How many threads does RTEMS create?
Richi Dubey richidubey at gmail.com
Thu Dec 31 18:48:23 UTC 2020
Hi Dr. Sherrill,
Thank you for your quick reply.
You can always compare the behavior with a normal uniprocessor build.
Yes, this is what I am doing.
But this test has Init, High, IDLE, and OPERATION_COUNT+2 medium tasks.
> All should be at unique priorities.
Yes, thanks for confirming.
> It looks like the test is doing two timing operations. These are for
> specific yield cases. Which one isn't behaving right for you?
The 2nd thread that executes the Tasks function exits and the code
terminates, i.e. the execution does not transfer to the third Tasks thread
function.
I have attached the gdb trace (executing at this
<https://github.com/richidubey/rtems/blob/a60d87b321e6658e10f39f9dd3f7b2c003d84c3c/cpukit/score/src/schedulerstrongapa.c#L153>
function)which shows that there are two different threads with High
priority, but this should not be the case, right? There should only be a
single High thread. Can you please take a look at it?
Thanks,
Richi.
On Mon, Dec 28, 2020 at 9:25 PM Joel Sherrill <joel at rtems.org> wrote:
> On Mon, Dec 28, 2020, 12:18 AM Richi Dubey <richidubey at gmail.com> wrote:
>> Hi,
>> When I am debugging the tm24 running on Strong APA scheduler, I can see
>> that when the Tasks
>> <https://git.rtems.org/rtems/tree/testsuites/tmtests/tm24/task1.c#n106>
>> function is being executed, there are two threads with priority 2, with
>> status SCHEDULER_SMP_NODE_BLOCKED in the list of threads, with both of them
>> having different addresses. How can there be two such threads?  Shouldn't
>> there only be a single thread with priority 2 that runs the High_task
>> <https://git.rtems.org/rtems/tree/testsuites/tmtests/tm24/task1.c#n77>
>> function? Please let me know your views about this.
>> Thank you,
>> Richi.
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210101/a99d057c/attachment.html>
189	    while ( next != tail ) {
(gdb)
0x001117cc	189	    while ( next != tail ) {
(gdb)
0x001117ce	189	    while ( next != tail ) {
(gdb)
0x001117d0	189	    while ( next != tail ) {
(gdb)
190	      node = (Scheduler_strong_APA_Node*) STRONG_SCHEDULER_NODE_OF_CHAIN( next );
(gdb)
0x001116f2	190	      node = (Scheduler_strong_APA_Node*) STRONG_SCHEDULER_NODE_OF_CHAIN( next );
(gdb)
(gdb)
192	      index_curr_cpu = _Per_CPU_Get_index( curr_CPU );
(gdb)
0x001116f8	192	      index_curr_cpu = _Per_CPU_Get_index( curr_CPU );
(gdb) p node
$3 = (Scheduler_strong_APA_Node *) 0x2011c8 <_RTEMS_tasks_Objects+600>
(gdb) p *node
$4 = {
  Base = {
    Base = {
      Node = {
        Chain = {
          next = 0x200838 <_Configuration_Scheduler_strong_APA_dflt+16>,
          previous = 0x200834 <_Configuration_Scheduler_strong_APA_dflt+12>
        RBTree = {
          Node = {
            rbe_left = 0x200838 <_Configuration_Scheduler_strong_APA_dflt+16>,
            rbe_right = 0x200834 <_Configuration_Scheduler_strong_APA_dflt+12>,
            rbe_parent = 0x0,
            rbe_color = 0
      sticky_level = 0,
      user = 0x200f70 <_RTEMS_tasks_Objects>,
      idle = 0x0,
      owner = 0x200f70 <_RTEMS_tasks_Objects>,
      Thread = {
        Wait_node = {
          next = 0x200fcc <_RTEMS_tasks_Objects+92>,
          previous = 0x200fc8 <_RTEMS_tasks_Objects+88>
        Scheduler_node = {
          Chain = {
            next = 0x200fd8 <_RTEMS_tasks_Objects+104>,
            previous = 0x200fd4 <_RTEMS_tasks_Objects+100>
        next_request = 0x0,
        request = SCHEDULER_NODE_REQUEST_NOT_PENDING
      Wait = {
        Priority = {
          Node = {
            Node = {
              Chain = {
                next = 0x0,
                previous = 0x0
              RBTree = {
                Node = {
                  rbe_left = 0x0,
                  rbe_right = 0x0,
                  rbe_parent = 0x0,
                  rbe_color = 0
            priority = 2
          Contributors = {
            rbh_root = 0x200f98 <_RTEMS_tasks_Objects+40>
          scheduler = 0x11bf78 <_Scheduler_Table>,
          Action = {
            next = 0x0,
            node = 0x0,
            type = PRIORITY_ACTION_ADD
      Priority = {
        value = 2,
        Lock = {
          sequence = 0
    state = SCHEDULER_SMP_NODE_BLOCKED,
    priority = 2
  Ready_node = {
    next = 0x201758 <_RTEMS_tasks_Objects+2024>,
    previous = 0x200b50 <_Thread_Objects+736>
  cpu_to_preempt = 0x200540 <_Per_CPU_Information>,
  Affinity = {
    __bits = {1}
(gdb) ni
0x001116fc	192	      index_curr_cpu = _Per_CPU_Get_index( curr_CPU );
(gdb)
194	        _Processor_mask_Is_set( &node->Affinity, index_curr_cpu )
(gdb)
0x00111700	194	        _Processor_mask_Is_set( &node->Affinity, index_curr_cpu )
(gdb)
(gdb)
0x00111704	194	        _Processor_mask_Is_set( &node->Affinity, index_curr_cpu )
(gdb)
0x00111706	194	        _Processor_mask_Is_set( &node->Affinity, index_curr_cpu )
(gdb)
0x0011170a	194	        _Processor_mask_Is_set( &node->Affinity, index_curr_cpu )
(gdb)
193	      if (
(gdb)
0x0011170e	193	      if (
(gdb)
196	        curr_state = _Scheduler_SMP_Node_state( &node->Base.Base );
(gdb)
(gdb)
0x00111714	196	        curr_state = _Scheduler_SMP_Node_state( &node->Base.Base );
(gdb)
0x00111718	196	        curr_state = _Scheduler_SMP_Node_state( &node->Base.Base );
(gdb)
198	        if ( curr_state == SCHEDULER_SMP_NODE_SCHEDULED ) {
(gdb)
0x0011171c	198	        if ( curr_state == SCHEDULER_SMP_NODE_SCHEDULED ) {
(gdb)
0x0011171e	198	        if ( curr_state == SCHEDULER_SMP_NODE_SCHEDULED ) {
(gdb)
216	        else if ( curr_state == SCHEDULER_SMP_NODE_READY ) {
(gdb)
0x00111772	216	        else if ( curr_state == SCHEDULER_SMP_NODE_READY ) {
(gdb)
0x00111774	216	        else if ( curr_state == SCHEDULER_SMP_NODE_READY ) {
(gdb)
233	    next = _Chain_Next( next );
(gdb)
0x001117c4	233	    next = _Chain_Next( next );
(gdb)
0x001117c8	233	    next = _Chain_Next( next );
(gdb)
(gdb)
(gdb)
(gdb)
(gdb)
(gdb)
(gdb)
(gdb)
(gdb) p node
$5 = (Scheduler_strong_APA_Node *) 0x2016d0 <_RTEMS_tasks_Objects+1888>
(gdb) p *node
$6 = {
  Base = {
    Base = {
      Node = {
        Chain = {
        RBTree = {
          Node = {
            rbe_parent = 0x0,
            rbe_color = 0
      sticky_level = 0,
      user = 0x201478 <_RTEMS_tasks_Objects+1288>,
      idle = 0x0,
      owner = 0x201478 <_RTEMS_tasks_Objects+1288>,
      Thread = {
        Wait_node = {
          next = 0x2014d4 <_RTEMS_tasks_Objects+1380>,
          previous = 0x2014d0 <_RTEMS_tasks_Objects+1376>
        Scheduler_node = {
          Chain = {
            next = 0x2014e0 <_RTEMS_tasks_Objects+1392>,
            previous = 0x2014dc <_RTEMS_tasks_Objects+1388>
        next_request = 0x0,
      Wait = {
        Priority = {
          Node = {
            Node = {
              Chain = {
                next = 0x0,
                previous = 0x0
              RBTree = {
                Node = {
                  rbe_left = 0x0,
                  rbe_right = 0x0,
                  rbe_parent = 0x0,
                  rbe_color = 0
            priority = 2
          Contributors = {
            rbh_root = 0x2014a0 <_RTEMS_tasks_Objects+1328>
          Action = {
            next = 0x0,
            node = 0x0,
      Priority = {
        value = 2,
        Lock = {
          sequence = 0
    priority = 2
  Ready_node = {
    next = 0x201c60 <_RTEMS_tasks_Objects+3312>,
    previous = 0x201250 <_RTEMS_tasks_Objects+736>
  Affinity = {
    __bits = {1}
(gdb) ni
(gdb)
(gdb)
(gdb)
(gdb)
