Enabling Buildbot 'responsible user' emails.
Gedare Bloom
gedare at rtems.org
Thu Feb 6 03:28:27 UTC 2020
On Wed, Feb 5, 2020 at 2:26 PM Chris Johns <chrisj at rtems.org> wrote:
> On 6/2/20 8:18 am, Amar Takhar wrote:
> > Currently emails sent out directly are limited to Joel, Chris and myself. This
> > was setup during a testing phase.
> > Typically what will happen is if a Builder within Buildbot changes from:
> > Working -> Broken
> > Broken -> Working
> > It will send an email to the 'responsible users'. You can see a list for this
> > Build here:
> > https://buildbot.rtems.org/#/builders/19/builds/47
> > Click on the 'Responsible Users' tab.
> > What does everyone think about removing this restriction and simply sending out
> > emails when a build breaks. This way the developer who has changed the status
> > of a build is notified immediately.
> +1
> > This does mean, once all 250 emails are enabled if the build breaks you could
> > get swamped.
> Can we enable this for one BSP from each tier 1 architectures?
I would like it to be a single email to indicate there is a new
breakage. Enough to indicate "hey go take a look at the full build
results! something is wrong here"
It should be opt-in to the full results.
> > Buildbot does support both Pushover and Pushjet as well.
> Is this like social media and that stuff? ;)
> > We also have an IRC channel on Freenode that is #rtems-build where announcements
> > happen.
> Yes.
> > Nobody likes getting swamped with emails however we could try it out and see how
> > it goes. I do plan on adding the rest of the BSPs at some point when I have
> > free time.
> Awesome.
> devel mailing list
> devel at rtems.org
