Ticket #3515
Bran S archsbran at gmail.com
Sat Feb 1 07:26:57 UTC 2020
On Thu, 30 Jan 2020 at 05:52, Chris Johns <chrisj at rtems.org> wrote:
> On 29/1/20 7:03 pm, Bran S wrote:
> > Hi Guys,
> > I am trying to solve #3515
> > https://devel.rtems.org/ticket/3515 <https://devel.rtems.org/ticket/3515>
> Nice and thanks.
> > For this issue covoar is required.
> > So I cloned https://git.rtems.org/rtems-tools/ <https://git.rtems.org/rtems-tools/>
> > This is my directory structure:
> > $HOME/quick-start/src/rtems - Main RTEMS repo
> > $HOME/quick-start/src/rsb - Source Builder
> > $HOME/quick-start/src/rtems-tools - The one that I have recently cloned
> > But running `rtems-test --list-bsps` inside '$HOME/quick-start/src/rtems-tools'
> > gives "error: RTEMS Toolkit python wrapper not found, plrease report"
> > Any ideas on how to resolve this error ?
> What does `type rtems-test` say?
> Have you built a set of sparc tools?
> Have you build the leon3 BSP and all the tests?
> I am not sure what happens if the `rtems-test` is run in the source tree while
> picking up a version from your path. Maybe `./tester/rtems-test ...` works?
It is now working my $PATH was wrongly set with rtems/4.11 instead of rtems/5.
I have corrected it. It now contains '$HOME/quick-start/rtems/5/bin'
Moving on to the next problem:
https://devel.rtems.org/wiki/GCI/Documentation/CoverageAnalysis/Coverage#RunningRTEMS-TESTERforCoverageanalysis
I was reading this to know more about covoar.
So as mentioned above I ran
`rtems-test --rtems-tools=/home/user45/quick-start/rtems/5/
--log=coverage_analysis.log --no-clean --coverage=score
--rtems-bsp=leon3-qemu-cov
/home/user45/quick-start/build/b-leon3/sparc-rtems5/c/leon3/testsuites/samples/hello.exe`
And the output was: https://paste.debian.net/1128608/
`qemu-system-sparc` not being installed seems to be the cause for the error.
So I followed suggestion found here:
https://lists.rtems.org/pipermail/users/2018-January/065583.html
Ran the commands as:
$ cd /quick-start/src/rsb/rtems/
The rsb directory contains rtems source builder.
$ ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/5
devel/qemu.bset
Running this further gives errors and reports it into
'rsb-report-glib-2.39.3-x86_64-linux-gnu-1.txt'
Full output of above command is at: https://paste.debian.net/1128609/
The content of 'rsb-report-glib-2.39.3-x86_64-linux-gnu-1.txt' is
here: https://paste.debian.net/1128610/
In file 'rsb-report-glib-2.39.3-x86_64-linux-gnu-1.txt' (at
https://paste.debian.net/1128610/) the first error occurs at line 385,
which is:
../../glib-2.39.3/glib/gdate.c:2497:7: error: format not a string
literal, format string not checked [-Werror=format-nonliteral]
       tmplen = strftime (tmpbuf, tmpbufsize, locale_format, &tm);
  CC       libglib_2_0_la-gdir.lo
  CC       libglib_2_0_la-genviron.lo
cc1: some warnings being treated as errors
Makefile:1782: recipe for target 'libglib_2_0_la-gdate.lo' failed
make[4]: *** [libglib_2_0_la-gdate.lo] Error 1
This happens to be a known error/bug (Ref:
https://bugs.freedesktop.org/show_bug.cgi?id=95326)
and a patch is available for it here:
https://gitlab.gnome.org/GNOME/glib/commit/8cdbc7fb2c8c876902e457abe46ee18a0b134486
Following the patch I manually made changes into
'$HOME/quick-start/src/rsb/rtems/build/glib-2.39.3-x86_64-linux-gnu-1/glib-2.39.3/glib/gdate.c'
But the problem is that as soon as I run
`../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/5
devel/qemu.bset`
My manual changes to the gdate.c disappear and I get the same error as
before. I don't know what is going on.
After this I found out that `qemu4.bset` is also present so I ran
devel/qemu4.bset
It seems to have run successfully here is the full output:
https://paste.debian.net/1128611/
Seems like qemu-system-sparc is now installed. But still while running
I get the same error related to qemu-system-sparc.
Here is the full output: https://paste.debian.net/1128612/
But this time there is a little difference.
Earlier it exited with exit code 2. see (https://paste.debian.net/1128608/)
Now it is exiting with exit code 1. see (https://paste.debian.net/1128612/)
Note: To see the exit code on the above 2 links you may have to use
the horizontal scroll.
What am I doing wrong ? Please suggest a way to solve this. I am just
trying to run a simple rtems-test coverage.
