Ticket #3515
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sat Feb 1 13:14:14 UTC 2020
On Sat, Feb 1, 2020 at 12:57 PM Bran S <archsbran at gmail.com> wrote:
> On Thu, 30 Jan 2020 at 05:52, Chris Johns <chrisj at rtems.org> wrote:
> > On 29/1/20 7:03 pm, Bran S wrote:
> > > Hi Guys,
> > > I am trying to solve #3515
> > > https://devel.rtems.org/ticket/3515 <
> https://devel.rtems.org/ticket/3515>
> > Nice and thanks.
> > > For this issue covoar is required.
> > > So I cloned https://git.rtems.org/rtems-tools/ <
> https://git.rtems.org/rtems-tools/>
> > > This is my directory structure:
> > > $HOME/quick-start/src/rtems - Main RTEMS repo
> > > $HOME/quick-start/src/rsb - Source Builder
> > > $HOME/quick-start/src/rtems-tools - The one that I have recently cloned
> > > But running `rtems-test --list-bsps` inside
> '$HOME/quick-start/src/rtems-tools'
> > > gives "error: RTEMS Toolkit python wrapper not found, plrease report"
> > > Any ideas on how to resolve this error ?
> > What does `type rtems-test` say?
> > Have you built a set of sparc tools?
> > Have you build the leon3 BSP and all the tests?
> > I am not sure what happens if the `rtems-test` is run in the source tree
> while
> > picking up a version from your path. Maybe `./tester/rtems-test ...`
> works?
> Hi Bran,
Thanks for taking up this ticket.
> It is now working my $PATH was wrongly set with rtems/4.11 instead of
> rtems/5.
> I have corrected it. It now contains '$HOME/quick-start/rtems/5/bin'
> Nice.
> Moving on to the next problem:
> https://devel.rtems.org/wiki/GCI/Documentation/CoverageAnalysis/Coverage#RunningRTEMS-TESTERforCoverageanalysis
> I was reading this to know more about covoar.
> So as mentioned above I ran
> `rtems-test --rtems-tools=/home/user45/quick-start/rtems/5/
> --log=coverage_analysis.log --no-clean --coverage=score
> --rtems-bsp=leon3-qemu-cov
> /home/user45/quick-start/build/b-leon3/sparc-rtems5/c/leon3/testsuites/samples/hello.exe`
> And the output was: https://paste.debian.net/1128608/
> `qemu-system-sparc` not being installed seems to be the cause for the
> error.
> So I followed suggestion found here:
> https://lists.rtems.org/pipermail/users/2018-January/065583.html
> Ran the commands as:
> $ cd /quick-start/src/rsb/rtems/
> The rsb directory contains rtems source builder.
> $ ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/5
> devel/qemu.bset
> You need devel/qemu-couverture.bset but while trying to build it, I see
the same error
as you see with qemu.bset
> Running this further gives errors and reports it into
> 'rsb-report-glib-2.39.3-x86_64-linux-gnu-1.txt'
> Full output of above command is at: https://paste.debian.net/1128609/
> The content of 'rsb-report-glib-2.39.3-x86_64-linux-gnu-1.txt' is
> here: https://paste.debian.net/1128610/
> In file 'rsb-report-glib-2.39.3-x86_64-linux-gnu-1.txt' (at
> https://paste.debian.net/1128610/) the first error occurs at line 385,
> which is:
> ../../glib-2.39.3/glib/gdate.c:2497:7: error: format not a string
> literal, format string not checked [-Werror=format-nonliteral]
> tmplen = strftime (tmpbuf, tmpbufsize, locale_format, &tm);
> CC libglib_2_0_la-gdir.lo
> CC libglib_2_0_la-genviron.lo
> cc1: some warnings being treated as errors
> Makefile:1782: recipe for target 'libglib_2_0_la-gdate.lo' failed
> make[4]: *** [libglib_2_0_la-gdate.lo] Error 1
> This happens to be a known error/bug (Ref:
> https://bugs.freedesktop.org/show_bug.cgi?id=95326)
> and a patch is available for it here:
> https://gitlab.gnome.org/GNOME/glib/commit/8cdbc7fb2c8c876902e457abe46ee18a0b134486
> Following the patch I manually made changes into
> '$HOME/quick-start/src/rsb/rtems/build/glib-2.39.3-x86_64-linux-gnu-1/glib-2.39.3/glib/gdate.c'
> But the problem is that as soon as I run
> `../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/5
> devel/qemu.bset`
> My manual changes to the gdate.c disappear and I get the same error as
> before. I don't know what is going on.
> I applied the patch that you found along with another patch and built the
souces, glib built
successfully, but unfortunately the couverture-qemu itself failed to build.
Here's the log:
https://paste.ofcode.org/KmJCNZrJyQNev6R4FSUafe
Here I'm pasting the diff to add patches to RSB:
diff --git a/bare/config/devel/glib-2.39.3-1.cfg
b/bare/config/devel/glib-2.39.3-1.cfg
index d86fe28..0bada15 100644
--- a/bare/config/devel/glib-2.39.3-1.cfg
+++ b/bare/config/devel/glib-2.39.3-1.cfg
@@ -14,6 +14,10 @@
%hash sha256 glib-%{glib_version}.tar.xz
d9fa6c9aa645a5e688a3bb29013bb83801b19ee767d99e33ff52e004e1cc5fc8
+#Patch to supress string literal warning
+%patch add glib
https://gitlab.gnome.org/GNOME/glib/commit/0817af40e8c74c721c30f6ef482b1f53d12044c7.patch
+%patch add glib
https://gitlab.gnome.org/GNOME/glib/commit/566e1d61a500267c7849ad0b2552feec9c9a29a6.patch
# The GLib build instructions. We use 2.x.x Release 1.
You can apply the above diff into your rtems-source-builder and try to
build couverture qemu.
Most likely it will fail it seems.
> After this I found out that `qemu4.bset` is also present so I ran
> devel/qemu4.bset
> It seems to have run successfully here is the full output:
> https://paste.debian.net/1128611/
> Seems like qemu-system-sparc is now installed. But still while running
> I get the same error related to qemu-system-sparc.
> Here is the full output: https://paste.debian.net/1128612/
> But this time there is a little difference.
> Earlier it exited with exit code 2. see (https://paste.debian.net/1128608/
> Now it is exiting with exit code 1. see (https://paste.debian.net/1128612/
> Note: To see the exit code on the above 2 links you may have to use
> the horizontal scroll.
> What am I doing wrong ? Please suggest a way to solve this. I am just
> trying to run a simple rtems-test coverage.
For now, I suggest you to use --rtems-bsp=leon3-sis-cov instead of qemu,
this is give you the reports and you can start focusing on your main ticket.
Best regards,
Vijay
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200201/a11115c1/attachment.html>
