[PATCH 6/7] bsps: Remove uses of BSP_GET_WORK_AREA_DEBUG
Sebastian Huber
Mon Feb 3 06:38:10 UTC 2020
----- Am 3. Feb 2020 um 7:12 schrieb Chris Johns chrisj at rtems.org:
> On 3/2/20 4:21 pm, Sebastian Huber wrote:
>> ----- Am 3. Feb 2020 um 1:14 schrieb Chris Johns chrisj at rtems.org:
>>> On 2/2/20 1:28 am, Sebastian Huber wrote:
>>>> ----- Am 20. Jan 2020 um 6:01 schrieb Chris Johns chrisj at rtems.org:
>>>>> On 17/12/19 4:57 pm, Sebastian Huber wrote:
>>>>>> My experience tells me that doing a BSP development without a debugger is a
>>>>>> waste of time.
>>>>> Sometimes getting a working debugger is more effort than getting a BSP to work.
>>>>> The Pi is an example. I believe Alan used print statements.
>>>> Ok, what do you think about a new configuration option:
>>>> CONFIGURE_ENABLE_VERBOSE_INITIALIZATION
>>> CONFIGURE_ENABLE_VERBOSE_SYS_INIT ?
>> In v2 of the patch set I named it CONFIGURE_VERBOSE_INITIALIZATION. I am not in
>> favour of abbreviations, since they are in general not used in the
>> configuration options.
> Sure.
>> More precise would be CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION. It is longer, but
>> would be not the longest configuration option name (e.g.
>> CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER is longer). So, what about this one?
> Yes CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION is OK, the original could imply more
> to a new user.
Ok, I will change the name to CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION. Anything else which needs to be addressed before I push the patch set?
