[PATCH 6/7] bsps: Remove uses of BSP_GET_WORK_AREA_DEBUG
Sebastian Huber
Sat Feb 1 14:28:12 UTC 2020
----- Am 20. Jan 2020 um 6:01 schrieb Chris Johns chrisj at rtems.org:
> On 17/12/19 4:57 pm, Sebastian Huber wrote:
>> My experience tells me that doing a BSP development without a debugger is a
>> waste of time.
> Sometimes getting a working debugger is more effort than getting a BSP to work.
> The Pi is an example. I believe Alan used print statements.
Ok, what do you think about a new configuration option:
CONFIGURE_ENABLE_VERBOSE_INITIALIZATION
This configuration option could enable a bunch of system initialization handlers which print (via printk()) some information for each of the RTEMS_SYSINIT_* steps.
