[rtems-docs PATCH] user/testing: Add coverage analysis instructions
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sat Feb 1 15:29:08 UTC 2020
user/testing/coverage.rst | 68 +++++++++++++++++++++++++++++++++++++++
user/testing/index.rst | 1 +
2 files changed, 69 insertions(+)
create mode 100644 user/testing/coverage.rst
diff --git a/user/testing/coverage.rst b/user/testing/coverage.rst
new file mode 100644
index 0000000..2994c62
--- /dev/null
+++ b/user/testing/coverage.rst
@@ -0,0 +1,68 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2019 Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
+Coverage Analysis
+RTEMS is used in many critical systems. It is important that the RTEMS Project
+ensure that the RTEMS product is tested as thoroughly as possible. With this
+goal in mind, the RTEMS test suite was expanded so that 100% of the RTEMS
+executive is tested.
+RTEMS-TESTER takes the following arguments to produce coverage reoprt:
+`--coverage :`
+ When the coverage option is enabled the tester produces coverage reports for
+ all the symbols in cpukit. To generate coverage report for a specific
+ symbol-set ( eg.: score) the symbol-set is passed as an argument to the
+ option. eg.: --coverage=score.
+`--no-clean :`
+ Tells the script not to delete the .cov trace files generated while running
+ the coverage. These Trace files are used for debugging purposes and will not
+ be needed for a normal user.
+For example: To generate coverage report of hello.exe for leon3 on SIS, the
+following command will be used:
+.. code-block:: none
+ rtems-test \
+ --rtems-tools=$HOME/development/rtems/5 \
+ --log=coverage_analysis.log \
+ --no-clean \
+ --coverage \
+ --rtems-bsp=leon3-sis-cov \
+ $HOME/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/hello.exe
+The command will create the coverage report in the following tree structure:
+ ├── coverage_analysis.log
+ ├── leon3-sis-coverage
+ │ └── score
+ │ ├── annotated.html
+ │ ├── annotated.txt
+ │ ├── branch.html
+ │ ├── branch.txt
+ │ ├── covoar.css
+ │ ├── ExplanationsNotFound.txt
+ │ ├── index.html
+ │ ├── no_range_uncovered.html
+ │ ├── no_range_uncovered.txt
+ │ ├── NotReferenced.html
+ │ ├── sizes.html
+ │ ├── sizes.txt
+ │ ├── summary.txt
+ │ ├── symbolSummary.html
+ │ ├── symbolSummary.txt
+ │ ├── table.js
+ │ ├── uncovered.html
+ │ └── uncovered.txt
+ └── leon3-sis-report.html
+The html on top of the directory, i.e., leon3-sis-report.html is the top level
+navigation for the coverage analysis report and will let the user browse through
+all the generated reports from different subsystems.
diff --git a/user/testing/index.rst b/user/testing/index.rst
index a938af4..3d36fab 100644
--- a/user/testing/index.rst
+++ b/user/testing/index.rst
@@ -43,6 +43,7 @@ extension.
tests
configuration
+ coverage
consoles
simulation
gdb-jtag
2.21.1
