[PATCH 6/7] bsps: Remove uses of BSP_GET_WORK_AREA_DEBUG
Chris Johns
chrisj at rtems.org
Mon Feb 3 06:12:40 UTC 2020
On 3/2/20 4:21 pm, Sebastian Huber wrote:
> ----- Am 3. Feb 2020 um 1:14 schrieb Chris Johns chrisj at rtems.org:
>> On 2/2/20 1:28 am, Sebastian Huber wrote:
>>> ----- Am 20. Jan 2020 um 6:01 schrieb Chris Johns chrisj at rtems.org:
>>>> On 17/12/19 4:57 pm, Sebastian Huber wrote:
>>>>> My experience tells me that doing a BSP development without a debugger is a
>>>>> waste of time.
>>>> Sometimes getting a working debugger is more effort than getting a BSP to work.
>>>> The Pi is an example. I believe Alan used print statements.
>>> Ok, what do you think about a new configuration option:
>>> CONFIGURE_ENABLE_VERBOSE_INITIALIZATION
>> CONFIGURE_ENABLE_VERBOSE_SYS_INIT ?
> In v2 of the patch set I named it CONFIGURE_VERBOSE_INITIALIZATION. I am not in favour of abbreviations, since they are in general not used in the configuration options.
Sure.
> More precise would be CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION. It is longer, but would be not the longest configuration option name (e.g. CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER is longer). So, what about this one?
Yes CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION is OK, the original could imply more
to a new user.
