Enabling Buildbot 'responsible user' emails.
Amar Takhar
amar at rtems.org
Fri Feb 7 05:39:22 UTC 2020
On 2020-02-07 16:17 +1100, Chris Johns wrote:
> Could we build an "always must build" BSP and if it builds a wider selection are
> built? The beaglebone black is my pick.
That's the way it already works now and has for years.
Look at the waterfall the process is:
1. Build snapshot
2. Build sparc/erc32
3. If #2 passes trigger <all builds>
4. If #3 passes build "stable" snapshot.
You can see this by viewing: https://buildbot.rtems.org/#/waterfall and looking
at the timeline to see the order.
> This would avoid a issue in the common code or buildbot needing updated tools
> from generating the same message a number of times.
Yes again it already works this way and has for the last 6 years. :)
> Note, it cannot be a SPARC BSP because it is not a tier 1 architecture as no
> hardware test results has been published <hint hint>.
No idea nobody has ever mentioned anything and it's clear on Buildbot that the
CHECK BSP is what is used... this is what was given to me a very long time ago.
Which one should it be now? Can everyone agree one one?
Amar.
