[PATCH 6/7] bsps: Remove uses of BSP_GET_WORK_AREA_DEBUG
Mon Feb 3 20:57:45 UTC 2020
On 3/2/20 5:38 pm, Sebastian Huber wrote:
> ----- Am 3. Feb 2020 um 7:12 schrieb Chris Johns chrisj at rtems.org:
>> On 3/2/20 4:21 pm, Sebastian Huber wrote:
>>> ----- Am 3. Feb 2020 um 1:14 schrieb Chris Johns chrisj at rtems.org:
>>>> On 2/2/20 1:28 am, Sebastian Huber wrote:
>>>>> ----- Am 20. Jan 2020 um 6:01 schrieb Chris Johns chrisj at rtems.org:
>>>>>> On 17/12/19 4:57 pm, Sebastian Huber wrote:
>>>>>>> My experience tells me that doing a BSP development without a debugger is a
>>>>>>> waste of time.
>>>>>> Sometimes getting a working debugger is more effort than getting a BSP to work.
>>>>>> The Pi is an example. I believe Alan used print statements.
>>>>> Ok, what do you think about a new configuration option:
>>>>> CONFIGURE_ENABLE_VERBOSE_INITIALIZATION
>>>> CONFIGURE_ENABLE_VERBOSE_SYS_INIT ?
>>> In v2 of the patch set I named it CONFIGURE_VERBOSE_INITIALIZATION. I am not in
>>> favour of abbreviations, since they are in general not used in the
>>> configuration options.
>> Sure.
>>> More precise would be CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION. It is longer, but
>>> would be not the longest configuration option name (e.g.
>>> CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER is longer). So, what about this one?
>> Yes CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION is OK, the original could imply more
>> to a new user.
> Ok, I will change the name to CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION. Anything else which needs to be addressed before I push the patch set?
I do not think so. Thanks.
