[PATCH 6/7] bsps: Remove uses of BSP_GET_WORK_AREA_DEBUG
Mon Feb 3 00:14:11 UTC 2020
On 2/2/20 1:28 am, Sebastian Huber wrote:
> ----- Am 20. Jan 2020 um 6:01 schrieb Chris Johns chrisj at rtems.org:
>> On 17/12/19 4:57 pm, Sebastian Huber wrote:
>>> My experience tells me that doing a BSP development without a debugger is a
>>> waste of time.
>> Sometimes getting a working debugger is more effort than getting a BSP to work.
>> The Pi is an example. I believe Alan used print statements.
> Ok, what do you think about a new configuration option:
> CONFIGURE_ENABLE_VERBOSE_INITIALIZATION
CONFIGURE_ENABLE_VERBOSE_SYS_INIT ?
> This configuration option could enable a bunch of system initialization handlers which print (via printk()) some information for each of the RTEMS_SYSINIT_* steps.
Great and thanks.
