GB total: 1.959GB (sources: 1.657GB, patches:
29.274KB, installed 309.145MB)
Mailing report: build at rtems.org
Report
RTEMS Tools Project <users at rtems.org> Mon Dec 28 15:07:45 2020
Report: devel/expat-2.1.0-1.cfg
RTEMS Source Builder Repository Status
 Remotes:
[ remotes removed, contact sender for details ]
 Status:
  Clean
 Head:
  Commit: d3dc0bc3861362978cdf65725e4ba2b64e283d32
Build Set: (1) devel/expat-2.1.0-1.cfg
Build Set: (2) devel/expat-2.1.0-1.cfg
Package: expat-2.1.0-x86_64-freebsd12.2-1
 Config: devel/expat-2.1.0-1.cfg
 Summary:
  Expat XML Parser v2.1.0 for target moxie-rtems6 on host x86_64-freebsd12.2
 URL:
  http://expat.sourceforge.net/
 Version:
  2.1.0
 Release:
  1
  Sources: 1
    1:
https://github.com/libexpat/libexpat/releases/download/R_2_1_0/expat-2.1.0.tar.gz
       sha256:
823705472f816df21c8f6aa026dd162b280806838bb55b3432b0fb1fcca7eb86
  Patches: 0
 Preparation:
  build_top=$(pwd)
  %setup source expat -q -n expat-2.1.0
  %setup patch expat -p1
  cd ${build_top}
 Build:
  build_top=$(pwd)
  cd expat-2.1.0
  # Host and build flags, Cross build if host and build are different and
  # Cxc build if target is deifned and also different.
  # Note, gcc is not ready to be compiled with -std=gnu99 (this needs to be
checked).
  if test "x86_64-freebsd12.2" != "x86_64-freebsd12.2" ; then
    # Cross build
    CC=$(echo "x86_64-freebsd12.2-gcc" | sed -e 's,-std=gnu99 ,,')
    CXX=$(echo "x86_64-freebsd12.2-g++" | sed -e 's,-std=gnu99 ,,')
    CPPFLAGS="${SB_HOST_CPPFLAGS}"
    CFLAGS="${SB_HOST_CFLAGS}"
    CXXFLAGS="${SB_HOST_CXXFLAGS}"
    LDFLAGS="${SB_HOST_LDFLAGS}"
    LDLIBS="${SB_HOST_LIBS}"
    # Host
    CPPFLAGS_FOR_HOST="${SB_HOST_CPPFLAGS}"
    CFLAGS_FOR_HOST="${SB_HOST_CFLAGS}"
    CXXFLAGS_FOR_HOST="${SB_HOST_CXXFLAGS}"
    LDFLAGS_FOR_HOST="${SB_HOST_LDFLAGS}"
    LDLIBS_FOR_HOST="${SB_HOST_LIBS}"
    CXXFLAGS_FOR_HOST="${SB_HOST_CFLAGS}"
    CC_FOR_HOST=$(echo "gcc ${SB_HOST_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
    CXX_FOR_HOST=$(echo "g++ ${SB_HOST_CXXFLAGS}" | sed -e 's,-std=gnu99
    # Build
    CFLAGS_FOR_BUILD="${SB_BUILD_CFLAGS}"
    CXXFLAGS_FOR_BUILD="${SB_BUILD_CXXFLAGS}"
    LDFLAGS_FOR_BUILD="${SB_BUILD_LDFLAGS}"
    LDLIBS_FOR_BUILD="${SB_BUILD_LIBS}"
    CXXFLAGS_FOR_BUILD="${SB_BUILD_CFLAGS}"
    CC_FOR_BUILD=$(echo "/usr/bin/cc ${SB_BUILD_CFLAGS}" | sed -e
's,-std=gnu99 ,,')
    CXX_FOR_BUILD=$(echo "/usr/bin/c++ ${SB_BUILD_CXXFLAGS}" | sed -e
's,-std=gnu99 ,,')
  else
    LDFLAGS="${SB_BUILD_LDFLAGS}"
    LDLIBS="${SB_BUILD_LIBS}"
    CC=$(echo "/usr/bin/cc ${SB_BUILD_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
    CXX=$(echo "/usr/bin/c++ ${SB_BUILD_CXXFLAGS}" | sed -e 's,-std=gnu99
    CC_FOR_BUILD=${CC}
    CXX_FOR_BUILD=${CXX}
  fi
  export CC CXX CPPFLAGS CFLAGS CXXFLAGS LDFLAGS LIBS LDLIBS
  export CC_FOR_HOST CXX_FOR_HOST CPPFLAGS_FOR_HOST CFLAGS_FOR_HOST
CXXFLAGS_FOR_HOST LDFLAGS_FOR_HOST LDLIBS_FOR_HOST LIBS_FOR_HOST
  export CC_FOR_BUILD CXX_FOR_BUILD CFLAGS_FOR_BUILD CXXFLAGS_FOR_BUILD
LDFLAGS_FOR_BUILD LDLIBS_FOR_BUILS LIBS_FOR_BUILS
  ./configure  --build=x86_64-freebsd12.2 --host=x86_64-freebsd12.2
--verbose  --prefix=/home/joel/rtems-cron-6/tools/6
--bindir=/home/joel/rtems-cron-6/tools/6/bin
--exec-prefix=/home/joel/rtems-cron-6/tools/6
--includedir=/home/joel/rtems-cron-6/tools/6/include
--libdir=/home/joel/rtems-cron-6/tools/6/lib
--mandir=/home/joel/rtems-cron-6/tools/6/share/man
--infodir=/home/joel/rtems-cron-6/tools/6/share/info  --disable-shared
  gmake -j 4 all
  cd ${build_top}
 Install:
  build_top=$(pwd)
  rm -rf $SB_BUILD_ROOT
  cd expat-2.1.0
  gmake DESTDIR=$SB_BUILD_ROOT install
  cd ${build_top}
 Remotes:
 Status:
  Clean
 Head:
 Summary:
 URL:
 Version:
  2.1.0
 Release:
  1
  Sources: 1
    1:
       sha256:
  Patches: 0
 Preparation:
  build_top=$(pwd)
  cd ${build_top}
 Build:
  build_top=$(pwd)
  cd expat-2.1.0
checked).
    # Cross build
    # Host
    # Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
  else
    CC_FOR_BUILD=${CC}
  fi
  gmake -j 4 all
  cd ${build_top}
 Install:
  build_top=$(pwd)
  cd expat-2.1.0
  cd ${build_top}
RTEMS Tools Project <users at rtems.org> Mon Dec 28 15:08:35 2020
Report: devel/gmp-6.1.0.cfg
 Remotes:
 Status:
  Clean
 Head:
Build Set: (1) devel/gmp-6.1.0.cfg
Build Set: (2) devel/gmp-6.1.0.cfg
Package: gmp-6.1.0-x86_64-freebsd12.2-1
 Config: devel/gmp-6.1.0.cfg
 Summary:
  The GNU Multiple Precision Arithmetic Library (GMP) v6.1.0 for target
 URL:
  https://gmplib.org/
 Version:
  6.1.0
 Release:
  1
  Sources: 1
    1: https://gcc.gnu.org/pub/gcc/infrastructure/gmp-6.1.0.tar.bz2
       sha512:
3c82aeab9c1596d4da8afac2eec38e429e84f3211e1a572cf8fd2b546493c44c039b922a1133eaaa48bd7f3e11dbe795a384e21ed95cbe3ecc58d7ac02246117
  Patches: 0
 Preparation:
  build_top=$(pwd)
  %setup source gmp -q -n gmp-6.1.0
  %setup patch gmp -p1
  cd ${build_top}
 Build:
  build_top=$(pwd)
  cd gmp-6.1.0
checked).
    # Cross build
    # Host
    # Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
  else
    CC_FOR_BUILD=${CC}
  fi
  gmake -j 4 all
  cd ${build_top}
 Install:
  build_top=$(pwd)
  cd gmp-6.1.0
  cd ${build_top}
 Remotes:
 Status:
  Clean
 Head:
 Summary:
 URL:
  https://gmplib.org/
 Version:
  6.1.0
 Release:
  1
  Sources: 1
       sha512:
  Patches: 0
 Preparation:
  build_top=$(pwd)
  cd ${build_top}
 Build:
  build_top=$(pwd)
  cd gmp-6.1.0
checked).
    # Cross build
    # Host
    # Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
  else
    CC_FOR_BUILD=${CC}
  fi
  gmake -j 4 all
  cd ${build_top}
 Install:
  build_top=$(pwd)
  cd gmp-6.1.0
  cd ${build_top}
RTEMS Tools Project <users at rtems.org> Mon Dec 28 15:14:42 2020
Report: tools/rtems-gdb-head.cfg
 Remotes:
 Status:
  Clean
 Head:
Build Set: (1) tools/rtems-gdb-head.cfg
Build Set: (2) tools/rtems-gdb-head.cfg
Package: moxie-rtems6-gdb-acf10ca-x86_64-freebsd12.2-1
 Config: tools/rtems-gdb-head.cfg
 Summary:
  GDB vacf10ca for target moxie-rtems6 on host x86_64-freebsd12.2
 URL:
  http://www.gnu.org/software/gdb/
 Version:
  acf10ca
 Release:
  1
  Sources: 1
    1: --rsb-file=sourceware-mirror-binutils-gdb-acf10ca.tar.gz
https://codeload.github.com/RTEMS/sourceware-mirror-binutils-gdb/tar.gz/acf10ca
       No checksum
  Patches: 0
 Preparation:
  build_top=$(pwd)
  gdb_source=sourceware-mirror-binutils-gdb-acf10ca
  source_dir_gdb=${gdb_source}
  %setup source gdb -q -n ${gdb_source}
  %setup patch gdb -p1
  cd ${build_top}
 Build:
  build_top=$(pwd)
    # Cross-build (Xc) if no target or the host and target match.
    # Canadian-cross (Cxc) if build, host and target are all different.
    if test -z "moxie-rtems6" -o "x86_64-freebsd12.2" == "moxie-rtems6" ;
then
      build_dir="build-xc"
    else
      build_dir="build-cxc"
    fi
  else
    build_dir="build"
  fi
  mkdir -p ${build_dir}
  cd ${build_dir}
checked).
    # Cross build
    # Host
    # Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
  else
    CC_FOR_BUILD=${CC}
  fi
  GDB_LIBS_STATIC="-lexpat"
  else
  GDB_LIBS="-Xlinker -Bstatic ${LIBS_STATIC} -Xlinker -Bdynamic"
  fi
  LIBS_STATIC=${GDB_LIBS_STATIC}  LIBS=${GDB_LIBS}
../${source_dir_gdb}/configure  --build=x86_64-freebsd12.2
--host=x86_64-freebsd12.2  --target=moxie-rtems6  --verbose --disable-nls
--disable-gas --disable-binutils --disable-ld --disable-gold
--disable-gprof    --without-included-gettext  --disable-win32-registry
--disable-werror  --enable-sim    --without-zlib  --with-expat
--with-guile=no  --with-libiconv-prefix=/usr/local
--with-python=/usr/local/bin/python3
  gmake -j 4 all
  cd ${build_top}
 Install:
  build_top=$(pwd)
  /bin/rm -rf $SB_BUILD_ROOT
  cd ${build_dir}
  /bin/rm -rf $SB_BUILD_ROOT/home/joel/rtems-cron-6/tools/6/share/info/
configure.info*
  /bin/rm -f $SB_BUILD_ROOT/home/joel/rtems-cron-6/tools/6/share/info/dir
  touch $SB_BUILD_ROOT/home/joel/rtems-cron-6/tools/6/share/info/dir
  cd ${build_top}
 Remotes:
 Status:
  Clean
 Head:
 Summary:
 URL:
 Version:
  acf10ca
 Release:
  1
  Sources: 1
       No checksum
  Patches: 0
 Preparation:
  build_top=$(pwd)
  cd ${build_top}
 Build:
  build_top=$(pwd)
then
    else
    fi
  else
    build_dir="build"
  fi
  cd ${build_dir}
checked).
    # Cross build
    # Host
    # Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
  else
    CC_FOR_BUILD=${CC}
  fi
  else
  fi
  gmake -j 4 all
  cd ${build_top}
 Install:
  build_top=$(pwd)
  cd ${build_dir}
configure.info*
  cd ${build_top}
RTEMS Tools Project <users at rtems.org> Mon Dec 28 15:16:19 2020
Report: tools/rtems-binutils-head.cfg
 Remotes:
 Status:
  Clean
 Head:
Build Set: (1) tools/rtems-binutils-head.cfg
Build Set: (2) tools/rtems-binutils-head.cfg
Package: moxie-rtems6-binutils-acf10ca-x86_64-freebsd12.2-1
 Config: tools/rtems-binutils-head.cfg
 Summary:
  Binutils vacf10ca for target moxie-rtems6 on host x86_64-freebsd12.2
 URL:
  http://sources.redhat.com/binutils
 Version:
  acf10ca
 Release:
  1
  Sources: 1
       No checksum
  Patches: 0
 Preparation:
  build_top=$(pwd)
  binutils_source=sourceware-mirror-binutils-gdb-acf10ca
  source_dir_binutils=${binutils_source}
  %setup source binutils -q -n ${binutils_source}
  %setup patch binutils -p1
  cd ${build_top}
 Build:
  build_top=$(pwd)
then
    else
    fi
  else
    build_dir="build"
  fi
  cd ${build_dir}
checked).
    # Cross build
    # Host
    # Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
  else
    CC_FOR_BUILD=${CC}
  fi
  ../${source_dir_binutils}/configure  --build=x86_64-freebsd12.2
--disable-gdb --disable-libdecnumber --disable-readline --disable-sim
--enable-deterministic-archives  --enable-64-bit-bfd    --disable-lto
--without-included-gettext  --disable-win32-registry  --disable-werror
  gmake -j 4 all
  cd ${build_top}
 Install:
  cd ${build_top}
  cd ${build_dir}
configure.info*
  mkdir -p $SB_BUILD_ROOT/home/joel/rtems-cron-6/tools/6/share/locale
  /bin/rm -f ${SB_BUILD_ROOT}/home/joel/rtems-cron-6/tools/6/lib/libiberty*
  if test ! -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-6/tools/6/bin/moxie-rtems6-dlltool;
then
  /bin/rm -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-6/tools/6/share/man/man1/moxie-rtems6-dlltool*
  fi
  if test ! -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-6/tools/6/bin/moxie-rtems6-nlmconv;
then
  /bin/rm -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-6/tools/6/share/man/man1/moxie-rtems6-nlmconv*
  fi
  if test ! -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-6/tools/6/bin/moxie-rtems6-windres;
then
  /bin/rm -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-6/tools/6/share/man/man1/moxie-rtems6-windres*
  fi
  if test ! -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-6/tools/6/bin/moxie-rtems6-windmc;
then
  /bin/rm -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-6/tools/6/share/man/man1/moxie-rtems6-windmc*
  fi
  cd ${build_top}
 Remotes:
 Status:
  Clean
 Head:
 Summary:
 URL:
 Version:
  acf10ca
 Release:
  1
  Sources: 1
       No checksum
  Patches: 0
 Preparation:
  build_top=$(pwd)
  cd ${build_top}
 Build:
  build_top=$(pwd)
then
    else
    fi
  else
    build_dir="build"
  fi
  cd ${build_dir}
checked).
    # Cross build
    # Host
    # Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
  else
    CC_FOR_BUILD=${CC}
  fi
  gmake -j 4 all
  cd ${build_top}
 Install:
  cd ${build_top}
  cd ${build_dir}
configure.info*
  if test ! -f
then
  /bin/rm -f
  fi
  if test ! -f
then
  /bin/rm -f
  fi
  if test ! -f
then
  /bin/rm -f
  fi
  if test ! -f
then
  /bin/rm -f
  fi
  cd ${build_top}
RTEMS Tools Project <users at rtems.org> Mon Dec 28 15:33:06 2020
Report: tools/rtems-gcc-10-newlib-head.cfg
 Remotes:
 Status:
  Clean
 Head:
Build Set: (1) tools/rtems-gcc-10-newlib-head.cfg
Build Set: (2) tools/rtems-gcc-10-newlib-head.cfg
Package: moxie-rtems6-gcc-03e2d83-newlib-415fdd4-x86_64-freebsd12.2-1
 Config: tools/rtems-gcc-10-newlib-head.cfg
 Summary:
  GCC v03e2d83 and Newlib v415fdd4 for target moxie-rtems6 on host
x86_64-freebsd12.2
 URL:
  http://gcc.gnu.org/
 Version:
  03e2d83
 Release:
  1
  Sources: 6
    1: --rsb-file=gnu-mirror-gcc-03e2d83.tar.gz
https://codeload.github.com/RTEMS/gnu-mirror-gcc/tar.gz/03e2d83
       No checksum
    2: --rsb-file=newlib-415fdd4.tar.gz
https://codeload.github.com/RTEMS/sourceware-mirror-newlib-cygwin/tar.gz/415fdd4
       No checksum
    3: https://ftp.gnu.org/gnu/mpc/mpc-1.0.3.tar.gz
       sha512:
0028b76df130720c1fad7de937a0d041224806ce5ef76589f19c7b49d956071a683e2f20d154c192a231e69756b19e48208f2889b0c13950ceb7b3cfaf059a43
    4: https://ftp.gnu.org/gnu/gmp/gmp-6.1.0.tar.bz2
       sha512:
    5: https://ftp.gnu.org/gnu/mpfr/mpfr-3.1.4.tar.bz2
       sha512:
51066066ff2c12ed2198605ecf68846b0c96b548adafa5b80e0c786d0df488411a5e8973358fce7192dc977ad4e68414cf14500e3c39746de62465eb145bb819
    6: https://gcc.gnu.org/pub/gcc/infrastructure/isl-0.18.tar.bz2
       sha512:
85d0b40f4dbf14cb99d17aa07048cdcab2dc3eb527d2fbb1e84c41b2de5f351025370e57448b63b2b8a8cf8a0843a089c3263f9baee1542d5c2e1cb37ed39d94
  Patches: 1
    1:
https://devel.rtems.org/raw-attachment/ticket/4196/0001-gcov-Add-fprofile-info-section-support.patch
       sha512:
284c4eb2180e8a7dac600b5833da5d2f99568b7fc2f873c145665ef56ab72ca3e9ac3da1e8bc88e72dd229f02a28402770d82ddd7a1b836836ae00cdfd1d400f
 Preparation:
  build_top=$(pwd)
  gcc_source=gnu-mirror-gcc-03e2d83
  source_dir_gcc=${gcc_source}
  %setup source gcc -q -n ${gcc_source}
  %setup patch gcc -p1
  cd ${build_top}
  source_dir_newlib=sourceware-mirror-newlib-cygwin-415fdd4
  %setup source newlib -q -D -n ${source_dir_newlib}
  %setup patch newlib -p1
  cd ${build_top}
  /bin/rm -f ${source_dir_gcc}/newlib
  ln -s $PWD/${source_dir_newlib}/newlib ${source_dir_gcc}/newlib
  source_dir_isl="isl-0.18"
  %setup source isl -q -D -n isl-0.18
  %setup patch isl -p1
  cd ${build_top}
  /bin/rm -f ${source_dir_gcc}/isl
  ln -s $PWD/${source_dir_isl} ${source_dir_gcc}/isl
  source_dir_mpfr="mpfr-3.1.4"
  %setup source mpfr -q -D -n mpfr-3.1.4
  %setup patch mpfr -p1
  cd ${build_top}
  /bin/rm -f ${source_dir_gcc}/mpfr
  ln -s $PWD/${source_dir_mpfr} ${source_dir_gcc}/mpfr
  source_dir_mpc="mpc-1.0.3"
  %setup source mpc -q -D -n mpc-1.0.3
  %setup patch mpc -p1
  cd ${build_top}
  /bin/rm -f ${source_dir_gcc}/mpc
  ln -s $PWD/${source_dir_mpc} ${source_dir_gcc}/mpc
  source_dir_gmp="gmp-6.1.0"
  %setup source gmp -q -D -n gmp-6.1.0
  cd ${build_top}
  /bin/rm -f ${source_dir_gcc}/gmp
  ln -s $PWD/${source_dir_gmp} ${source_dir_gcc}/gmp
  echo "RTEMS 6, RSB d3dc0bc3861362978cdf65725e4ba2b64e283d32, Newlib
415fdd4" > ${source_dir_gcc}/gcc/DEV-PHASE
  cd ${source_dir_gcc}
  contrib/gcc_update --touch
  cd ${build_top}
 Build:
  build_top=$(pwd)
then
    else
    fi
  else
    build_dir="build"
  fi
  cd ${build_dir}
  languages="c"
  languages="$languages,c++"
checked).
    # Cross build
    # Host
    # Build
's,-std=gnu99 ,,
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201228/8773e14e/attachment-0001.html>
